Home » Modeling » GMF (Graphical Modeling Framework) » reserved word for EMF classes ?
reserved word for EMF classes ? [message #86632] Wed, 20 December 2006 08:19 Go to next message
next question:
I have a strange behaviour in my gmf result. Having a ecore model
containing classes "Screen" and "Loop" extending the same base class.
When I setup my gmffmap to refer to the loop class as domain element for
the node mapping: the palette of the gmf diagram is empty except the
selection tool. Everything works fine, if I use the screen as domain
element. The reason can't be the gmftool or gmfgraph, because I can use
both screen tool and loop tool and as well screen figure and loop figure.
Are there any known limitations regarding the domain element class name ?
Sven
Re: reserved word for EMF classes ? [message #86723 is a reply to message #86632] Wed, 20 December 2006 10:27 Go to previous messageGo to next message
Originally posted by: 5d5.mail.ru
We do convert domain model class and feature names to valid java
identifiers wherever possible though there may be some holes; 'Screen'
and 'Loop' are quite valid so the problem should be somewhere else (((
Sven Krause wrote:
> next question:
> Sven
Re: reserved word for EMF classes ? [message #86750 is a reply to message #86723] Wed, 20 December 2006 13:08 Go to previous message
Thanks, I'll give them a try.
Sven
> Sven Krause wrote:
>> next question:
>> for the node mapping: the palette of the gmf diagram is empty except
>> the selection tool. Everything works fine, if I use the screen as
>> domain element. The reason can't be the gmftool or gmfgraph, because I
>> can use both screen tool and loop tool and as well screen figure and
>> loop figure.
>> Sven
Previous Topic:Connection Handles doesn't work...
Next Topic:How to add Widgets to the Palette
Current Time: Sun Jul 27 02:51:26 EDT 2025
Powered by FUDForum. Page generated in 0.16225 seconds
