IWAB0019E Error in getting method from Java bean. [message #85750] |
Tue, 22 March 2005 13:10  |
Originally posted by: amol.xx.xx
I am selecting a simple java bean with getXX():String method to create a
webservice.
After selecting this, a click on next and I select the web apps and click
next. at this point, instead of displaying the methods, it generates this
error:
org.eclipse.jst.ws.internal.axis.creation.ui.command.JavaToW SDLMethodCommand.execute(JavaToWSDLMethodCommand.java:95)
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.runCommand(CommandFragmentEngine.java:322)
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.visitTop(CommandFragmentEngine.java:288)
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.moveForwardToNextStop(CommandFragmentEngine.java:208)
org.eclipse.wst.command.env.ui.widgets.SimpleCommandEngineMa nager$4.run(SimpleCommandEngineManager.java:206)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:344)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:289)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 824)
FUDForum. Page generated in 0.25817 seconds
