Home » Eclipse Projects » GEF » Logic example router problem
Logic example router problem [message #86626] Mon, 07 July 2003 12:40 Go to next message
Originally posted by: carlos.grahl.senior.com.br
When I try to make two connections between the same anchors on the logic
diagram, the second connection does not connect to the anchor. It goes to
some point on the diagram which is not connected to anything. Take a look at
the three pictures attached.
Step1.bmp: two figures with a Connection between them.
Step2.bmp: This is what happens when I'm creating the second Connection.
Step3.bmp: When I release the mouse button, the second Connection goes to a
point which is not connected to any figure.
When I'm dragging the connection the AutomaticRouter inserts a bendpoint in
the middle of the line, but when I release the mouse button, the connection
goes to a place totally wrong. I think that the correct behaviour could be
two possibilities:
1) Using the AutomaticRouter and create the Connection
2) Does not create the second Connection (which already exists - it's
exactly the same as the first)
How to solve that?
Carlos Augusto Grahl
  • Attachment: steps.zip
    (Size: 2.65KB, Downloaded 110 times)
Re: Logic example router problem [message #86669 is a reply to message #86626] Mon, 07 July 2003 23:43 Go to previous messageGo to next message
The example should prevent this from happening, but doesn't. It's a bug in
the example. The logic model only supports a single incoming connection per
terminal, but multiple outgoing wires are allowed.
"Carlos Augusto C. Grahl" <carlos.grahl@senior.com.br> wrote in message
news:bec7qk$v2o$1@eclipse.org...
> Hello,
a
in
connection
> two possibilities:
> How to solve that?
> Thanks
Re: Logic example router problem [message #86677 is a reply to message #86669] Mon, 07 July 2003 23:44 Go to previous messageGo to next message
Not only is it a bug in the example, but it's a feature in GEF that the
bogus connection is still visible ;-)
When the connection editpart looses its target, which is the case, we still
show the connection, but give it a hard-coded anchor point.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:bedel4$1rj$1@eclipse.org...
in
per
> > Hello,
to
look
> at
to
> a
> in
> connection
be
> > two possibilities:
> > How to solve that?
> > Thanks
Re: Logic example router problem [message #86691 is a reply to message #86677] Tue, 08 July 2003 07:19 Go to previous messageGo to next message
Hi!
And you have any hint on how to solve this bug (how let the editpart have
more than one incoming connection)?
Thanks!
"Randy Hudson" <none@us.ibm.com> escreveu na mensagem
news:beden5$1s5$1@eclipse.org...
still
> in
> per
> > > Hello,
logic
> to
> look
> > at
Connection.
> to
> > a
bendpoint
> > in
> > connection
could
> be
> > > two possibilities:
> > > How to solve that?
> > > Thanks
Re: Logic example router problem [message #86702 is a reply to message #86691] Tue, 08 July 2003 10:09 Go to previous message
The fix is to prevent the second connection from being connected. This can
be done in the ConnectionCommand.
If you had two input wires, which one would you use to determine the boolean
value of the input? It doesn't make sense.
news:bee9c0$mg2$1@eclipse.org...
> Hi!
> Thanks!
> still
bug
> > in
connection
> > per
message
> > > > Hello,
> logic
goes
> > to
> > look
> > > at
> Connection.
goes
> > to
> > > a
> bendpoint
> > > in
> > > connection
> could
> > be
> > > > two possibilities:
it's
> > > > How to solve that?
> > > > Thanks
Previous Topic:[ANN] GEF 2.1.1 now available
Next Topic:Flow of control during drag and drop
Current Time: Mon Sep 01 00:51:48 EDT 2025
Powered by FUDForum. Page generated in 0.04718 seconds
