Home » Archived » M2M (model-to-model transformation) » [ATL] ATL Standalone - advanced parameters
[ATL] ATL Standalone - advanced parameters [message #86037] Mon, 07 July 2008 11:01
Originally posted by: jmcq.cs.nuim.ie
I'm using Dennis Wagelaar's ATL command line tool to run ATL as a
standalone application. I have successfully got this to work. However,
I'd like to be able to set the option 'print execution information to
console for each executed bytecode' from the advanced parameters of the
run configuration but via the standalone application not the ATL launch
configuration within the Eclipse IDE.
The following piece of code launches the transformation and I think I
need to somehow set the params variable to do this.
Map params = Collections.EMPTY_MAP;
AtlLauncher myLauncher = AtlLauncher.getDefault();
myLauncher.launch(trans, libs, models, params, superimpose);
Can anyone point me to some documentation on this?
Jacqui
Previous Topic:[ATL] generating ECore!EString or ECore!EInt, ...
Next Topic:[QVTO] Set contents not remembered between init and end
Current Time: Fri Jul 25 14:07:53 EDT 2025
Powered by FUDForum. Page generated in 0.05208 seconds
