Home » Archived » Riena » Using Swing for ui interface
Using Swing for ui interface [message #7680] Thu, 14 August 2008 07:14 Go to next message
Am very impressed of what you guys are doing. Have trying to achieve
something similar.
I was using the Appframework as base plugin to build my app on equinox
with spring DM both on client and server for beans injection as well as
implementing remote services, which i think its quite ok.
What I find quit interesting with riena is the notion of object
transaction, build in security and so on.
My main question is, is possible to make use of this features of riena on
the backend of the client, and use for the ui Swing(big fan). I have an
already existing ui interface in swing but will like to get rid of
appframework plugin and use riena.
How should i go about it. Thanks in advance.
Re: Using Swing for ui interface [message #7701 is a reply to message #7680] Thu, 14 August 2008 07:31 Go to previous messageGo to next message
Originally posted by: ekkehard.gentz-software.de
I'm also not using all parts from Riena:
"only" ObjectTransactions and Remote Services
the ObjectRansactions are not bound to SWT - only to your objects
and you can send Deltas of Changes to the server and back
I'm a SWT / JFace fan and will use this in my RCP,
but the Riena UI doesn't fit to my needs - so I use my own UI concept
and (hopefully) some parts around the UI (Ridgets, Markers, Validation), too
ekke
Ngwa Ambe Elvis schrieb:
> something similar. I was using the Appframework as base plugin to build
> my app on equinox with spring DM both on client and server for beans
> injection as well as implementing remote services, which i think its
> quite ok. What I find quit interesting with riena is the notion of
> object transaction, build in security and so on.
> on the backend of the client, and use for the ui Swing(big fan). I have
> an already existing ui interface in swing but will like to get rid of
Re: Using Swing for ui interface [message #7720 is a reply to message #7701] Fri, 15 August 2008 03:32 Go to previous message
hi ngwa,
as ekke already said. Riena is meant to be modular so that you can use some pieces and not include others. So if you
have an existing Swing UI and like to use communication, objecttransaction,security and riena on the server, that should
work (and if it doesnt you can file a bugreport). Its meant to be modular. If you have any more specific question, let
me know.
christian
ekke schrieb:
> too
> ekke
>> build my app on equinox with spring DM both on client and server for
>> beans injection as well as implementing remote services, which i think
>> its quite ok. What I find quit interesting with riena is the notion of
>> have an already existing ui interface in swing but will like to get
>> rid of appframework plugin and use riena.
Re: Using Swing for ui interface [message #573236 is a reply to message #7680] Thu, 14 August 2008 07:31 Go to previous message
ekke
Re: Using Swing for ui interface [message #573251 is a reply to message #7701] Fri, 15 August 2008 03:32 Go to previous message
hi ngwa,
me know.
christian
ekke schrieb:
> too
> ekke
Previous Topic:Using Swing for ui interface
Next Topic:Milestone 1.0.0.M4 is coming end of august
Current Time: Fri Jul 25 23:16:10 EDT 2025
Powered by FUDForum. Page generated in 0.78181 seconds
