Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [TENEO] Hibernate update exception when updating existing data
[TENEO] Hibernate update exception when updating existing data [message #86518] Fri, 15 June 2007 05:08 Go to next message
I have an EMF model which I have persisted into a DB using Teneo and Hibernate. My EMF model is
initially loaded from an XML document and calling save on the root of the object graph will
correctly persist the document into the DB.
In my application I am trying to deal with new xml documents which may contain new elements for
persisting or updates to existing elements which were persisted from previous XML document submissions.
Test 1:
As a basic test I have loaded an initial XML document into my EMF model then persisted this to the
DB. I then attempted to load exactly the same document and perform a session.update() passing in the
root of the object graph . Sounds reasonable, it should overlay the object values on top of the old
ones and increment the version of each persisted object in the DB.
Problem 1:
An exception is thrown of the form
org.hibernate.NonUniqueObjectException: a different object with the same identifier value was
already associated with the session:
[cat.CategoryScheme#urn:sdmx:org.sdmx.infomodel.categorysche me.CategoryScheme=SDMX:categoryScheme1]
I am running this test in isolation so I have created a brand new session from Teneo, then I have
called empty() just to be sure, then when I perform my update( ) I see the error above. Am I missing
somethign here? How can the object possibly already be in the session ?
Test 2:
I load an initial XML document into my EMF model and persist this through Teneo/Hibernate to the DB.
I then attempt to load a new XML document which contains some new elements and one existing element.
I then call saveOrUpdate on the datagraph root. I would expect in this instance for hibernate to be
able to differentiate between new and existing elements and perform a save or update accordingly.
Problem 2:
10:00:40,359 WARN JDBCExceptionReporter:77 - SQL Error: 1062, SQLState: 23000
10:00:40,359 ERROR JDBCExceptionReporter:78 - Duplicate entry
'urn:sdmx:org.sdmx.infomodel.base.Agency=SDMX' for key 1
org.hibernate.exception.ConstraintViolationException: Could not execute JDBC batch update....etc etc
It seems again that hibernate is not differentiating between existing and new objects but this time
it gets further and is attemtping to put the object into the DB, but with a save instead of an
update. Should Teneo/Hibernate be able to handle this mixture of new and existing elements.
Ive looked through the Hibernate forums extensively on this issue and I cant seem to find any exact
related issues. Im thinking that my problem is more to with EMF and Teneo and the semantics of how
they interact with Hibernate......but I could be on totally the wrong track.
Anyone ever tried anything similiar to the above .. ?
Any help is greatly appreciated as always.
Duncan
Re: [TENEO] Hibernate update exception when updating existing data [message #86535 is a reply to message #86518] Fri, 15 June 2007 07:44 Go to previous messageGo to next message
Hi Duncan,
1) Hmm, what I can think of is the following: what can happen is that when saving part of the xml
tree an object from another part of the tree is loaded from the db (because there are references to
it), then when the other part of the tree is updated, hibernate finds that it already has an
instance with the same id.
2) I would need to run a testcase to get a better feel for what goes wrong there.
Can you make a small testcase for both cases?
gr. Martin
Duncan ALexander wrote:
> Hibernate. My EMF model is initially loaded from an XML document and
> calling save on the root of the object graph will correctly persist the
> contain new elements for persisting or updates to existing elements
> Test 1:
> then persisted this to the DB. I then attempted to load exactly the same
> document and perform a session.update() passing in the root of the
> top of the old ones and increment the version of each persisted object
> in the DB.
> Problem 1:
> identifier value was already associated with the session:
> session from Teneo, then I have called empty() just to be sure, then
> Test 2:
> through Teneo/Hibernate to the DB. I then attempt to load a new XML
> document which contains some new elements and one existing element. I
> instance for hibernate to be able to differentiate between new and
> Problem 2:
> 23000
> and new objects but this time it gets further and is attemtping to put
> the object into the DB, but with a save instead of an update. Should
> elements.
> cant seem to find any exact related issues. Im thinking that my problem
> is more to with EMF and Teneo and the semantics of how they interact
> Duncan
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [TENEO] Hibernate update exception when updating existing data [message #86550 is a reply to message #86535] Fri, 15 June 2007 08:11 Go to previous message
Hi Martin,
I have a small test case but I have included my full set of ecore files and my full hibernate
mapping as Im not confident that I can detach subsections from them.
I have forwarded these directly to you as they are owned by a customer.
My test code would do the following (TeneoSessionManager handles the setup of the DBDataStore):
// LOAD AND SET THE INITIAL DB STATE
teneoSession = TeneoSessionManager.getInstance();
teneoSession.empty();
EDataGraph externalIMAsDatagraph =
StructureMother.INSTANCE.getExternalIMAsDatagraph(
"/resources/TEST_1.X_SDMXIM_REGISTRY_BASE.xml");
Session session = teneoSession.getSession();
Transaction transaction = session.getTransaction();
transaction.begin();
session.save(externalIMAsDatagraph.getERootObject());
session.flush();
transaction.commit();
session.close();
// ATTEMPT TO LOAD A FURTHER DOCUMENT AND UPDATE THE DB STATE
// BY SAVEORUPDATING EACH INDIVIDUAL ELEMENT IN THE DOCUMENT.
"/resources/TEST_1.1_SDMXIM_DUPLICATE_CONCEPT_SCHEME.xml"); SDMXContainer sdmxContainer =
(SDMXContainer) externalIMAsDatagraph.getERootObject();
List identifiableList = sdmxContainer.getIdentifiable();
for (Object o : identifiableList) {
session.saveOrUpdate(o);
session.flush();
session.close();
From the above I would expect to see the Concept Scheme updated with one new concept (concept3) and
one updated concept(concept1) and one concept deleted (concept2)
Duncan
Martin Taal wrote:
> Hi Duncan,
> when saving part of the xml tree an object from another part of the tree
> is loaded from the db (because there are references to it), then when
> has an instance with the same id.
> wrong there.
> gr. Martin
>> and Hibernate. My EMF model is initially loaded from an XML document
>> and calling save on the root of the object graph will correctly
>> Test 1:
>> model then persisted this to the DB. I then attempted to load exactly
>> the same document and perform a session.update() passing in the root
>> values on top of the old ones and increment the version of each
>> Problem 1:
>> same identifier value was already associated with the session:
>> Test 2:
>> Problem 2:
>> SQLState: 23000
>> elements.
>> I cant seem to find any exact related issues. Im thinking that my
>> problem is more to with EMF and Teneo and the semantics of how they
>> Duncan
Re: [TENEO] Hibernate update exception when updating existing data [message #606996 is a reply to message #86518] Fri, 15 June 2007 07:44 Go to previous message
Hi Duncan,
gr. Martin
> Test 1:
> in the DB.
> Problem 1:
> Test 2:
> Problem 2:
> 23000
> elements.
> Duncan
The Netherlands
Re: [TENEO] Hibernate update exception when updating existing data [message #606997 is a reply to message #86535] Fri, 15 June 2007 08:11 Go to previous message
Hi Martin,
session.flush();
session.close();
session.flush();
session.close();
Duncan
Martin Taal wrote:
> Hi Duncan,
> wrong there.
> gr. Martin
>> Test 1:
>> Problem 1:
>> Test 2:
>> Problem 2:
>> SQLState: 23000
>> elements.
>> Duncan
Previous Topic:[TENEO] Hibernate update exception when updating existing data
Next Topic:[Teneo] : VersionPropertyHandler returns null for dettached objects
Current Time: Thu Jul 17 15:07:59 EDT 2025
Powered by FUDForum. Page generated in 0.09511 seconds
