| Manifest Compatibility [message #85682] |
Fri, 30 March 2007 16:26  |
We are running into an issue exporting and using gmf plug-ins listed here
org.eclipse.gmf.runtime.emf.clipboard.core_1.0.1.v20060919-0 800.jar
org.eclipse.gmf.runtime.emf.type.core_1.0.1.v20060919-0800.j ar
org.eclipse.gmf.runtime.notation_1.0.1.v20060919-0800.jar
The problem seems to be with corrupt manifest files, due to an extra
space in the manifest file, which causes Eclipse to think it has to
re-generate the manifest file and when it tries to do so it fails
because there is no plugin.xml.
Manifest file for this plug-in causing issue (notice the space between ;
and singleton):
Bundle-SymbolicName: org.eclipse.gmf.runtime.emf.clipboard.core; singl
eton:=true
Manifest file for this plugin after the issue was fixed by changing the
file (notice no space between ; and the word singleton):
Bundle-SymbolicName: org.eclipse.gmf.runtime.emf.clipboard.core;singl
eton:=true
The stack trace is as follows when the plug-ins are accessed:
!ENTRY system.bundle 4 0 2007-03-30 09:36:07.866
!MESSAGE FrameworkEvent.ERROR
!STACK 0
java.util.zip.ZipException: error in opening zip file
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(Unknown Source)
org.eclipse.osgi.framework.util.SecureAction.getZipFile(Secu reAction.java:225)
org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.basicO pen(ZipBundleFile.java:79)
org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.getZip File(ZipBundleFile.java:92)
org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.checke dOpen(ZipBundleFile.java:65)
org.eclipse.osgi.baseadaptor.bundlefile.ZipBundleFile.getEnt ry(ZipBundleFile.java:234)
at org.eclipse.osgi.baseadaptor.BaseData.getEntry(BaseData.java :96)
org.eclipse.osgi.internal.baseadaptor.AdaptorUtil.loadManife stFrom(AdaptorUtil.java:189)
org.eclipse.core.runtime.internal.adaptor.EclipseStorageHook .getGeneratedManifest(EclipseStorageHook.java:294)
org.eclipse.core.runtime.internal.adaptor.EclipseStorageHook .createCachedManifest(EclipseStorageHook.java:290)
org.eclipse.core.runtime.internal.adaptor.EclipseStorageHook .getManifest(EclipseStorageHook.java:395)
org.eclipse.osgi.internal.baseadaptor.BaseStorage.loadManife st(BaseStorage.java:255)
org.eclipse.osgi.internal.baseadaptor.BundleInstall.begin(Bu ndleInstall.java:82)
org.eclipse.osgi.framework.internal.core.Framework.installWo rkerPrivileged(Framework.java:832)
org.eclipse.osgi.framework.internal.core.Framework$2.run(Fra mework.java:748)
org.eclipse.osgi.framework.internal.core.Framework.installWo rker(Framework.java:799)
org.eclipse.osgi.framework.internal.core.Framework.installBu ndle(Framework.java:743)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.i nstallBundle(BundleContextImpl.java:221)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.installBundles(ConfigurationActivator.java:197)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start(ConfigurationActivator.java:82)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:991)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:985)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:966)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:329)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1046)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:573)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:495)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:275)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:455)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:189)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:291)
!ENTRY org.eclipse.update.configurator 2007-03-30 09:36:07.874
!MESSAGE Could not install bundle
.../../plugins/org.eclipse.gmf.runtime.emf.clipboard.core_1. 0.1.v20060919-0800.jar
Error converting plugin at
C:\maya\cache\plugins\org.eclipse.gmf.runtime.emf.clipboard. core_1.0.1.v20060919-0800.jar.
Has anyone run into this issue before?
Also, is there fix already available from GMF on this issue.
Sharanya
| Re: Manifest Compatibility [message #85724 is a reply to message #85682] |
Fri, 30 March 2007 17:08   |
Hi Sharanya,
I've not seen this before, but have submitted a fix to CVS for the 3 GMF
manifests below.
Rich
On 3/30/07 4:26 PM, in article eujrpk$h73$1@build.eclipse.org, "Sharanya
Doddapaneni" <shdoddap@cisco.com> wrote:
> and singleton):
> eton:=true
> eton:=true
> !STACK 0
> at
> at
> java:79)
> at
> .java:92)
> at
> e.java:65)
> at
> ava:234)
> at
> .java:189)
> at
> at
> at
> at
> a:255)
> at
> 2)
> at
> mework.java:832)
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> a:799)
> at
> a:743)
> at
> at
> at
> at
> Impl.java:991)
> at
> at
> Impl.java:966)
> at
> a:317)
> at
> java:329)
> at
> :1046)
> at
> at
> anager.java:495)
> at
> at
> at
> va:189)
> at
> java:291)
> ../../plugins/org.eclipse.gmf.runtime.emf.clipboard.core_1.0 .1.v20060919-0800.
> jar
> 19-0800.jar.
> Sharanya
| Re: Manifest Compatibility [message #87424 is a reply to message #85682] |
Wed, 02 May 2007 15:58  |
This is really strange. I have not been able to find that build of the
gmf bundles on the download sight. But many (maybe most) of the bundles
in the eclipse SDK have a space before the "singleton" directive. That
should not cause the issue you are seeing. You probably do not have the
bundles that failed for you anymore. But just incase you do can you
check to make sure the META-INF/MANIFEST.MF file contained in them is
using the correct case (all upper case) for the path?
Tom.
FUDForum. Page generated in 0.03702 seconds
