Home » Archived » BIRT » Database Drivers fighting
Database Drivers fighting [message #86196] Tue, 01 November 2005 10:55 Go to next message
Originally posted by: m.n.com
I know this is not specific to BIRT,
but ..
I am trying to do BIRT and Hibernate Tools in the same IDE. Sadly when one
loads the database driver, the other can't. So I have to restart Eclipse.
But if the plugin doesn't load the driver itself, then it can't find it.
This is not specific to just these plugins. :(
Anyone have any idea on how to solve this?
Re: Database Drivers fighting [message #86241 is a reply to message #86196] Tue, 01 November 2005 11:11 Go to previous messageGo to next message
Mark,
I am not sure how to solve this, partly because I didnt think this would be
an issue, but does making a copy of it and using the Manage Drivers button
in the Data Source connection wizard make a difference?
Jason Weathersby
BIRT PMC
"Mark" <m@n.com> wrote in message news:dk834v$s61$1@news.eclipse.org...
> but ..
> one loads the database driver, the other can't. So I have to restart
> Eclipse. But if the plugin doesn't load the driver itself, then it can't
> find it. This is not specific to just these plugins. :(
Re: Database Drivers fighting [message #86257 is a reply to message #86241] Tue, 01 November 2005 11:35 Go to previous messageGo to next message
I don't think so. The driver is being loaded via a scripted dataset.
Also, the problem I am getting is with a dll - I am using DB2 app driver.
If I connect to a session in Hibernate first I get this in the report when I
preview it:
"Script engine error: Wrapped
org.hibernate.exception.JDBCConnectionException: Cannot open connection
(DataSet:MEM.open#39)"
If I preview the report first I get this in Hibernate Tools:
"org.hibernate.console.HibernateConsoleRuntimeException: Problems while
loading database driverclass (COM.ibm.db2.jdbc.app.DB2Driver)
java.sql.SQLException: java.lang.UnsatisfiedLinkError: Native Library
C:\Program Files\SQLLIB\bin\db2jdbc.dll already loaded in another
classloader
classloader
I've had this issue with other tools, but I have been able to live with it.
The problem now is that I am going to have Report Writers building the
reports and eventually doing some HQL development. I don't think they can or
will deal with the issue.
Is there an easy way to preview/run the reports externally to Eclipse - so
it runs in another JVM? Just for the real data. They can build the reports
with dummy objects (like in the demo).
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:dk843c$tgq$1@news.eclipse.org...
> Mark,
> be an issue, but does making a copy of it and using the Manage Drivers
> button in the Data Source connection wizard make a difference?
> Jason Weathersby
> BIRT PMC
>> but ..
Re: Database Drivers fighting [message #86272 is a reply to message #86257] Tue, 01 November 2005 13:02 Go to previous messageGo to next message
Mark,
If you download the Report Engine you can deploy them to Tomcat or another
J2EE server, which should be in another JVM. Launching two instances of
eclipse doesnt work?
Jason Weathersby
BIRT PMC
"Mark" <m@n.com> wrote in message news:dk85fk$vik$1@news.eclipse.org...
> I preview it:
> classloader
> classloader
> it. The problem now is that I am going to have Report Writers building the
> or will deal with the issue.
> reports with dummy objects (like in the demo).
>> Mark,
>> Jason Weathersby
>> BIRT PMC
>>> but ..
Re: Database Drivers fighting [message #86318 is a reply to message #86272] Tue, 01 November 2005 14:59 Go to previous messageGo to next message
I was looking into installing the viewer in tomcat. Looks pretty easy.
Yes, I could open another instance of Eclipse. That is what I have done
before. But memory becomes an issue. And the report writers might not have
as powerful machines.
I believe, for now, the solution will be that the report writers won't be
doing any Hibernate Developement. Just using the code created by the
developers. Long term, I would like to see them involved.
news:dk8ajg$7i9$1@news.eclipse.org...
> Mark,
> Jason Weathersby
> BIRT PMC
>> when I preview it:
>> classloader
>> classloader
>> the reports and eventually doing some HQL development. I don't think they
>> can or will deal with the issue.
>> so it runs in another JVM? Just for the real data. They can build the
>>> Mark,
>>> Jason Weathersby
>>> BIRT PMC
>>>> but ..
>>>> can't find it. This is not specific to just these plugins. :(
Re: Database Drivers fighting [message #86729 is a reply to message #86257] Wed, 02 November 2005 13:45 Go to previous message
This is a rather common issue when using Type-2 JDBC driver which loads a
native DLL. JVM can't handle the same DLL being loaded by two different
classloaders.
If a Java-native (type 4) JDBC driver is out of the question, try this and
see if it helps: add your JDBC driver to the system class path of the JVM
used by Eclipse. This way the driver class is loaded only once by the system
class loader.
Gary Xue
I
> preview it:
> classloader
> classloader
it.
or
reports
> > Mark,
> > Jason Weathersby
> > BIRT PMC
> >> but ..
can't
Previous Topic:Close dataset: is possible?
Next Topic:Charts
Current Time: Mon Sep 01 01:20:02 EDT 2025
Powered by FUDForum. Page generated in 0.04998 seconds
