Home » Archived » Visual Editor (VE) » Trouble running VE with Eclipse 3.0.2
Trouble running VE with Eclipse 3.0.2 [message #85504] Mon, 04 April 2005 12:25 Go to next message
After determining that VE does not yet work with 3.1M6 I decided to try it
on 3.0.2. So I used the update manager to update my main eclipse and EMF
plug-ins. Then I used the update manager to get VE 1.0.1. I can create a
visual class and I can say I want it to be an SWT Application. It creates
a new class for me and opens the visual editor but the only widgets I am
able to add from the palette are Swing and AWT which as you might imaging
do not work all that well. When I run I get a blank shell window like I
would expect given I have not added any controls.
What do I need to do to get the ability to add SWT widgets to my visual
class?
I am using the following versions:
Eclipse: 3.0.2 200503110845
EMF: 2.0.1.M200409081700
GEF: 3.0 200408311615
VE: 1.0.1 200409191449
On Windows XP sp2
Ian
BTW the visual editor will allow me to add Swing frames and controls and
it generates code that compiles but has no effect when the SWT shell is
launched.
Re: Trouble running VE with Eclipse 3.0.2 [message #85523 is a reply to message #85504] Mon, 04 April 2005 13:49 Go to previous messageGo to next message
Right after I posted I found this post
< http://www.eclipse.org/newsportal/article.php?id=3165&gr oup=eclipse.tools.ve#3165>
which says they did a searched and solved their problems. So, I did a
search too and all I could find was this:
http://dev.eclipse.org/newslists/news.eclipse.tools.ve/msg01 976.html
I have done those things
- closed and reopened the Java perspective
- added the swt.jar to my project's build path before invoking the wizard
- invoked the wizard again to create a new visual class (selecting SWT
application again)
I still end up with an visual class that creates a new empty SWT shell and
presetns me woth Swing and AWT widgets only in the editor palette.
Any other advice would be appreciated.
Ian
Re: Trouble running VE with Eclipse 3.0.2 [message #85552 is a reply to message #85523] Mon, 04 April 2005 16:13 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Is there a redX on the project in the package explorer? If so, go to the
Problems View, open the customizer on it and select the unchecked
problem marker org.eclipse.ve.swt. By default this doesn't get checked.
It is probably due to not using at least 1.4.2 of Java. There is a
problem if using 1.4.1 or lower and the error marker explains this.
Rich Kulp
Re: Trouble running VE with Eclipse 3.0.2 [message #85565 is a reply to message #85552] Mon, 04 April 2005 16:14 Go to previous messageGo to next message
One more thing, step up to VE 1.0.2.2. There are several bug fixes in
there, one has to do with SWT.
Rich Kulp
Re: Trouble running VE with Eclipse 3.0.2 [message #85580 is a reply to message #85565] Tue, 05 April 2005 00:12 Go to previous messageGo to next message
Thanks for the advice - it is still a no go though. I am running Java 5
(1.5.0 02). I turned on the extra problems in the problems view and there
are no problems in my project. All I could find was VE 1.0.2.1 though.
Ian
Re: Trouble running VE with Eclipse 3.0.2 [message #85594 is a reply to message #85580] Tue, 05 April 2005 00:19 Go to previous messageGo to next message
I just retried with Java 1.4.2 06 (both for running Eclipse and as the
project JRE) with the same result. I can create a visual class but even
though I choose SWT / Shell in the wizard I do not get any SWT controls on
the pallette.
Ian
Re: Trouble running VE with Eclipse 3.0.2 [message #85623 is a reply to message #85594] Tue, 05 April 2005 09:46 Go to previous messageGo to next message
please append the .log file. There is probably some errors there.
Rich Kulp
Re: Trouble running VE with Eclipse 3.0.2 [message #85652 is a reply to message #85623] Tue, 05 April 2005 13:31 Go to previous messageGo to next message
Silly me there are errors. I also attached the contents of the
configuration window too.
Ian
BTW I do have SWT in my project's build path.
