Home » Newcomers » Newcomers » Eclipse 3.1 start error
Eclipse 3.1 start error [message #86350] Wed, 13 July 2005 15:39 Go to next message
Originally posted by: zzheng.voicegenie.com
I am using Window 2000. I just downloaded Eclipse 3.1. When I try to start
it, I got the error message "Required Java version: 1.4.1. Available:
1.3.1_01". However, I have installed j2sdk-1_4_2_08. Can anyone tell me what
is wrong?
Zhong
Re: Eclipse 3.1 start error [message #86362 is a reply to message #86350] Wed, 13 July 2005 16:29 Go to previous messageGo to next message
Use the -vm command line argument for Eclipse to point to your 1.4.2 install
HTH
Darins
"Zhong Zheng" <zzheng@voicegenie.com> wrote in message
news:db3qho$8bu$1@news.eclipse.org...
> Hello,
what
> is wrong?
> Zhong
Re: Eclipse 3.1 start error [message #86375 is a reply to message #86362] Wed, 13 July 2005 20:50 Go to previous messageGo to next message
Originally posted by: cj19841015.hotmail.com
Or you can edit the system environment variable "JAVA_HOME" to make it point
to your 1.4.2 install directory.
BTW: modify the "PATH" and "CLASSPATH" as well.
Good luck:-)
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:db3tk8$bp1$1@news.eclipse.org...
> install
> HTH
> Darins
>> Hello,
>> start
> what
>> is wrong?
>> Thanks,
>> Zhong
Re: Eclipse 3.1 start error [message #86493 is a reply to message #86350] Thu, 14 July 2005 10:32 Go to previous message
Originally posted by: eclipse3.rizzoweb.com
Zhong Zheng wrote:
> Hello,
> is wrong?
This page might help: http://eclipsewiki.editme.com/StartupProblems
HTH,
Eric
Previous Topic:Plugins installation - Eclipse 3.1 (WinXP)
Next Topic:Eclipse 3.1, Update manager freezes network connection
Current Time: Fri Jul 25 11:00:55 EDT 2025
Powered by FUDForum. Page generated in 0.19467 seconds
