Home » Archived » M2M (model-to-model transformation) » How to work with circular references?
How to work with circular references? [message #85549] Tue, 01 July 2008 08:20 Go to next message
I'm having some trouble with circular references lately. How do I cope
with the situation, that two output elements have references to the same
third element?
In one case it was like that:
Input model:
A
|-B
|-B
Mappings:
A to X
B to Y,Z
Output model:
X
|-Y--Z
|-Y-/
So that both Y-model elements have a reference to the same Z.
Is there declarative way to express that?
My only idea is to create a helper-method, which is called in Mapping B to
Y that checks if Z already exists. If Z exists, it returns it, if not, it
calls a lazy rule creating Z. Is this the way to go, or is there a better
way?
Re: How to work with circular references? [message #85614 is a reply to message #85549] Wed, 02 July 2008 03:39 Go to previous message
Ok, I could write one B to Y,Z with the precondition, that the Z does not
exists and one B to Y rule with the precondition that Z does exists and
set the reference from B to the existing Z in the body of the rule. This
is a bit lengthy, because the B to Y rule does a lot. Maybe I can use
abstract rules and inheritance to eliminate the duplicate parts of the
rules.
> Hello,
> third element?
> Input model:
> A
> |-B
> |-B
> Mappings:
> A to X
> B to Y,Z
> Output model:
> X
> |-Y--Z
> |-Y-/
> way?
Previous Topic:Set stereotype tagged value
Next Topic:EMF Changeable problem
Current Time: Sun Aug 31 14:20:44 EDT 2025
Powered by FUDForum. Page generated in 0.03310 seconds