---.log---
!SESSION Apr 05, 2005 00:13:53.15
eclipse.buildId=M200409161125
java.version=1.4.2_06
!ENTRY org.eclipse.jem.proxy 2 0 Apr 05, 2005 00:13:53.15
!MESSAGE
!STACK 0
IWAV0073I *** RemoteVM Exception - Trace from Remote VM:
java.lang.UnsatisfiedLinkError: no swt-win32-3064 in java.library.path
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1517)
at java.lang.Runtime.loadLibrary0(Runtime.java:788)
at java.lang.System.loadLibrary(System.java:834)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:10 0)
at org.eclipse.swt.internal.win32.OS.<clinit>(OS.java:18)
at org.eclipse.swt.widgets.Widget.<clinit>(Widget.java:66)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:141)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionHandler.r un(ConnectionHandler.java:142)
org.eclipse.jem.internal.proxy.vm.remote.ConnectionThread.ru n(ConnectionThread.java:47)
IWAV0074I *** Local StackTrace:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanProxyP roxy:
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.createThrowableBeanProxy(REMThrowableBeanTypeProxy.java: 34)
org.eclipse.jem.internal.proxy.remote.REMThrowableBeanTypePr oxy.newBeanProxy(REMThrowableBeanTypeProxy.java:65)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.getBeanProxy(REMStandardBeanProxyFactory.java:454)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanProxyFa ctory.processErrorReturn(REMStandardBeanProxyFactory.java:50 5)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getClassReturn(REMStandardBeanTypeProxyFactory.jav a:313)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.createBeanTypeProxy(REMStandardBeanTypeProxyFactor y.java:173)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:290)
org.eclipse.jem.internal.proxy.remote.REMStandardBeanTypePro xyFactory.getBeanTypeProxy(REMStandardBeanTypeProxyFactory.j ava:237)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspect(BeaninfoClassAdapter.java:455)
org.eclipse.jem.internal.beaninfo.adapters.BeaninfoClassAdap ter.introspectIfNecessary(BeaninfoClassAdapter.java:404)
org.eclipse.jem.java.impl.JavaClassImpl.getEAnnotations(Java ClassImpl.java:344)
org.eclipse.ve.internal.cde.emf.ClassDecoratorSourceIterator .findDecorator(ClassDecoratorSourceIterator.java:37)
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.initi alize(ClassDecoratorIterator.java:47)
org.eclipse.ve.internal.cde.emf.ClassDecoratorSourceIterator . <init>(ClassDecoratorSourceIterator.java:33)
org.eclipse.ve.internal.cde.emf.ClassDecoratorFeatureAccess. getDecoratorWithFeature(ClassDecoratorFeatureAccess.java:67)
org.eclipse.ve.internal.java.codegen.java.rules.InstanceVari ableCreationRule.getDefaultBooleanValue(InstanceVariableCrea tionRule.java:70)
org.eclipse.ve.internal.java.codegen.java.rules.InstanceVari ableCreationRule.isModelled(InstanceVariableCreationRule.jav a:97)
org.eclipse.ve.internal.java.codegen.java.rules.InstanceVari ableRule.isModelled(InstanceVariableRule.java:114)
org.eclipse.ve.internal.java.codegen.java.rules.InstanceVari ableRule.ignoreVariable(InstanceVariableRule.java:46)
org.eclipse.ve.internal.java.codegen.java.TypeVisitor.visit( TypeVisitor.java:153)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.visitType(JavaBeanModelBuilder.java:446)
org.eclipse.ve.internal.java.codegen.java.JavaBeanModelBuild er.build(JavaBeanModelBuilder.java:386)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.decodeDocument(JavaSourceTranslator.java:924)
org.eclipse.ve.internal.java.codegen.core.JavaSourceTranslat or.loadModel(JavaSourceTranslator.java:658)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1567)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
!ENTRY org.eclipse.jem.beaninfo 2 0 Apr 05, 2005 00:13:53.62
!MESSAGE IWAV0155E Introspection failed on class
"org.eclipse.swt.widgets.Shell." msg="IWAV0135E
java.lang.UnsatisfiedLinkError(no swt-win32-3064 in java.library.path)."
!ENTRY org.eclipse.jem.proxy 2 0 Apr 05, 2005 00:13:53.78
!MESSAGE
!STACK 0
java.lang.NoClassDefFoundError
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.findN ext(ClassDecoratorIterator.java:76)
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.initi alize(ClassDecoratorIterator.java:49)
!ENTRY org.eclipse.jem.beaninfo 2 0 Apr 05, 2005 00:13:53.78
"org.eclipse.swt.widgets.Decorations." msg="IWAV0135E
java.lang.NoClassDefFoundError(null)."
