Home » Eclipse Projects » Eclipse Platform » maybe a (very) minor bug?
maybe a (very) minor bug? [message #85297] Mon, 30 June 2003 08:37 Go to next message
Originally posted by: ran.~Qfish.com
Hi.
I start eclipse with some open project (the last one, naturally), eclipse
window title says "proj_name" - java - "filename" - Eclipse Platform.
Now, if I change my proj (closing this one and opening another), the title
stays with the OLD proj name.
Reported?
Re: maybe a (very) minor bug? [message #85611 is a reply to message #85297] Mon, 30 June 2003 12:33 Go to previous messageGo to next message
Originally posted by: rhino1.NOSPAM.sympatico.ca
"R@nsh!" <ran@~Qfish.com> wrote in message
news:bdpaud$iqn$1@rogue.oti.com...
> Hi.
I suspect that is "working as designed". I'd be a little surprised if the
developers actually bothered to refresh the project name every time you
changed it.
Rhino
Re: maybe a (very) minor bug? [message #85653 is a reply to message #85611] Mon, 30 June 2003 14:10 Go to previous messageGo to next message
Hi.
"Rhino" <rhino1@NOSPAM.sympatico.ca> wrote in message
news:bdponf$1ns$1@rogue.oti.com...
> > Hi.
eclipse
title
> changed it.
> Rhino
In that case, why bother with this in the fist place? ;o)
Re: maybe a (very) minor bug? [message #87542 is a reply to message #85297] Wed, 02 July 2003 12:19 Go to previous message
Originally posted by: John_Arthorne.oti.com_
It only shows the project name in the title area if you open a new
workbench window on that project (by selecting a project and choosing
"Open in New Window"). When you've done that, it will remain as the
input element for that window indefinitely, even if you actually start
working on a different project from within that window. If this is your
only window, you can get back to a "top level" window by choosing
"Window > New Window". So, this is working as intended.
R@nsh! wrote:
> Hi.
> Reported?
Previous Topic:plugin compatibility
Next Topic:sleak
Current Time: Sun Aug 31 17:44:16 EDT 2025
Powered by FUDForum. Page generated in 0.03224 seconds
