Home » Archived » Test and Performance Tools Platform (TPTP) » Associating Analysis types with Data collectors
Associating Analysis types with Data collectors [message #85300] Sat, 14 October 2006 17:50 Go to next message
Originally posted by: vranganath.sbcglobal.net
In the article "Registering a Custom Data Collection Mechanism with TPTP's
Launch Configuration Framework" at eclipse.org, the analysis type is
associated with the data collector in the declaration of the collector in
plugin.xml. This reflects the declarations in
platform/org.eclipse.hyades.trace.ui/plugin.xml.
In simple words, analysis types are associated with data collectors while
declaring the data collectors. Does this mean that new analysis types
cannot to associated with existing data collectors without changing the
plugin manifest of the data collectors? If not, then how can new analysis
types be associated with existing data collectors without modifying the
waiting for reply,
Venkatesh Prasad Ranganath
e-id: venkateshprasad.ranganath@gmail.com
e-id: rvprasad@ksu.edu
web: http://www.cis.ksu.edu/~rvprasad
blog: http://venkateshthinks.blogspot.com
Re: Associating Analysis types with Data collectors [message #85434 is a reply to message #85300] Tue, 17 October 2006 10:50 Go to previous message
You can associate an analysis type with an existing data collector by using
the following extension point:
org.eclipse.hyades.trace.ui.analysisTypesAssociation
Ali Mehregani
"Venkatesh Prasad Ranganath" <vranganath@sbcglobal.net> wrote in message
news:pan.2006.10.14.21.50.49.795700@sbcglobal.net...
> waiting for reply,
Previous Topic:ClassNotFoundException - Verification hook class not found
Next Topic:AGR : using loop with DataPool
Current Time: Sat Jul 26 14:05:00 EDT 2025
Powered by FUDForum. Page generated in 0.02746 seconds
