Home » Newcomers » Newcomers » How to get File, Export Jar to work?
How to get File, Export Jar to work? [message #85778] Tue, 12 July 2005 19:07 Go to next message
Originally posted by: ewing.discoverypartners.com
We've gotten Eclipse's "File, Export Jar" function to work OK with Eclipse
3.0.x but now I'm stumped. When I try to run the jar, Java always gives
the message "Could not find the find main class."
Using winzip to peek inside the jar, the main class certainly is in there.
The manifest.mf inside of the jar looks like this:
Manifest-Version: 1.0
Class-Path: lib\org.eclipse.core.runtime_3.1.0.jar lib\org.eclipse.jfa
ce.text_3.1.0.jar lib\org.eclipse.jface_3.1.0.jar lib\org.eclipse.osg
i_3.1.0.jar lib\org.eclipse.swt_3.1.0.jar lib\org.eclipse.text_3.1.0.
jar
Main-Class: com.companyname.test.MainWindow
The manifest input file used to generate the jar is a text file that
doesn't have the line wrap shown above. We made sure the Class-Path line
is all one line, in case that matters.
What I have done, which has been our practice for some time now, is put
the essential SWT/JFace libraries in a folder named lib, right beneath the
project folder.
Other than "go learn Ant," can anyone offer any suggestions about what's
wrong here?
Any/all clues greatly appreciated, thanks!
Re: How to get File, Export Jar to work? [message #85924 is a reply to message #85778] Wed, 13 July 2005 04:50 Go to previous message
Originally posted by: daniel.megert.gmx.net
> Eclipse 3.0.x but now I'm stumped. When I try to run the jar, Java
> always gives the message "Could not find the find main class."
> there.
> jar Main-Class: com.companyname.test.MainWindow
> line is all one line, in case that matters.
> put the essential SWT/JFace libraries in a folder named lib, right
> beneath the project folder.
> what's wrong here?
Did you create the manifest file manually or do you let the wizard
create it? Note that the manifest has a line length limitation (can't
remember the number but it is smaller than 80).
Dani
Previous Topic:How do I install Eclipse
Next Topic:Display HTML code in the Editor?
Current Time: Thu Jul 17 20:01:13 EDT 2025
Powered by FUDForum. Page generated in 0.08057 seconds
