Getting the editor's widget [message #86341] |
Tue, 19 August 2003 05:04  |
is there any way for me to get at the StyledText widget underlying the
JavaEditor? I have only a reference to the editor itself (in this case,
from an EditorActionDelegate class). I know I am probably not supposed
to even be able to get at the widget, but this is going to be just an
evil hack, so please bear with me :->
Best,
Torsten
Re: Getting the editor's widget [message #87004 is a reply to message #86851] |
Wed, 20 August 2003 06:17   |
I'm using Eclipse 2.1.1, and getSourceViewer() is a protected method
(defined as final in AbstractTextEditor), so I can't call it, since I'm
not within the JavaEditor itself. Is there any other way?
Best,
Torsten
Darin Swanson wrote:
> JavaEditor.getSourceViewer().getTextWidget() ... and it is all API :-)
> Darins
> "Torsten Nahm" <tnahm@web.de> wrote in message
> news:bhsp4n$oiv$1@eclipse.org...
>>Hi,
>>Best,
>>Torsten
Re: Getting the editor's widget [message #87864 is a reply to message #87004] |
Thu, 21 August 2003 13:56   |
Sorry, I am living in 3.0 land and have no plans to go back :-)
Things have changed quite a bit in the JavaEditor / Text editor framework.
Darins
news:bhvhmt$9ns$1@eclipse.org...
> Best,
> Torsten
> > Darins
> >>Hi,
> >>Best,
> >>Torsten
Re: Getting the editor's widget [message #88102 is a reply to message #87864] |
Fri, 22 August 2003 02:15  |
Originally posted by: tom.eicher.gmx.ch.nodomain
AbstractTextEditor.getSourceViewer() is still protected as of 3.0... and
will probably remain so. You can get access to certain aspects of the
source viewer and the underlying widget, though (e.g.
getSelectionProvider()).
There is no proper way to get hold of the viewer or the widget from
outside an editor. You could always create your own editor by copying
code, though.
-tom
> Darins
>>Hi,
>>Best,
>>Torsten
>>>Darins
>>>>Hi,
>>>>Best,
>>>>Torsten
FUDForum. Page generated in 0.05062 seconds
