Home » Archived » Memory Analyzer (MAT) » MAT+DTLJ crash on reading jextract'ed DMP
MAT+DTLJ crash on reading jextract'ed DMP [message #7697] Sat, 22 November 2008 18:43
--------------090902040003000607090209
WinXP; IBM JVM:
java version "1.5.0"
Java(TM) 2 Runtime Environment, Standard Edition (build
pwi32dev-20070511 (SR5))
IBM J9 VM (build 2.3, J2RE 1.5.0 IBM J9 2.3 Windows XP x86-32
j9vmwi3223-20070426 (JIT enabled)
J9VM - 20070420_12448_lHdSMR
JIT - 20070419_1806_r8
GC - 200704_19)
JCL - 20070511
I ran my RCP; ran SendSignal; ran jextract ... so far all was well, no
errors anywhere.
In MAT+DTLJ I attempted to open the zip that had been created, and got
the error in the attached log-file. What's up?
thanks,
Paul
name="MAT+DTLJ_Crash_2.log"
Content-Disposition: inline;
filename="MAT+DTLJ_Crash_2.log"
!SESSION 2008-11-22 17:54:07.218 -----------------------------------------------
eclipse.buildId=I20070625-1500
java.fullversion=J2RE 1.5.0 IBM J9 2.3 Windows XP x86-32 j9vmwi3223-20070426 (JIT enabled)
GC - 200704_19
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.mat.ui 1 0 2008-11-22 17:55:19.906
!MESSAGE Took 22,625ms to get the DTFJ image from file C:\0-UIMA\BlueJay\eclipse_330\UDAT_RunConceptFinder_20081122 .zip
!ENTRY org.eclipse.mat.ui 2 0 2008-11-22 17:55:19.906
!MESSAGE Corrupt data reading runtimes from processes at null : No runtimes due to early startup error: The character reference must end with the ';' delimiter.
!ENTRY org.eclipse.mat.parser 4 0 2008-11-22 17:55:19.906
!MESSAGE Error opening heap dump
!SUBENTRY 1 org.eclipse.mat.parser 4 0 2008-11-22 17:55:19.906
!MESSAGE Unable to find Java runtime in DTFJ image after searching 1 address spaces (last space: com.ibm.dtfj.image.j9.ImageAddressSpace@60f860f8) 1 processes (last process: 5284)
!STACK 0
java.io.IOException: Unable to find Java runtime in DTFJ image after searching 1 address spaces (last space: com.ibm.dtfj.image.j9.ImageAddressSpace@60f860f8) 1 processes (last process: 5284)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.getRuntime(DTFJIndexBu ilder.java:2172)
at org.eclipse.mat.dtfj.DTFJIndexBuilder.fill(DTFJIndexBuilder. java:299)
at org.eclipse.mat.parser.internal.SnapshotFactoryImpl.parse(Sn apshotFactoryImpl.java:183)
at org.eclipse.mat.parser.internal.SnapshotFactoryImpl.openSnap shot(SnapshotFactoryImpl.java:101)
at org.eclipse.mat.snapshot.SnapshotFactory.openSnapshot(Snapsh otFactory.java:87)
at org.eclipse.mat.ui.snapshot.ParseHeapDumpJob.run(ParseHeapDu mpJob.java:54)
!ENTRY org.eclipse.mat.ui 4 0 2008-11-22 17:55:19.921
!MESSAGE Error opening heap dump 'UDAT_RunConceptFinder_20081122.zip'. Check log for details.
!STACK 0
org.eclipse.mat.SnapshotException: Error opening heap dump 'UDAT_RunConceptFinder_20081122.zip'. Check log for details.
at org.eclipse.mat.parser.internal.SnapshotFactoryImpl.parse(Sn apshotFactoryImpl.java:217)
--------------090902040003000607090209--
Previous Topic:can MAT use PHD? (or only HPROF?)
Next Topic:Gray part in Overview pane
Current Time: Mon Jul 14 07:03:33 EDT 2025
Powered by FUDForum. Page generated in 0.04658 seconds