!ENTRY org.eclipse.jem.proxy 2 0 Apr 05, 2005 00:13:53.93
!MESSAGE
!STACK 0
org.eclipse.ve.internal.cde.emf.ClassDecoratorIterator.findN ext(ClassDecoratorIterator.java:78)
!ENTRY org.eclipse.jem.beaninfo 2 0 Apr 05, 2005 00:13:53.93
"org.eclipse.swt.widgets.Canvas." msg="IWAV0135E
!MESSAGE
!STACK 0
!ENTRY org.eclipse.jem.beaninfo 2 0 Apr 05, 2005 00:13:53.109
"org.eclipse.swt.widgets.Composite." msg="IWAV0135E
!ENTRY org.eclipse.jem.proxy 2 0 Apr 05, 2005 00:13:53.109
!MESSAGE
!STACK 0
"org.eclipse.swt.widgets.Scrollable." msg="IWAV0135E
!MESSAGE
!STACK 0
!ENTRY org.eclipse.jem.beaninfo 2 0 Apr 05, 2005 00:13:53.125
"org.eclipse.swt.widgets.Control." msg="IWAV0135E
!ENTRY org.eclipse.jem.proxy 2 0 Apr 05, 2005 00:13:53.125
!MESSAGE
!STACK 0
!ENTRY org.eclipse.jem.beaninfo 2 0 Apr 05, 2005 00:13:53.140
"org.eclipse.swt.widgets.Widget." msg="IWAV0135E
---configuration---
*** Date: 4/5/05 1:26 PM
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
D:\Program Files\Eclipse30\eclipse\eclipse.exe -showsplash 600
-exitdata
D:\Program Files\Eclipse30\eclipse\eclipse.exe -exitdata fa8_4c
-data
F:\Eclipseworkspaces\LPhoto
-vm
D:\WINDOWS\system32\javaw.exe
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1112721885500
eclipse.vm=D:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-Xmx1024M
-cp
D:\Program Files\Eclipse30\eclipse\startup.jar
org.eclipse.core.launcher.Main
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=D:\Program Files\Eclipse30\eclipse\startup.jar
java.class.version=49.0
java.endorsed.dirs=D:\Program Files\Java\jre1.5.0_02\lib\endorsed
java.ext.dirs=D:\Program Files\Java\jre1.5.0_02\lib\ext
java.home=D:\Program Files\Java\jre1.5.0_02
java.io.tmpdir=D:\DOCUME~1\ileslie\LOCALS~1\Temp\
java.library.path=D:\WINDOWS\system32;.;D:\WINDOWS\system32; D:\WINDOWS;D:\WINDOWS\system32;D:\WINDOWS;D:\WINDOWS\System3 2\Wbem;D:\Program
Files\ATI Technologies\ATI Control Panel;"D:\Program Files\Symantec\Norton
Ghost
2003\" ;D:\j2sdk1.4.1_02\bin;D:\xindice-1.1b4\bin;D:\ant-1531\bin;D :\xalan-j_2_5_2\bin;D:\fop-0.20.5;D:\Program
Files\Subversion\bin;C:\WINDOWS;C:\WINDOWS\COMMAND;C:\PROGRA ~1\ATITEC~1\ATICON~1
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_02-b09
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_02
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_02-b09
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.executionenvironment=
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.2.0
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=d:\Program
Files\Eclipse30\eclipse\configuration\org.eclipse.osgi\bundl es
osgi.configuration.area=file:/d:/Program
Files/Eclipse30/eclipse/configuration/
osgi.framework=file:/d:/Program
Files/Eclipse30/eclipse/plugins/org.eclipse.osgi_3.0.1/
osgi.framework.beginningstartlevel=1
osgi.framework.version=3.0.0
osgi.frameworkClassPath=core.jar, console.jar, osgi.jar, resolver.jar,
defaultAdaptor.jar, eclipseAdaptor.jar
osgi.install.area=file:/d:/Program Files/Eclipse30/eclipse/
osgi.instance.area=file:/F:/Eclipseworkspaces/LPhoto/
osgi.logfile=F:\Eclipseworkspaces\LPhoto\.metadata\.log
osgi.manifest.cache=d:\Program
Files\Eclipse30\eclipse\configuration\org.eclipse.osgi\manif ests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=d:\Program
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=D:\Program
Files\Java\jre1.5.0_02\lib\rt.jar;D:\Program
Files\Java\jre1.5.0_02\lib\i18n.jar;D:\Program
Files\Java\jre1.5.0_02\lib\sunrsasign.jar;D:\Program
Files\Java\jre1.5.0_02\lib\jsse.jar;D:\Program
Files\Java\jre1.5.0_02\lib\jce.jar;D:\Program
Files\Java\jre1.5.0_02\lib\charsets.jar;D:\Program
Files\Java\jre1.5.0_02\classes
sun.boot.library.path=D:\Program Files\Java\jre1.5.0_02\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=D:\Program Files\Eclipse30\eclipse
user.home=D:\Documents and Settings\ileslie
user.language=en
user.name=ileslie
user.timezone=America/New_York
user.variant=
*** Features:
com.omondo.uml.free (2.0.0) "EclipseUML Free Edition "
