Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo - JPOX] Enhanced classes
[Teneo - JPOX] Enhanced classes [message #86032] Tue, 12 June 2007 04:17 Go to next message
Originally posted by: fc_supercanard.yahoo.fr
I have made a model generation from xml schema and enhanced classes
using JPOX. Everything is working well when classes are in a separate
jar file, but when I put enhanced classes in the WebSphere Application
Server plug-in com.ibm.ws.webui_6.1.0.jar, an exception is thrown:
"ServletWrappe E SRVE0068E: Uncaught exception thrown in one of the
service methods of the servlet: IdMap. Exception thrown:
javax.jdo.JDOUserException: Found Meta-Data for class
package.impl.DocumentRootImpl but this class is not enhanced!! Please
enhance the class before running JPOX."
It does not recognize that classes are really enhanced.
Please advise me what to do?
Re: [Teneo - JPOX] Enhanced classes [message #86048 is a reply to message #86032] Tue, 12 June 2007 04:34 Go to previous messageGo to next message
I am not sure how you put the enhanced classes in the plugin. What I remember is that when you build
a plugin that the enhancement step is not done automatically. But I am not sure on this area. You
can ask this on the jpox newsgroup:
http://www.jpox.org/servlet/forum/index
gr. Martin
french.cancan wrote:
> Hello,
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo - JPOX] Enhanced classes [message #86063 is a reply to message #86048] Tue, 12 June 2007 04:47 Go to previous messageGo to next message
Hi Martin,
I have put the enhanced classes in the plug-in archive with a simple
copy-paste. I don't know how to build a plug-in with JPOX enhanced classes.
Unfortunately, the http://www.jpox.org/servlet/forum/index newsgroup is
down for a long time (gives "Invalid Session" message) so I don't know
how to solve the problem...
Martin Taal wrote:
> remember is that when you build a plugin that the enhancement step is
> not done automatically. But I am not sure on this area. You can ask this
> gr. Martin
>> Hello,
Re: [Teneo - JPOX] Enhanced classes [message #86078 is a reply to message #86063] Tue, 12 June 2007 05:08 Go to previous messageGo to next message
Just copying should work. Can you open the class file (present in the plugin) in eclipse, normally
it shows the method signatures which are present in the classfile, there should be a lot of methods
with jdo in their name.
One other thing to check is where your plugin loads the classes from, maybe your classes are present
twice (in another jar or plugin, you never know), see for example here:
http://blogs.sanmathi.org/ashwin/2007/02/09/dude-wheres-my-c lass/
Btw, the jpox forum works fine for me (at least I can see many recent posts).
gr. Martin
> Hi Martin,
> Martin Taal wrote:
>> gr. Martin
>>> Hello,
>>> Application Server plug-in com.ibm.ws.webui_6.1.0.jar, an exception
>>> is thrown:
The Netherlands
Re: [Teneo - JPOX] Enhanced classes [message #86108 is a reply to message #86078] Tue, 12 June 2007 16:31 Go to previous messageGo to next message
If you are using websphere, you need to run osgiCfgInit.bat to refresh the
cache when you modify something in the plugins directory. Then start the
server.
You also might need to modify the Manifest file in
com.ibm.ws.webui_6.1.0.jar to import any of the teneo/jpox packages.
Re: [Teneo - JPOX] Enhanced classes [message #86154 is a reply to message #86108] Wed, 13 June 2007 05:00 Go to previous messageGo to next message
> the cache when you modify something in the plugins directory. Then start
> the server.
I made all the verifications that Martin told me to do and everything
was ok (the classes are enhanced and the plug-in loads them from the
right position).
Then I modified the Manifest file in com.ibm.ws.webui_6.1.0.jar in order
to import.
The result of this step is that another exception is thrown when I want
to start my portlet.
service methods of the servlet: IdMap. Exception thrown :
java.lang.ExceptionInInitializerError
at java.lang.J9VMInternals.initialize(J9VMInternals.java:205)
at idmap.ResourceSetImplEx.createResource(ResourceSetImplEx.jav a:52)
And the row which is concerned in the file ResourceSetImplEx.java is
this one :
JpoxDataStore jpoxDataStore =
JpoxHelper.INSTANCE.createRegisterDataStore(pmfName);
Re: [Teneo - JPOX] Enhanced classes [message #86200 is a reply to message #86154] Wed, 13 June 2007 07:28 Go to previous message
I have never encountered this exception with the J9VMInternals. Apparently something goes wrong in a
static initializer. The jpoxhelper class has a static initializer which does this:
>> Source <<
log.info("Registering a jpox resource factory for all uri's with jpox as the protocol/extension");
log.info("Registering a jpox resource factory for all uri's with ejdo as the protocol/extension");
log.info("Registering a jpox resource dao factory for all uri's with jpoxdao as the
Resource.Factory.Registry.INSTANCE.getProtocolToFactoryMap() .put( "jpox", new JPOXResourceFactory());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "jpox", new JPOXResourceFactory());
// support old way
Resource.Factory.Registry.INSTANCE.getProtocolToFactoryMap() .put( "jpoxdao", new JPOXResourceFactory());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "jpoxdao", new JPOXResourceFactory());
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put(JpoxConstants.EJDO_EXTENSION,
System.setProperty("org.jpox.cache.level1.type", "org.eclipse.emf.teneo.jpox.cache.EMFWeakRefCache");
>> Source <<
Are you sure that all the required emf jars in the classpath?
Is this the complete stacktrace (I mean are other nested exceptions also being displayed)?
gr. Martin
>> start the server.
> right position).
> to import.
> this one :
The Netherlands
Re: [Teneo - JPOX] Enhanced classes [message #606903 is a reply to message #86032] Tue, 12 June 2007 04:34 Go to previous message
gr. Martin
> Hello,
The Netherlands
Re: [Teneo - JPOX] Enhanced classes [message #606904 is a reply to message #86048] Tue, 12 June 2007 04:47 Go to previous message
Hi Martin,
Martin Taal wrote:
> gr. Martin
>> Hello,
Re: [Teneo - JPOX] Enhanced classes [message #606907 is a reply to message #86063] Tue, 12 June 2007 05:08 Go to previous message
gr. Martin
> Hi Martin,
> Martin Taal wrote:
>> gr. Martin
>>> Hello,
>>> is thrown:
The Netherlands
Re: [Teneo - JPOX] Enhanced classes [message #606913 is a reply to message #86078] Tue, 12 June 2007 16:31 Go to previous message
server.
Re: [Teneo - JPOX] Enhanced classes [message #606923 is a reply to message #86108] Wed, 13 June 2007 05:00 Go to previous message
> the server.
right position).
to import.
this one :
Re: [Teneo - JPOX] Enhanced classes [message #606932 is a reply to message #86154] Wed, 13 June 2007 07:28 Go to previous message
>> Source <<
// support old way
>> Source <<
gr. Martin
>> start the server.
> right position).
> to import.
> this one :
The Netherlands
Previous Topic:[Teneo] Replacing persisted elements of an object heirarchy..
Next Topic:Issue with JPA Annotations
Current Time: Fri Jul 18 23:02:58 EDT 2025
Powered by FUDForum. Page generated in 0.12289 seconds
