Home » Archived » BIRT » Holy Log Spam batman
Holy Log Spam batman [message #85646] |
Mon, 31 October 2005 02:18  |
Originally posted by: pcasey.earthlink.net
I've got my reports mostly working through my app server atm; deployment
turned out to be less scary than I thought it would be. I'm getting a really
huge amount of BIRT log spam though that I was hoping somebody could help me
out with. First, how do I set birt to a log level of ERROR so I don't see
the spam? I'm drawing a blank on the appropriate logger name.
Second of all, could any brave soul take a look at the (abbreviated) run
log below and tell me if there's anything in there that I should work on
fixing? I'm concerned by the huge number of SEVERE warnings which seem to
imply some sort of deficiency in my report file. Nonetheless, the output
looks right...
INFO: Data Engine starts up
line 1 column 1 - Warning: inserting missing 'title' element
Oct 30, 2005 11:10:58 PM
org.eclipse.birt.report.engine.content.impl.MasterPageConten t
initSimpleMasterPage
INFO: The property HeaderHeight is not set. Use Default 1 cm.
INFO: The property FooterHeight is not set. Use default 1 cm.
Oct 30, 2005 11:10:58 PM org.eclipse.birt.data.engine.odaconsumer.Driver
setLogConfiguration
INFO: ODA driver does not have valid trace logging defined in the plug-in
..options or plugin.xml file.
Oct 30, 2005 11:10:59 PM
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager loadDriverExtensions
INFO: Found JDBC driverinfo extension:
driverClass=sun.jdbc.odbc.JdbcOdbcDriver, connectionFactory=null
driverClass=org.apache.derby.jdbc.EmbeddedDriver, connectionFactory=null
loadAndRegisterDriver
INFO: Loading JDBC driver class: com.mysql.jdbc.Driver
INFO: Loaded JDBC driver class in class path: com.mysql.jdbc.Driver
Oct 30, 2005 11:11:02 PM org.apache.avalon.framework.logger.Jdk14Logger info
INFO: Using org.apache.xerces.parsers.SAXParser as SAX2 Parser
Oct 30, 2005 11:11:04 PM org.apache.avalon.framework.logger.Jdk14Logger info
INFO: building formatting object tree
INFO: setting up fonts
error
SEVERE: property - "text-transform" is not implemented yet.
error
SEVERE: Error in letter-spacing property value 'normal':
org.apache.fop.fo.expr.PropertyException: No conversion defined
error
SEVERE: property - "word-spacing" is not implemented yet.
error
SEVERE: Error in column-width property value '50%':
(Repeated 50 times)
INFO: [1]
error
SEVERE: At least one of minimum, optimum, or maximum IPD must be specified
on table.
(Repeated 50 times)
INFO: Parsing of document complete, stopping renderer
Oct 30, 2005 11:11:07 PM org.eclipse.birt.data.engine.impl.DataEngineImpl
shutdown
INFO: Data engine shuts down
Re: Holy Log Spam batman [message #85766 is a reply to message #85646] |
Mon, 31 October 2005 11:21   |
Patrick,
Wenbin posted this earlier:
If you write your app using BIRT, you can set the engine log directory and
level through the following code:
EngineConfig config = new EngineConfig( );
String logDirectory = "myloggingfolder/";
config.setLogConfig( logDirectory, java.util.logging.Level.INFO );
If you use viewer, you can directly set the log folder in viewer web.xml.
By default, the log file will be writen to $BIRT viewer/logs folder.
Currently you can't control the log level. We will add this in BIRT 2.0 M3
build.
-Wenbin He
Jason Weathersby
BIRT PMC
"Patrick Casey" <pcasey@earthlink.net> wrote in message
news:dk4ggd$eb9$1@news.eclipse.org...
> deployment turned out to be less scary than I thought it would be. I'm
> getting a really huge amount of BIRT log spam though that I was hoping
> somebody could help me out with. First, how do I set birt to a log level
> of ERROR so I don't see the spam? I'm drawing a blank on the appropriate
> logger name.
> run log below and tell me if there's anything in there that I should work
> on fixing? I'm concerned by the huge number of SEVERE warnings which seem
> to imply some sort of deficiency in my report file. Nonetheless, the
> output looks right...
> setLogConfiguration
> info
> info
> info
> info
> info
> error
> error
> error
> error
> (Repeated 50 times)
> info
> INFO: [1]
> error
> on table.
> (Repeated 50 times)
> shutdown
Re: Holy Log Spam batman [message #85797 is a reply to message #85766] |
Mon, 31 October 2005 12:17  |
Thanks Jason, that cleaned up about 99% of the log results although even
with the log turned off I'm still seeing:
Maybe somebody still has a system.out.println() in the code somewhere?
Either way, I can live with 3 warns per report, it's a hundredfold better
than before I put in you suggestion.
--- Pat
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:dk5gas$okt$1@news.eclipse.org...
> Patrick,
> build.
> -Wenbin He
> Jason Weathersby
> BIRT PMC
<snip>
Current Time: Sun Jul 13 05:08:56 EDT 2025
Powered by FUDForum. Page generated in 0.04638 seconds