org.eclipse.emf (2.0.1.M200409081700) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.ecore.sdo (2.0.1) "EMF Service Data Objects (SDO)"
org.eclipse.gef (3.0.1) "Graphical Editing Framework"
org.eclipse.gef.sdk (3.0.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.gef.source (3.0.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.jdt (3.0.2) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.0.2) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.0.2.1) "Java EMF Model"
org.eclipse.pde (3.0.2) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.0.2) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.0.2) "Eclipse Platform"
org.eclipse.platform.source (3.0.2) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.sdk (3.0.2) "Eclipse Project SDK"
org.eclipse.uml2 (1.0.1) "UML2"
org.eclipse.ve (1.0.2.1) "Visual Editor"
org.eclipse.xsd (2.0.1.M200409081700) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.0.0.M200409081700) "XML Schema Infoset Model (XSD)
Programmers Guide"
org.eclipse.xsd.source (2.0.1.M200409081700) "XML Schema Infoset Model
(XSD) Source"
org.tigris.subversion.book (1.1.1) "Version Control with Subversion"
org.tigris.subversion.subclipse (0.9.25) "Subclipse"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model"
com.ibm.wtp.common.util (1.0.1) "Logging Plug-in"
com.ibm.wtp.emf.workbench (1.0.1.2) "EMF Workbench"
com.omondo.uml.core (1.6.0) "Eclipse UML Plugin Core"
com.omondo.uml.free (2.0.0) "EclipseUML Free Edition"
com.omondo.uml.model (1.2.1) "Eclipse UML Plugin Open API Model"
com.omondo.uml.std (1.0.0) "EclipseUML Standard Plugin"
com.omondo.uml.std.doc.user (1.1.0) "EclipseUML Standard Plugin
Documentation"
com.omondo.xerces (2.6.2) "Xerces Based XML Parser"
org.apache.ant (1.6.2) "Apache Ant"
org.apache.batik (1.5.5) "Batik SVG Toolkit"
org.apache.lucene (1.4.3) "Apache Lucene"
org.eclipse.ant.core (3.0.0) "Ant Build Tool Core"
org.eclipse.ant.ui (3.0.2) "Ant UI"
org.eclipse.compare (3.0.0) "Compare Support"
org.eclipse.core.boot (3.0.0) "Core Boot"
org.eclipse.core.expressions (3.0.0) "Expression Language"
org.eclipse.core.filebuffers (3.0.1) "File Buffers"
org.eclipse.core.resources (3.0.1) "Core Resource Management"
org.eclipse.core.resources.win32 (3.0.0) "Core Resource Management Win32
Fragment"
org.eclipse.core.runtime (3.0.2) "Core Runtime"
org.eclipse.core.runtime.compatibility (3.0.0) "Core Runtime Plug-in
Compatibility"
org.eclipse.core.variables (3.0.0) "Core Variables"
org.eclipse.debug.core (3.0.2) "Debug Core"
org.eclipse.debug.ui (3.0.2) "Debug UI"
org.eclipse.draw2d (3.0.1) "Draw2d"
org.eclipse.draw2d.doc.isv (3.0.1) "Draw2D Documentation"
org.eclipse.emf (2.0.1.200409081700) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.codegen (2.0.1.200409081700) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.0.1.200409081700) "EMF Ecore Code
Generation"
org.eclipse.emf.codegen.ecore.ui (2.0.1.200409081700) "EMF Ecore Code
Generation UI"
org.eclipse.emf.codegen.ui (2.0.0.200409081700) "EMF Template Code
Generator UI"
org.eclipse.emf.common (2.0.1.200409081700) "EMF Common"
org.eclipse.emf.common.ui (2.0.1.200409081700) "EMF Common UI"
org.eclipse.emf.commonj.sdo (2.0.0) "CommonJ SDO"
org.eclipse.emf.ecore (2.0.1.200409081700) "EMF Ecore"
org.eclipse.emf.ecore.change (2.0.1.200409081700) "EMF Ecore Change Model"
org.eclipse.emf.ecore.change.edit (2.0.0.200409081700) "EMF Ecore Change
Edit Support"
org.eclipse.emf.ecore.edit (2.0.0.200409081700) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.0.1.200409081700) "Sample Ecore Editor"
org.eclipse.emf.ecore.sdo.edit (2.0.0) "EMF Service Data Objects (SDO)
Edit Support"
org.eclipse.emf.ecore.sdo.editor (2.0.0) "EMF Service Data Objects (SDO)
Editor"
org.eclipse.emf.ecore.xmi (2.0.1.200409081700) "EMF XMI"
org.eclipse.emf.edit (2.0.1.200409081700) "EMF Edit"
org.eclipse.emf.edit.ui (2.0.1.200409081700) "EMF Edit UI"
org.eclipse.emf.mapping (2.0.1.200409081700) "EMF Mapping"
org.eclipse.emf.mapping.ecore2ecore (2.0.1.200409081700) "Ecore to Ecore
