Home » Newcomers » Newcomers » split pane?
split pane? [message #86152] Wed, 13 July 2005 11:03 Go to next message
I am just wondering if Eclipse has Split Pane functionality? Sometimes when
we write code, we need to refer to a segment that is miles down below or up
above our current line, and split pane comes in handy. Does Eclipse let me
do that? Since eclipse won't let me open one single file in two separate
windows, right now I have to open the same file using a different editor.
Thanks.
-- Jim
Re: split pane? [message #86271 is a reply to message #86152] Wed, 13 July 2005 12:36 Go to previous message
Originally posted by: eclipse3.rizzoweb.com
Jim Bear wrote:
> Hello,
> Thanks.
It sounds like you already know about the Window > New Editor feature to
get another editor on the same file. Then you can drag the tab or title
bar of one editor and position it above, below, or beside the other editors.
HTH,
Eric
Previous Topic:3.0.1 to 3.1 installation
Next Topic:Plugins installation - Eclipse 3.1 (WinXP)
Current Time: Fri Jul 18 20:36:12 EDT 2025
Powered by FUDForum. Page generated in 0.09918 seconds
