Home » Language IDEs » C / C++ IDE (CDT) » Managed make: Fatal error in reader: line 2:unexpected end of line
Managed make: Fatal error in reader: line 2:unexpected end of line [message #86186] Wed, 19 November 2003 13:53 Go to next message
Originally posted by: jim.brown.mindspring.com
Brand new install of eclipse on Solaris 9. Eclipse 2.1.1, cdt 1.2.
I'm trying a simple HelloWorld project using Managed make.
When I build I get the referenced error.
I used managed make because I assumed it would write a correct make file.
Suggestions?
Re: Managed make: Fatal error in reader: line 2:unexpected end of line [message #86324 is a reply to message #86186] Thu, 20 November 2003 11:11 Go to previous messageGo to next message
Jim,
A little more information would be helpful, but I'm pretty sure from the
error that you are not using Gnu make. The generated makefile that the
managed builder produces relies on some Gnu extensions to 'make' that
are not supported by the vanilla make that ships on Solaris by default.
> Suggestions?
Re: Managed make: Fatal error in reader: line 2:unexpected end of line [message #86466 is a reply to message #86324] Thu, 20 November 2003 20:34 Go to previous messageGo to next message
Right on. There was indeed a make in the path before /usr/local/bin
Many thanks. I would have never thought of that.
Jim
Sean Evoy wrote:
> Jim,
>> Suggestions?
Re: Managed make: Fatal error in reader: line 2:unexpected end of line [message #86522 is a reply to message #86466] Fri, 21 November 2003 10:23 Go to previous message
Glad to help. In the CDT 2.0, the generated makefiles will be more
generic so people won't get tripped up by these sorts of problems.
> Jim
> Sean Evoy wrote:
>> Jim,
>> the error that you are not using Gnu make. The generated makefile that
>> the managed builder produces relies on some Gnu extensions to 'make'
>> that are not supported by the vanilla make that ships on Solaris by
>> default.
>>> file.
>>> Suggestions?
Previous Topic:Can we Make CDT Editor more comfortable?
Next Topic:code assist and co.
Current Time: Thu Jul 17 02:23:45 EDT 2025
Powered by FUDForum. Page generated in 0.06764 seconds