Mapping"
org.eclipse.emf.mapping.ecore2ecore.editor (2.0.1.200409081700) "Ecore to
Ecore Mapping Editor"
org.eclipse.emf.mapping.ui (2.0.0.200409081700) "EMF Mapping UI"
org.eclipse.gef.doc.isv (3.0.1) "Graphical Editing Framework Documentation"
Resources"
org.eclipse.help (3.0.0) "Help System Core"
org.eclipse.help.appserver (3.0.0) "Help Application Server"
org.eclipse.help.base (3.0.2) "Help System Base"
org.eclipse.help.ide (3.0.0) "Help System IDE"
org.eclipse.help.ui (3.0.2) "Help System UI"
org.eclipse.help.webapp (3.0.2) "Help System Webapp"
org.eclipse.jdt.core (3.0.2) "Java Development Tools Core"
org.eclipse.jdt.debug (3.0.2) "JDI Debug Model"
org.eclipse.jdt.debug.ui (3.0.2) "JDI Debug UI"
org.eclipse.jdt.doc.isv (3.0.1) "Eclipse JDT Plug-in Developer Guide"
org.eclipse.jdt.doc.user (3.0.1) "Eclipse Java Development User Guide"
org.eclipse.jdt.junit (3.0.1) "Java Development Tools JUnit support"
org.eclipse.jdt.junit.runtime (3.0.2) "Java Development Tools JUnit
runtime support"
org.eclipse.jdt.launching (3.0.2) "Java Development Tools Launching
Support"
org.eclipse.jdt.ui (3.0.2) "Java Development Tools UI"
org.eclipse.jem (1.0.2) "Java EMF Model"
org.eclipse.jem.beaninfo (1.0.2) "Java EMF Model BeanInfo (Introspection)
Support"
org.eclipse.jem.proxy (1.0.2) "Java EMF Model Proxy Support"
org.eclipse.jem.ui (1.0.1) "Java EMF Model UI"
org.eclipse.jem.workbench (1.0.2) "Java EMF Model Workbench Support"
org.eclipse.jface (3.0.2) "JFace"
org.eclipse.jface.text (3.0.2) "JFace Text"
org.eclipse.ltk.core.refactoring (3.0.1) "Refactoring Core"
org.eclipse.ltk.ui.refactoring (3.0.1) "Refactoring UI"
org.eclipse.osgi (3.0.1) "OSGi System Bundle"
org.eclipse.osgi.services (3.0.0) "OSGi Release 3 Services"
org.eclipse.osgi.util (3.0.0) "OSGi R3 Utility Classes"
org.eclipse.pde (3.0.1) "Eclipse Plug-in Development Environment"
org.eclipse.pde.build (3.0.1) "Plug-in Development Environment Build
Support"
org.eclipse.pde.core (3.0.2) "Plug-in Development Core"
org.eclipse.pde.doc.user (3.0.0) "Eclipse Plug-in Development User Guide"
org.eclipse.pde.junit.runtime (3.0.0) "PDE JUnit Plug-in Test"
org.eclipse.pde.runtime (3.0.1) "Plug-in Development Environment Runtime"
org.eclipse.pde.ui (3.0.2) "Plug-in Development UI"
org.eclipse.platform.doc.isv (3.0.1) "Eclipse Platform Plug-in Developer
Guide"
org.eclipse.platform.doc.user (3.0.1) "Eclipse Workbench User Guide"
Resources"
org.eclipse.platform.source.win32.win32.x86 (3.0.2) "Eclipse Platform
Plug-in Developer Resources"
org.eclipse.search (3.0.1) "Search Support"
org.eclipse.swt (3.0.2) "Standard Widget Toolkit"
org.eclipse.swt.win32 (3.0.2) "Standard Widget Toolkit for Windows"
org.eclipse.team.core (3.0.0) "Team Support Core"
org.eclipse.team.cvs.core (3.0.1) "CVS Team Provider Core"
org.eclipse.team.cvs.ssh (3.0.0) "CVS SSH Core"
org.eclipse.team.cvs.ssh2 (3.0.0) "CVS SSH2"
org.eclipse.team.cvs.ui (3.0.1) "CVS Team Provider UI"
org.eclipse.team.ui (3.0.1) "Team Support UI"
org.eclipse.text (3.0.1) "Text"
org.eclipse.tomcat (4.1.30) "Tomcat Wrapper"
org.eclipse.ui (3.0.2) "Eclipse UI"
org.eclipse.ui.cheatsheets (3.0.1) "Cheat Sheets"
org.eclipse.ui.console (3.0.0) "Console"
org.eclipse.ui.editors (3.0.1) "Default Text Editor"
org.eclipse.ui.externaltools (3.0.1) "External Tools"
org.eclipse.ui.forms (3.0.0) "Eclipse Forms"
org.eclipse.ui.ide (3.0.2) "Eclipse IDE UI"
org.eclipse.ui.intro (3.0.2) "Intro Plugin"
org.eclipse.ui.presentations.r21 (3.0.1) "R21 Presentation Plug-in"
org.eclipse.ui.views (3.0.0) "Views"
org.eclipse.ui.win32 (3.0.1) "Win32 fragment"
org.eclipse.ui.workbench (3.0.2) "Workbench"
org.eclipse.ui.workbench.compatibility (3.0.0) "Workbench Compatibility"
org.eclipse.ui.workbench.texteditor (3.0.1) "Text Editor Framework"
org.eclipse.uml2.edit (1.0.1) "UML2 Edit Support"
org.eclipse.uml2.editor (1.0.1) "UML2 Editor"
org.eclipse.uml2.resources (1.0.1) "UML2 Resources"
org.eclipse.update.configurator (3.0.0) "Install/Update Configurator"
