Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [teneo/jpox] Question of design of metadata
[teneo/jpox] Question of design of metadata [message #86504] Thu, 14 June 2007 15:16 Go to next message
Hi Martin,
I have been working with several separate xsd files used within my
application. Some of the xsd files refer to other xsd file eg topology.xsd
header looks like this
<xs:schema
targetNamespace=" http://www.ibm.com/websphere/appserver/schemas/6.0/ibm-porta l-topology.xsd"
xmlns:portal=" http://www.ibm.com/websphere/appserver/schemas/6.0/ibm-porta l-topology.xsd"
xmlns:base=" http://www.ibm.com/websphere/appserver/schemas/6.0/ibm-porta l-base.xsd"
xmlns:security=" http://www.ibm.com/websphere/appserver/schemas/6.0/ibm-porta l-security.xsd"
The navigation.xsd header looks like this:
<xs:schema
targetNamespace=" http://www.ibm.com/websphere/appserver/schemas/6.0/ibm-porta l-navigation.xsd"
xmlns:navigation=" http://www.ibm.com/websphere/appserver/schemas/6.0/ibm-porta l-navigation.xsd"
What is the best way to create the metadata file(s) for this kind of
xsd(s)?
1) For example base.xsd is common to both. Should there be one set of
base.xsd tables and both topology and navigation.xsd should refer to the
base tables? There could be duplicate entries. Would the system know which
row to delete if needed? Or should there be a separate base tables for
each xsds?
2) Navigation.xsd also references topology.xsd. But neither is a
superset/subset of each other. I think creating separate topology tables
would be best. But unfortunately it uses the same namespace. Would
annotation be usefule here?
3) Or should there be one giant metadata jdo file for both xsd file?
Any advice would be appreciated. Thanks.
Julia
Re: [teneo/jpox] Question of design of metadata [message #86565 is a reply to message #86504] Fri, 15 June 2007 08:25 Go to previous messageGo to next message
Hi Julia,
I will do my best to answer your questions.
1) It always depends on different things, because both navigation and topology both use the same
base.xsd model, the most logical answer is that there should be one set of tables for base.xsd
(otherwise why would they share the same base model). Although at first sight there maybe not so
much overlap between the actual instance data between topology and navigation (at least that is what
I guess you mean) it is for other reasons easier if the same types are placed in the tables (for
example for reporting, or other external tools).
2) when looking at part 2 of your post you say that navigation also references topology but that you
prefer separate tables. Why is that?
3) When creating a jdo file Teneo requires both the epackage(s) itself and the epackage(s) on which
they depend (it needs this to compute foreign-key mappings etc). In your case you maybe want to have
separate jdo files for navigation and topology (for example because they are distributed
separately). So what you can try is create a jdo file for base.xsd and topology.xsd and a second jdo
file for base.xsd and navigation.xsd. As the base.xsd part in both jdo's is the same the end result
should be that only one set of tables is created for the base.xsd part. (you need to test this to be
sure ofcourse).
gr. Martin
Julia wrote:
> Hi Martin,
> topology.xsd header looks like this
> <xs:schema
> <xs:schema
> xsd(s)?
> which row to delete if needed? Or should there be a separate base tables
> for each xsds?
> Julia
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [teneo/jpox] Question of design of metadata [message #86759 is a reply to message #86565] Mon, 18 June 2007 18:59 Go to previous messageGo to next message
Hi Martin,
My current application outputs all data to xml files. We want to be able
to scale upwards to use a database. but we still need to ability to use
file datastores. We want to maintain a common code base iwthout radically
altering previous code.
1) Yes I think that having a single set of base.xsd tables should work. I
will test this out. But I'm a little puzzled how the system would know
what row belongs to what xsds? There does not appear to be anyting linking
the referring xsd to the base.xsd. Do I have to add that as say a separate
column in base.xsd?
2) Navigation.xsd refers to topology.xsd but as it turns out topology.xsd
data is divided into to separate xml files (topology.xml and
global-topology.xml). So data from both these xmls can be used in
navigation.xsd tables. I was going to create separate tables for
topology,global-topology.xml and for the topology elements in
navigation.xsd. But I'm not sure if this is the right direction to go.
Could I use one set of topolopy.xsd tables and some how recognize what row
belongs to what xsd?
3) Yes a single metadata file per xsd would be easier to maintain.
Julia
Re: [teneo/jpox] Question of design of metadata [message #86815 is a reply to message #86759] Tue, 19 June 2007 18:26 Go to previous message
Hi Julia,
See inline below.
gr. Martin
Julia wrote:
> Hi Martin,
> radically altering previous code.
> I will test this out. But I'm a little puzzled how the system would know
> linking the referring xsd to the base.xsd. Do I have to add that as say
> a separate column in base.xsd?
MT>> I am not sure what you mean, the link between the referring xsd and the base.xsd is the
ereference from the referring xsd to the base.xsd, maybe I am missing something?
Or do you mean that when creating the actual data in the tables you don't know which data was
entered for the base.xsd as such or which data is refered to from the other xsd's?
> topology.xsd data is divided into to separate xml files (topology.xml
> and global-topology.xml). So data from both these xmls can be used in
> row belongs to what xsd?
MT>> I am not sure what you mean with 'recognize what row belongs to what xsd', do mean what rows
belongs to what xml?
> Julia
The Netherlands
Re: [teneo/jpox] Question of design of metadata [message #606998 is a reply to message #86504] Fri, 15 June 2007 08:25 Go to previous message
Hi Julia,
sure ofcourse).
gr. Martin
Julia wrote:
> Hi Martin,
> <xs:schema
> <xs:schema
> xsd(s)?
> for each xsds?
> Julia
The Netherlands
Re: [teneo/jpox] Question of design of metadata [message #607013 is a reply to message #86565] Mon, 18 June 2007 18:59 Go to previous message
Hi Martin,
column in base.xsd?
Julia
Re: [teneo/jpox] Question of design of metadata [message #607018 is a reply to message #86759] Tue, 19 June 2007 18:26 Go to previous message
Hi Julia,
See inline below.
gr. Martin
Julia wrote:
> Hi Martin,
> Julia
The Netherlands
Previous Topic:EMF Compare - Diffing EMF UML2 XMI
Next Topic:[Teneo] Child objects in DB have multiple references to parent.
Current Time: Sun Aug 31 01:42:47 EDT 2025
Powered by FUDForum. Page generated in 0.05192 seconds
