problem launching the demos [message #85701] |
Thu, 01 May 2008 03:59  |
Originally posted by: rlagoue.yahoo.fr
i'm new to RAP and would like to write an application with it. But as i
tried the demos (like in the video), the application threw an exception.
Here is the complete text printed out
osgi> 30.04.2008 22:38:13 org.mortbay.http.HttpServer doStart
INFO: Version Jetty/5.1.x
30.04.2008 22:38:13 org.mortbay.util.Container start
INFO: Started org.mortbay.jetty.servlet.ServletHandler@9a9b65
INFO: Started HttpContext[/,/]
30.04.2008 22:38:13 org.mortbay.http.SocketListener start
INFO: Started SocketListener on 0.0.0.0:51850
INFO: Started org.mortbay.http.HttpServer@1d36dfe
30.04..2008 22:38:15 org.mortbay.jetty.servlet.ServletHandler handle
SCHWERWIEGEND: /rap?startup=default:
org.eclipse.rwt.internal.resources.ResourceRegistrationExcep tion: Failed
to register resource 'qx.js'.
org.eclipse.rwt.internal.resources.ResourceManagerImpl.doReg ister(ResourceManagerImpl.java:411)
org.eclipse.rwt.internal.resources.ResourceManagerImpl.regis ter(ResourceManagerImpl.java:224)
org.eclipse.ui.internal.servlet.ResourceManagerFactory$Resou rceManagerWrapper.register(ResourceManagerFactory.java:135)
org.eclipse.swt.internal.widgets.displaykit.QooxdooResources Util.register(QooxdooResourcesUtil.java:229)
org.eclipse.swt.internal.widgets.displaykit.QooxdooResources Util.registerResources(QooxdooResourcesUtil.java:141)
org.eclipse.swt.internal.widgets.displaykit.DisplayLCA.write Libraries(DisplayLCA.java:217)
org.eclipse.rwt.internal.lifecycle.DisplayUtil.writeLibrarie s(DisplayUtil.java:66)
org.eclipse.rwt.internal.service.LifeCycleServiceHandlerConf igurer.getLibraries(LifeCycleServiceHandlerConfigurer.java:2 02)
org.eclipse.rwt.internal.service.LifeCycleServiceHandlerConf igurer.getTemplateOfStartupPage(LifeCycleServiceHandlerConfi gurer.java:60)
org.eclipse.rwt.internal.service..BrowserSurvey.load(Browser Survey.java:123)
org.eclipse.rwt.internal.service.BrowserSurvey.renderScript( BrowserSurvey.java:90)
org.eclipse.rwt.internal.service.BrowserSurvey.sendBrowserSu rvey(BrowserSurvey.java:51)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.int ernalService(LifeCycleServiceHandler.java:180)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.acc ess$1(LifeCycleServiceHandler.java:168)
org.eclipse.rwt.internal..service.LifeCycleServiceHandler$Li feCycleServiceHandlerSync.doService(LifeCycleServiceHandler. java:133)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.serviceInternal(RWTLifeCycleServiceHandlerSync.java:45 )
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleServiceHandle rSync.service(RWTLifeCycleServiceHandlerSync.java:34)
org.eclipse.rwt.internal.service.LifeCycleServiceHandler.ser vice(LifeCycleServiceHandler.java:140)
org.eclipse.rwt.internal.service.ServiceManager$HandlerDispa tcher.service(ServiceManager.java:100)
org.eclipse..rwt.internal.engine.RWTDelegate.doPost(RWTDeleg ate.java:61)
org.eclipse.ui.internal.servlet.RequestHandler.service(Reque stHandler.java:52)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.handleRequest(ServletRegistration.java:90)
org.eclipse.equinox.http.servlet.internal.ProxyServlet..proc essAlias(ProxyServlet.java:111)
org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:59)
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:270)
org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:428)
org.mortbay.jetty.servlet.ServletHandler.dispatch(ServletHan dler.java:677)
org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandl er.java:568)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1530)
at org.mortbay.http.HttpContext.handle(HttpContext.java:1482)
at org.mortbay.http.HttpServer.service(HttpServer.java:909)
at org.mortbay.http.HttpConnection.service(HttpConnection.java: 820)
at org.mortbay.http.HttpConnection.handleNext(HttpConnection.ja va:986)
at org.mortbay.http.HttpConnection.handle(HttpConnection.java:8 37)
org.mortbay.http.SocketListener.handleConnection(SocketListe ner.java:245)
at org.mortbay.util.ThreadedServer.handle(ThreadedServer.java:3 57)
at org.mortbay.util.ThreadPool$PoolThread.run(ThreadPool.java:5 34)
Caused by: java.io.IOException: Access is denied
at java.io.WinNTFileSystem.createFileExclusively(Native Method)
at java.io.File.createNewFile(File.java:850)
org.eclipse.rwt.internal.resources.ResourceManagerImpl.creat eFile(ResourceManagerImpl.java:448)
org.eclipse.rwt.internal.resources..ResourceManagerImpl.doRe gister(ResourceManagerImpl.java:427)
org.eclipse.rwt.internal.resources.ResourceManagerImpl.doReg ister(ResourceManagerImpl.java:407)
... 38 more
Can somebody tell me where the problem is?
thanks
Re: problem launching the demos [message #85837 is a reply to message #85794] |
Sat, 03 May 2008 02:23  |
Originally posted by: fappel.innoopract.com
which RAP version do you use? RAP is indeed compiled against 1.4. But
your problem sounds like you are trying to run Java 5 compliant byte
code in a Java 1.4 VM, so please check if your compile and runtime
settings are fitting. Maybe the launch config uses a 1.4 VM, while your
code is compiled against Java 5 or higher.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Rodrigue [mailto:rlagoue@yahoo.fr]
Bereitgestellt: Freitag, 2. Mai 2008 16:32
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: problem launching the demos
Betreff: Re: problem launching the demos
Thanks for the help.
I solved the problem and got another exception this one:
java.lang.UnsupportedClassVersionError:
org/eclipse/rap/demo/controls/ControlsDemo (Unsupported major.minor
version 49.0)
at java.lang.ClassLoader.defineClass0(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(Def
aultClassLoader.java:165)
It seems like RAP only works with code compiled with the version 1.4*,
and throws this exception for any code compiled with the version 1.5 and
more
Is it really the case?
thanks for any help
FUDForum. Page generated in 0.06185 seconds