org.eclipse.update.core (3.0.2) "Install/Update Core"
org.eclipse.update.core.win32 (3.0.0) "Install/Update Core for Windows"
org.eclipse.update.scheduler (3.0.1.1) "Automatic Updates Scheduler"
org.eclipse.update.ui (3.0.1.1) "Install/Update UI"
org.eclipse.ve (1.0.1) "Visual Editor"
org.eclipse.ve.cde (1.0.2) "Visual Editor Common Data Editor"
org.eclipse.ve.doc (1.0.1) "Visual Editor User Guide"
org.eclipse.ve.java.core (1.0.2.1) "Visual Editor Java Core"
org.eclipse.ve.jfc (1.0.2) "Visual Editor for Java Foundation Classes"
org.eclipse.ve.propertysheet (1.0.1) "Visual Editor PropertySheet"
org.eclipse.ve.swt (1.0.2) "Visual Editor for Standard Widget Toolkit"
org.eclipse.xsd (2.0.1.200409081700) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.0.0.200409081700) "XML Schema Infoset Model (XSD)
Programmers Guide"
org.eclipse.xsd.edit (2.0.1.200409081700) "XML Schema Edit Framework"
org.eclipse.xsd.editor (2.0.1.200409081700) "XML Schema Editor"
(XSD) Source"
org.eclipse.xsd.test (2.0.1.200409081700) "XML Schema Infoset Model Test"
org.junit (3.8.1) "JUnit Testing Framework"
org.tigris.subversion.javahl.win32 (0.9.25) "Win32 Fragment"
org.tigris.subversion.subclipse.core (0.9.25) "SVN Team Provider Core"
org.tigris.subversion.subclipse.ui (0.9.25) "SVN Team Provider UI"
ru.novosoft.nsuml (1.4.0) "Novosoft NSUML"
*** User Preferences:
#Tue Apr 05 13:26:05 EDT 2005
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.EMFPhotos|org.eclipse.pde.core.requiredPlugins= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<classpath>\r\n<classpathentry
sourcepath\="D\:/Program
Files/Eclipse30/eclipse/plugins/org.eclipse.platform.source_ 3.0.2/src/org.eclipse.core.runtime_3.0.2/runtimesrc.zip "
kind\="lib" path\="D\:/Program
Files/Eclipse30/eclipse/plugins/org.eclipse.core.runtime_3.0 .2/runtime.jar "/>\r\n<classpathentry
Files/Eclipse30/eclipse/plugins/org.eclipse.platform.source_ 3.0.2/src/org.eclipse.osgi_3.0.1/osgisrc.zip "
Files/Eclipse30/eclipse/plugins/org.eclipse.osgi_3.0.1/osgi. jar "/>\r\n<classpathentry
Files/Eclipse30/eclipse/plugins/org.eclipse.platform.source_ 3.0.2/src/org.eclipse.osgi_3.0.1/coresrc.zip "
Files/Eclipse30/eclipse/plugins/org.eclipse.osgi_3.0.1/core. jar "/>\r\n<classpathentry
Files/Eclipse30/eclipse/plugins/org.eclipse.platform.source_ 3.0.2/src/org.eclipse.osgi_3.0.1/resolversrc.zip "
Files/Eclipse30/eclipse/plugins/org.eclipse.osgi_3.0.1/resol ver.jar "/>\r\n<classpathentry
Files/Eclipse30/eclipse/plugins/org.eclipse.platform.source_ 3.0.2/src/org.eclipse.osgi_3.0.1/defaultAdaptorsrc.zip "
Files/Eclipse30/eclipse/plugins/org.eclipse.osgi_3.0.1/defau ltAdaptor.jar "/>\r\n<classpathentry
Files/Eclipse30/eclipse/plugins/org.eclipse.platform.source_ 3.0.2/src/org.eclipse.osgi_3.0.1/eclipseAdaptorsrc.zip "
Files/Eclipse30/eclipse/plugins/org.eclipse.osgi_3.0.1/eclip seAdaptor.jar "/>\r\n<classpathentry
Files/Eclipse30/eclipse/plugins/org.eclipse.platform.source_ 3.0.2/src/org.eclipse.osgi_3.0.1/consolesrc.zip "
Files/Eclipse30/eclipse/plugins/org.eclipse.osgi_3.0.1/conso le.jar "/>\r\n<classpathentry
exported\="true" kind\="lib" path\="D\:/Program
Files/Eclipse30/eclipse/plugins/org.eclipse.emf.ecore_2.0.1. 200409081700/runtime/ecore.jar "/>\r\n<classpathentry
Files/Eclipse30/eclipse/plugins/org.eclipse.emf.common_2.0.1 .200409081700/runtime/common.jar "/>\r\n<classpathentry
Files/Eclipse30/eclipse/plugins/org.eclipse.emf.ecore.xmi_2. 0.1.200409081700/runtime/ecore.xmi.jar "/>\r\n</classpath>\r\n
@org.eclipse.debug.ui=3.0.2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.EMFPhotos.edit|org.eclipse.pde.core.requiredPlugi ns= <?xml
exported\="true" kind\="src" path\="/EMFPhotos"/>\r\n<classpathentry
Files/Eclipse30/eclipse/plugins/org.eclipse.emf.edit_2.0.1.2 00409081700/runtime/edit.jar "/>\r\n<classpathentry
Files/Eclipse30/eclipse/plugins/org.eclipse.emf.ecore_2.0.1. 200409081700/runtime/ecore.jar "/>\r\n</classpath>\r\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.Java\
