Home » Newcomers » Newcomers » Mac OS X and Java code completion's Java Doc
Mac OS X and Java code completion's Java Doc [message #85745] Tue, 12 July 2005 15:31
Originally posted by: ccerinojr.gmail.com
Same problem different OS :). I copied over the src file from windows and
place it in
/System/Library/Frameworks/JavaVM.framework/Versions/1.4.2/H ome because
thats where eclipse said it was looking for the src.zip file. Unfortuantly
this doesnt help. The src file that I used is a Java 1.5 src and my mac
has 1.4.2. I dont think this should cause an issue. I have no clue what
else to do? With Netbeans all you have to do is add the src as a library
which is really easy. Anyone know what i am doing wrong? Oh one last thing
I also read some other places that it helps if you have xcode installed
because it is suppose to install a src file.
Previous Topic:What I need to be able to develop Servlet/JSP apps on tomcat
Next Topic:applet viewer
Current Time: Wed Jul 09 08:36:25 EDT 2025
Powered by FUDForum. Page generated in 0.08352 seconds
