Home » Eclipse Projects » GEF » Overview doesn't work any more
Overview doesn't work any more [message #7761] Wed, 05 June 2002 07:24 Go to next message
Originally posted by: g.wagenknecht.intershop.de
Hi!
I use GraphicalRootEditPartWithOvervie in a project. With the latest source,
I
had to refactory my editor, but this was not a problem.
The overview button, which expands the overview, doesn't appear on top of
the
bottom scrollbar. I have to scroll down to see it and if I click on it a
overview of the editor is shown, but the current visible area isn't marked
anymore and I can't move the visible area.
Cu, Gunnar
Re: Overview doesn't work any more [message #7802 is a reply to message #7761] Wed, 05 June 2002 08:52 Go to previous messageGo to next message
Originally posted by: none.ibm.com
The overview is not meant to be used with the native scrollbars. The reason
is that with an overlapping figure like that, you can't use the optimized
scrolling available in Canvas. When scrolling down, the overview Tab would
get copied upwards.
We will provide another solution for using the overview.
"Gunnar Wagenknecht" <g.wagenknecht@intershop.de> wrote in message
news:adkrbj$vag$1@rogue.oti.com...
> Hi!
source,
> I
> the
> Cu, Gunnar
Re: Overview doesn't work any more [message #7824 is a reply to message #7802] Wed, 05 June 2002 09:30 Go to previous message
Hi!
"Randy Hudson" <none@ibm.com> schrieb im Newsbeitrag
news:adl0il$1tr$1@rogue.oti.com...
Will the new solution behave the same the old did it and will it be
available for 2.0 final?
If not, how can I switch back to the old one? Is it still in GEF?
Cu, Gunnar
Previous Topic:How to make selected EditPart visible in a viewer?
Next Topic:Examples for Polyline/PolylineDecoration
Current Time: Sun Jun 08 00:19:43 EDT 2025
Powered by FUDForum. Page generated in 0.03279 seconds