Research|org.eclipse.jdt.launching.JRE_CONTAINER=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<classpath>\r\n<classpathentry kind\="lib"
path\="D\:/Program
Files/Java/j2re1.4.1_02/lib/rt.jar"/>\r\n<classpathentry kind\="lib"
path\="D\:/Program
Files/Java/j2re1.4.1_02/lib/sunrsasign.jar"/>\r\n<classpathentry
Files/Java/j2re1.4.1_02/lib/jsse.jar"/>\r\n<classpathentry kind\="lib"
path\="D\:/Program
Files/Java/j2re1.4.1_02/lib/jce.jar"/>\r\n<classpathentry kind\="lib"
path\="D\:/Program
Files/Java/j2re1.4.1_02/lib/charsets.jar"/>\r\n<classpathentry kind\="lib"
path\="D\:/Program
Files/Java/j2re1.4.1_02/lib/ext/dnsns.jar"/>\r\n<classpathentry
Files/Java/j2re1.4.1_02/lib/ext/ldapsec.jar"/>\r\n<classpathentry
Files/Java/j2re1.4.1_02/lib/ext/localedata.jar"/>\r\n<classpathentry
Files/Java/j2re1.4.1_02/lib/ext/Rational.jar"/>\r\n<classpathentry
Files/Java/j2re1.4.1_02/lib/ext/sunjce_provider.jar"/>\r\n </classpath>\r\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.formatte r.insert_space_before_opening_paren_in_constructor_declarati on=insert
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.org.eclipse.ui.examples.rcp.browser|org.eclipse.p de.core.requiredPlugins= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<classpath>\r\n</classpath>\r\n
/instance/org.eclipse.jdt.junit/org.eclipse.jdt.junit.active _filters=org.eclipse.jdt.internal.junit.runner.*,org.eclipse .jdt.internal.junit.ui.*,junit.framework.TestCase,junit.fram ework.TestResult,junit.framework.TestSuite,junit.framework.A ssert,java.lang.reflect.Method.invoke
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<templates/>
@org.eclipse.ui.ide=3.0.2
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 13,1112674394843 "
defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="0" name\="jre1.5.0_02" path\="D\:\\Program
Files\\Java\\jre1.5.0_02"/>\r\n<vm id\="1112674394843" name\="Sun 1.4.2
06" path\="D\:\\j2sdk1.4.2_06"
javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api"/>\r\n</vmType>\r\n</vmSettings>\r\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.com.lesliesoftware.xindice.emf|org.eclipse.pde.co re.requiredPlugins= <?xml
Re: Trouble running VE with Eclipse 3.0.2 [message #85667 is a reply to message #85652] Tue, 05 April 2005 13:56 Go to previous messageGo to next message
Did you add SWT through our SWT_CONTAINER, or did you just add it by
hand. It needs to be added through SWT_CONTAINER.
Is your project a standard Java Project, or is it a plugin (PDE) project?
If it is a plugin project, we do have a bug where if the Workbench
target is not the same exact instance (same file path) as the Eclipse
that is running your workspace, then swt won't work. We've fixed this
with our latest 1.1 builds of VE for working with Eclipse M5a.
Rich Kulp
Re: Trouble running VE with Eclipse 3.0.2 [message #85781 is a reply to message #85667] Tue, 05 April 2005 22:39 Go to previous messageGo to next message
Bingo! Thanks for your help.
The project is a standard Java project.
After your suggestion I realize now that the VE needs to determine what
GUI components are available based on what libraries the project has
available - that makes sense. However this is something that I do not
think is obvious. Nor is using the special way of including SWT in the
project. I have always simply added the swt.jar as an external jar.
Until today I was unaware that there were special libraries in addition to
external jars and jars. What makes a special library? Why is it special?
Why does VE not use SWT when it is available to the project?
I think the VE wizard - which offers the creation of SWT based classes -
should indicate when choosing one of the SWT options is not appropriate
for a project (when the swt.jar is not available). Further when it is
available it should be used. I made the swt.jar available in my project
and VE did not make use of it. The compiler did - I could write SWT code
by hand - but VE did not. This does not seem like a good idea - even if
there are good implementation based reasons.
