Home » Eclipse Projects » Equinox » Easy way to capture -debug info
Easy way to capture -debug info [message #85649] Thu, 29 March 2007 16:43 Go to next message
Originally posted by: gkarasiuk.gmail.com
Is there any easy way to capture the output from the -debug directive?
I know that I can always use something like this:
java -cp plugins\org.eclipse.equinox.launcher_1.0.0.v20070208a.jar
org.eclipse.core.launcher.Main -data \apt-radv7\local\ws -debug >debug.txt
2>&1
but this is very hard to explain to a end user. And it is also quite
fragile with the qualifier changing from build to build.
Re: Easy way to capture -debug info [message #85709 is a reply to message #85649] Fri, 30 March 2007 16:28 Go to previous messageGo to next message
Originally posted by: dj_houghton.nospam.ca.ibm.com
Currently, no. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=179860
> >debug.txt 2>&1
Re: Easy way to capture -debug info [message #85739 is a reply to message #85649] Sat, 31 March 2007 16:30 Go to previous message
> >debug.txt 2>&1
I wonder why you can't use a shell script that would do the above java
execution with appropriate redirects?
Jacek
Jacek Laskowski
http://www.JacekLaskowski.pl
Previous Topic:proper way to shutdown equinox 3.2 above?
Next Topic:PROBLEM: OSGi events not delivered to event handles if bundle is being started.
Current Time: Sun Aug 31 11:16:49 EDT 2025
Powered by FUDForum. Page generated in 0.06716 seconds
