[ATL] How "getAppliedStereotypes()" operation works with ATL [message #86485] |
Mon, 14 July 2008 16:30  |
Hi all,
I have a question about how the "getAppliedStereotypes()" operation works
with ATL. In UML, a model element knows nothing about what stereotypes are
attached to it and the navigation goes from the stereotype to the
stereotyped element.
However in ATL rules, I can select a model element according to the
stereotype attach to it. Does ATL provide this as a build-in OCL operation?
Thanks for any help,
Rasha
Re: [ATL] How "getAppliedStereotypes()" operation works with ATL [message #86516 is a reply to message #86485] |
Tue, 15 July 2008 03:25   |
When using any EMF metamodel, ATL registers all the "custom" operations
which are defined in that metamodel. For instance, UML is basically an
EMF metamodel which has been extended with methods like
"getAppliedStereotypes", "getValue", "applyStereotype", etc... in order
to support of the profiles/stereotypes specification: those methods are
part of the eclipse UML2 framework.
ATL only maps method's calls to this framework.
William
rasha a écrit :
> Hi all,
> works with ATL. In UML, a model element knows nothing about what
> stereotypes are attached to it and the navigation goes from the
> stereotype to the stereotyped element. However in ATL rules, I can
> select a model element according to the stereotype attach to it. Does
> Rasha
Re: [ATL] How "getAppliedStereotypes()" operation works with ATL [message #95977 is a reply to message #86516] |
Mon, 24 November 2008 08:35   |
Originally posted by: Stefan.Warwas.freenet.de
could you please explain in more detail how to make these custom
operations available? I added the UML2 plug-ins to my Eclipse but when I
start the transformation, ATL always complains that it cannot find the
getAppliedStereotypes() operation. I already tried the "EMF-specific VM
only: Support UML2 stereotypes" option in the advanced tab of the run
configuration but it did not work. Moreover, I tried to switch the model
handler to UML2. Nothing worked.
Stefan
William Piers schrieb:
> Hello,
> William
> rasha a écrit :
>> Hi all,
>> Rasha
Re: [ATL] How "getAppliedStereotypes()" operation works with ATL [message #96034 is a reply to message #96019] |
Tue, 25 November 2008 03:00  |
I just found the solution. Somehow I overlooked the "EMF Registry"
button in the run configuration ;) That is why ATL did not find the
implementation of UML2... Now, I can answer my questions on my own:
Stefan Warwas schrieb:
> Hello
> Somehow it seems like that ATL does not find the operations implemented
> by the UML2 project. How does your run configuration exactly look like?
> My ATL header looks like this:
> module mymodule; -- Module Template
> create OUT : MM1 from IN : UML, PROFILE : UML;
Following header is sufficient:
create OUT : MM1 from IN : UML;
> What did you choose for the UML metamodel in the run configuration? Did
> you check "Is metametamodel" and selected "model handler: UML2"?
No, you don't have to check "Is metametamodel" and you don't have to
choose "model handler: UML2". Just click on the "EMF Registry..." button
and choose the UML2.1 metamodel.
> Did you enable "EMF-specific VM only: Support UML2 stereotypes" at the
> advanced tab? Did you changed the "ATL Virtual Machine" to "EMF-specific
> VM"?
No, you don't have to make these settings.
> Many questions ;) Thanks for your help!
> Stefan
> Skander schrieb:
>> you can use get AppliedStereotypes() ending with "s" like this:
>> helper context UML2!Element def : isStereotypeApplied (name :String) :
>> Boolean =
>> if self.oclIsUndefined() then
>> false
>> else
>> not self.getAppliedStereotypes()-> select(s| s.name=name)-> isEmpty()
>> endif
>> this works for me!
FUDForum. Page generated in 0.04178 seconds
