Home » Modeling » GMF (Graphical Modeling Framework) » urgent: the problem with resizing svg figure
urgent: the problem with resizing svg figure [message #85919] Sat, 16 December 2006 03:57 Go to next message
Originally posted by: dzhpingbo.sohu.com
I can show svg figures properly by using the code below, but it comes out
problem when resizing the figure.You can see the the problem in the attached
picture.The "activity" figure only show half when decrease the size of
figure, and there comes out big space between figure and label when increase
the size of figure.
To my surprise, the presenter.svg which I download from cvs repository of
gmf, has no problem I mentioned above when resizing the figure.
So I wonder is there something special with the presenter.svg file, because
I run the activity.svg and present.svg with the same code list below.
looking forward to your answers, because my project requires me to show the
figures properly and it comes to the end of the project soon.
public static IPath path = new Path(TRANSLATE_PATH_ARGUMENT).append("icons"
+ IPath.SEPARATOR + "Activity.svg");;
protected NodeFigure createNodePlate() {
/*return new DefaultSizeNodeFigure(getMapMode().DPtoLP(40), getMapMode()
.DPtoLP(40));*/
URL presenterURL = null;
presenterURL = FileLocator.find(NewpmbeDiagramEditorPlugin
.getInstance().getBundle(), path, null);
RenderedImage rndImg = RenderedImageFactory.getInstance(presenterURL);
final ScalableImageFigure sif = new ScalableImageFigure(rndImg, false,
true, true);
NodeFigure figure = new WrapperNodeFigure(sif) {
protected ConnectionAnchor createDefaultAnchor() {
return new SlidableImageAnchor(this, sif);
protected ConnectionAnchor createAnchor(PrecisionPoint p) {
if (p == null)
// If the old terminal for the connection anchor cannot be resolved (by
SlidableAnchor) a null
// PrecisionPoint will passed in - this is handled here
return createDefaultAnchor();
return new SlidableImageAnchor(this, sif, p);
return figure;
Re: urgent: the problem with resizing svg figure [message #85937 is a reply to message #85919] Sat, 16 December 2006 06:41 Go to previous messageGo to next message
I know it relevents to viewbox, list below. But how can I know the width and
height of the svg file? which tool should I use to figure out the width and
<svg xmlns="&ns_svg;" xmlns:xlink="&ns_xlink;"
xmlns:a="http://ns.adobe.com/AdobeSVGViewerExtensions/3.0/"
width="35.81445" height="91.60449" viewBox="0 0 35.81445 91.60449"
overflow="visible" enable-background="new 0 0 35.81445 91.60449"
xml:space="preserve">
and I had alter activity.svg file by adding viewBox="150 0 70.81445
200.60449" just as presenter.svg file does, it come out properly before
resizing the figure, but it still can only show part of the figure when
resizing the figure, what is wrong with my svg file?
"dzh" <dzhpingbo@sohu.com> д
Re: urgent: the problem with resizing svg figure [message #85969 is a reply to message #85919] Sat, 16 December 2006 13:21 Go to previous messageGo to next message
----++Omea_Parts_Splitter.426322526496985
Content-Type: text/plain; charset=utf-7
Hello=20dzh,
I'm=20not=20an=20expert=20in=20SVG,=20but=20by=20comparing=2 0Activity=2esvg=20and=20present=2esvg=20I=20found=20that=20t here=20is=20no=20+ACI-width/height+AD0AIg-=20and=20+ACI-view Box+ACI-=20attributes=20specified=20in=20Activity=2esvg=20At tached=20Activity=2esvg=20works=20well=2e
Alex=20Shatalin
Content-Type: application/octet-stream; name="Activity.svg"
Content-Disposition: attachment; filename="Activity.svg"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----++Omea_Parts_Splitter.426322526496985--
Re: urgent: the problem with resizing svg figure [message #85999 is a reply to message #85969] Sat, 16 December 2006 21:22 Go to previous messageGo to next message
Thank you for your answers:)
I know it relevents to viewbox now, because I delete viewBox="0 0 35.81445
91.60449" from presenter.svg, then it come out the problem the same as my
svg file, and be normal if I added viewBox="0 0 35.81445 91.60449".
But how can I know the width and height of the svg file? which tool should I
presenter.svg:
I had tried to alter activity.svg file by adding width="70.81445 " and
height=" 200.60449" viewBox="150 0 70.81445 200.60449" just as presenter.svg
file does, it come out properly(the figure is just on the center of the box
and can fully be seen) before
resizing the figure,how can I know the width and height of the svg file?
which tool should I use to figure out the width and height of the svg file?
"Alex Shatalin" <vano@borland.com> д
Re: urgent: the problem with resizing svg figure [message #86060 is a reply to message #85999] Sun, 17 December 2006 15:11 Go to previous messageGo to next message
From the way you construct the ScalableImageFigure I understand that you'd
like to preserve the original SVG image aspect ratio, correct?
true, true);
You can try not to respect them and construct the image figure as
following:
false, true);
This will render the SVG image to occupy the entire bounds of the figure.
If you really want your image to have aspect ratio of the oeriginal image
try use latest GMF from HEAD or R1_maintanance. There used to be a bug
with the aspect ratio of the images - the original aspect ratio wasn't
respected properly. It sounds like you're experiencing this bug - after
resizing the image it becomes cut off. (Bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163123)
Hope this helps.
Alex
Re: urgent: the problem with resizing svg figure [message #86105 is a reply to message #86060] Mon, 18 December 2006 02:10 Go to previous messageGo to next message
Thank you so much:) according to your help, I succed in showing the figure
properly:)
"Alex Boyko" <aboyko@ca.ibm.com>
??????:202da8233689efe4278f6394e9261abd$1@www.eclipse.org...
> true, true);
> following:
> false, true);
> Hope this helps.
> Cheers,
> Alex
Re: urgent: the problem with resizing svg figure [message #86195 is a reply to message #86105] Mon, 18 December 2006 11:41 Go to previous message
Just want to let you know that with GMF 1.0.3 (which is out in February)
the original image aspect ratio feature is fixed, so you'll be able to use
ScalabaleImageFigure as you were using it initially.
Was glad to help.
Alex
Previous Topic:How to programmatically resize a structured edit part
Next Topic:Comparing GMF with other tools
Current Time: Fri Jul 25 14:04:33 EDT 2025
Powered by FUDForum. Page generated in 0.05103 seconds
