Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Dynamic classes are mapped as static/generated
[Teneo] Dynamic classes are mapped as static/generated [message #86625] Sun, 17 June 2007 12:51 Go to next message
I was unable to find EMFT category in bugzilla so I am posting this here.
Detection whether model class is dynamic or static is broken with latest
Teneo CVS and EMF 2.3. Dynamic classes get <class
name="org.eclipse.emf.ecore.impl.DynamicEObjectImpl" ... > mapping,
which fails.
MappingContext#isDynamic is set to false for dynamic classes.
ERuntime#computeConcreteInstanceMapping detects that instance was
created and takes that as evidence that class is dynamic. But this just
puts DynamicEObjectImpl in eclassifierToConcrete map. My quick fix below
was to check getInstanceClass() as well
for (EClassifier eclassifier : epack.getEClassifiers()) {
if (!(eclassifier instanceof EClass))
continue;
// BEGIN FIX
if(eclassifier.getInstanceClass() == null)
continue;
// END FIX
final Object instance = create((EClass)eclassifier);
if (instance != null) {
eclassifierToConcrete.put((EClass) eclassifier, instance
.getClass());
concreteToEClass.put(instance.getClass(),
(EClass) eclassifier);
I
-a
Re: [Teneo] Dynamic classes are mapped as static/generated [message #86639 is a reply to message #86625] Sun, 17 June 2007 23:22 Go to previous message
Thanks for reporting this, this is bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=193052
Btw, here is a direct hyperlink to create an emft bugzilla (select teneo in the component listbox):
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EMFT
gr. Martin
> which fails.
> continue;
> // BEGIN FIX
> continue;
> // END FIX
> .getClass());
> I
> -a
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Dynamic classes are mapped as static/generated [message #607003 is a reply to message #86625] Sun, 17 June 2007 23:22 Go to previous message
gr. Martin
> which fails.
> continue;
> // BEGIN FIX
> continue;
> // END FIX
> .getClass());
> I
> -a
The Netherlands
Previous Topic:[Teneo] Dynamic classes are mapped as static/generated
Next Topic:[Teneo] : VersionPropertyHandler returns null for dettached objects
Current Time: Mon Jul 14 06:16:25 EDT 2025
Powered by FUDForum. Page generated in 0.07227 seconds