Ian
Re: Trouble running VE with Eclipse 3.0.2 [message #85796 is a reply to message #85781] Wed, 06 April 2005 09:45 Go to previous messageGo to next message
The VE Wizard does add the SWT_CONTAINER for you when you select an SWT
style.
Rich Kulp
Re: Trouble running VE with Eclipse 3.0.2 [message #85821 is a reply to message #85796] Wed, 06 April 2005 16:39 Go to previous messageGo to next message
What is SWT_CONTAINTER then? I saw nothing added to my project by the VE
Wizard. What I did was add the swt.jar via the project properties using
the "Library..." button. After doing that the SWT widgets appeared on the
tool palette of my visual class editor.
Ian
Re: Trouble running VE with Eclipse 3.0.2 [message #85835 is a reply to message #85821] Wed, 06 April 2005 19:05 Go to previous message
SWT_CONTAINER is the container we use in a project (assuming it is not a
plugin project) to know we have SWT so that we can add the palette, add
the correct SWT dll when we run it, etc. The Add Library... has SWT
container there. If you selected that, that is the SWT_CONTAINER.
However, from the Visual New Class Wizard, if you selected a SWT style,
it should of added the SWT_CONTAINER for you.
> VE Wizard. What I did was add the swt.jar via the project properties
> using the "Library..." button. After doing that the SWT widgets
> appeared on the tool palette of my visual class editor.
> Ian
Rich Kulp
Re: Trouble running VE with Eclipse 3.0.2 [message #606236 is a reply to message #85504] Mon, 04 April 2005 13:49 Go to previous message
application again)
Ian
Re: Trouble running VE with Eclipse 3.0.2 [message #606241 is a reply to message #85523] Mon, 04 April 2005 16:13 Go to previous message
Rich Kulp
Re: Trouble running VE with Eclipse 3.0.2 [message #606243 is a reply to message #85552] Mon, 04 April 2005 16:14 Go to previous message
Rich Kulp
Re: Trouble running VE with Eclipse 3.0.2 [message #606246 is a reply to message #85565] Tue, 05 April 2005 00:12 Go to previous message
Ian
Re: Trouble running VE with Eclipse 3.0.2 [message #606248 is a reply to message #85580] Tue, 05 April 2005 00:19 Go to previous message
the pallette.
Ian
Re: Trouble running VE with Eclipse 3.0.2 [message #606252 is a reply to message #85594] Tue, 05 April 2005 09:46 Go to previous message
Rich Kulp
Re: Trouble running VE with Eclipse 3.0.2 [message #606254 is a reply to message #85623] Tue, 05 April 2005 13:31 Go to previous message
Ian
---.log---
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
---configuration---
win32
-ws
win32
-arch
x86
-showsplash
-exitdata
-data
-vm
-cp
eof=eof
file.separator=\
Ghost
line.separator=
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.nl=en_US
osgi.os=win32
osgi.ws=win32
path.separator=;
sun.cpu.isalist=
sun.desktop=windows
user.country=US
user.language=en
user.name=ileslie
user.variant=
*** Features:
Resources"
Resources"
Resources"
Programmers Guide"
(XSD) Source"
Documentation"
Fragment"
Compatibility"
Generation"
Generation UI"
Generator UI"
Edit Support"
Edit Support"
Editor"
Mapping"
Resources"
runtime support"
Support"
Support"
Support"
Guide"
Resources"
Programmers Guide"
(XSD) Source"
path\="D\:/Program
path\="D\:/Program
path\="D\:/Program
path\="D\:/Program
path\="D\:/Program
Re: Trouble running VE with Eclipse 3.0.2 [message #606256 is a reply to message #85652] Tue, 05 April 2005 13:56 Go to previous message
Rich Kulp
Re: Trouble running VE with Eclipse 3.0.2 [message #606275 is a reply to message #85667] Tue, 05 April 2005 22:39 Go to previous message
Ian
Re: Trouble running VE with Eclipse 3.0.2 [message #606277 is a reply to message #85781] Wed, 06 April 2005 09:45 Go to previous message
style.
Rich Kulp
Re: Trouble running VE with Eclipse 3.0.2 [message #606280 is a reply to message #85796] Wed, 06 April 2005 16:39 Go to previous message
Ian
Re: Trouble running VE with Eclipse 3.0.2 [message #606281 is a reply to message #85821] Wed, 06 April 2005 19:05 Go to previous message
> Ian
Rich Kulp
Previous Topic:Trouble creating an SWT application visual class with 3.1 M6
Next Topic:Can not enable VE in Eclipse 3.0.1
Current Time: Sun Jul 27 07:12:40 EDT 2025
Powered by FUDForum. Page generated in 0.11385 seconds
