Home » Language IDEs » ServerTools (WTP) » javax/wsdl/factory/WSDLFactory not found
javax/wsdl/factory/WSDLFactory not found [message #85418] Mon, 21 March 2005 16:03 Go to next message
Originally posted by: xxx.xxx.xxx
Environment: Eclipse M5, WTP M3, tomcat 5.0
I created a simple bean with a getXX() and tried to deploy it as a
webservice using the WebService option.
On the last pane, click on finish and I get the following error dialog:
IWAB0014E Unexpected exception occured.
java.lang.NoClassDefFoundError: javax/wsdl/factory/WSDLFactory
org.eclipse.jst.ws.internal.axis.creation.ui.task.DefaultsFo rServerJavaWSDLCommand.execute(DefaultsForServerJavaWSDLComm and.java:128)
I have all the external jars included that are required for web services.
Thanks in advance
amol
Re: javax/wsdl/factory/WSDLFactory not found [message #85467 is a reply to message #85418] Mon, 21 March 2005 18:52 Go to previous messageGo to next message
Hi Amol,
Although I'm not familiar with the specific structure of this plugin the
javax.wsdl.factory.WSDLFactory class is part of WSDL4J. I'd guess the
WSDL4J.jar this plugin requires has not been installed in the correct
location.
From the third party install page (off of the M3 download page) you need
to install WSDL4J in the following location
<wtpInstallDirectory>/eclipse/plugins/org.eclipse.wst.wsdl_1.0.0/lib/
You may also need to run Eclipse with the -clean option as in
eclipse -clean
Lawrence
> at
services.
>Thanks in advance
>amol
Re: javax/wsdl/factory/WSDLFactory not found [message #85765 is a reply to message #85467] Tue, 22 March 2005 13:11 Go to previous message
Originally posted by: amol.xx.xx
Thanks Lawrence
I just reinstalled the whole thing and it works.
Previous Topic:Bug in EJB Wizard
Next Topic:Weblogic 7.0
Current Time: Fri Jul 18 05:54:29 EDT 2025
Powered by FUDForum. Page generated in 0.03582 seconds
