Home » Newcomers » Newcomers » Plugins installation - Eclipse 3.1 (WinXP)
Plugins installation - Eclipse 3.1 (WinXP) [message #86167] Wed, 13 July 2005 11:59 Go to next message
Originally posted by: ptournet.nojunkmail-win-design.com
I get some trouble with the installation of plugins not using the Update
Manager. After extracting Eclipse 3.1, I can easily add some plugins by
unzipping them in the same directory, but once I have launched Eclipse one
after that, if I try to install one more plugin the same way, it doesn't
appear in "Software Updates/Manage Configuration".
Am I doing something wrong ? and/or is there a way to force Eclipse to
rescan its directory for new plugins ?
Thanx in advance,
Patrick
Re: Plugins installation - Eclipse 3.1 (WinXP) [message #86227 is a reply to message #86167] Wed, 13 July 2005 12:22 Go to previous messageGo to next message
I am new to this and the words I write here are not from experience but,=
I =
did read that Eclipse keeps a cache of plug-in data and that some plug-i=
ns =
require that Eclipse be started with the "-clear" command line option to=
empty the cache before they will be correctly detected. The article =
(which I can't put my hands on right now) seemed to feel that after =
instaling, updating or reconfiguring any plug-in you should start Eclips=
e =
once with the clear option.
Hope that helps!
-Dale
On Wed, 13 Jul 2005 11:59:09 -0400, Patrick Tournet =
<ptournet@nojunkmail-win-design.com> wrote:
> I get some trouble with the installation of plugins not using the Upda=
te
> Manager. After extracting Eclipse 3.1, I can easily add some plugins b=
y
> unzipping them in the same directory, but once I have launched Eclipse=
> one
> after that, if I try to install one more plugin the same way, it doesn=
't
> Am I doing something wrong ? and/or is there a way to force Eclipse to=
> Thanx in advance,
> Patrick
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
Re: Plugins installation - Eclipse 3.1 (WinXP) [message #86286 is a reply to message #86167] Wed, 13 July 2005 12:37 Go to previous message
Originally posted by: eclipse3.rizzoweb.com
Patrick Tournet wrote:
Run eclipse.exe with the -clean command-line option to get it to rescan.
That might help.
HTH,
Eric
Previous Topic:split pane?
Next Topic:Eclipse 3.1 start error
Current Time: Fri Jul 18 17:20:49 EDT 2025
Powered by FUDForum. Page generated in 0.07855 seconds
