Home » Archived » M2M (model-to-model transformation) » [ATL] New vs Old Launch Configurations and Ganymede Missing Features
[ATL] New vs Old Launch Configurations and Ganymede Missing Features [message #85220] |
Wed, 25 June 2008 18:50  |
Originally posted by: ttonelli.uwaterloo.ca
I am quite new to ATL, but I searched the documentation and the newsgroups trying to understand these problems. I hope I
haven't miss anything and that my questions are relevant.
I am using the Ganymede Modeling Tools distribution that was out today.
First, what is the difference between the New and Old Launch Configurations in Eclipse? I saw that most examples use the
Old launcher. Should I use the new instead?
Second, when I use the new launcher and a target model file does not exist, I get a null pointer exception. Note that
the transformation keeps going and creates the file (apparently correctly). Subsequent launches don't raise the
exception (or if I create a dummy target file before the 1st launch). This happens only with the new launcher, and here
is the exception:
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.getSourceMode ls(AtlRegularVM.java:150)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:304)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:426)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:398)
at org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:42)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:764)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:614)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:880)
at org.eclipse.debug.internal.ui.DebugUIPlugin$8.run(DebugUIPlu gin.java:1083)
Also, I noticed that some features are missing in my installation, although the plugins are there (and I checked in
Eclipse's configuration details that they were loaded without errors). Specifically, I am not seeing the menu to inject
KM3 files into an Ecore model (when I click with the right button on a KM3 file), and I am not being able to use the
debugger (cannot add breakpoints nor run in debug mode). Am I missing something? Do I have to configure something to be
able to use these features?
Bests,
Thiago
Re: [ATL] New vs Old Launch Configurations and Ganymede Missing Features [message #85235 is a reply to message #85220] |
Thu, 26 June 2008 04:06   |
Thiago Tonelli Bartolomei a écrit :
The main difference is that old configurations used an old-defined id
which was incompatible with the correct plugins id... only a technical
issue.
We left the old configurations in order to allow users to migrate them
to the new ones, using the "Compatibility" menu.
> is the exception:
> java.lang.NullPointerException
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
I didn't encounter that bug... if possible, could you attach more
details about your example ? Thanks in advance.
In fact, KM3 is a GMT project which is not part of the ATL project. The
menus you mention are provided by the AM3 plugins.
The ATL debugger is quite incomplete, the add breakpoints you still must
position them in the outline.
William
Re: [ATL] New vs Old Launch Configurations and Ganymede Missing Features [message #85311 is a reply to message #85235] |
Thu, 26 June 2008 13:44   |
Hi William,
thanks for the answers. I am now being able to use the debugger. The thing is that by following the documentation it
seemed that there was a specific ATL Debug perspective, when in fact I am using the regular Debug perspective. And
thanks for pointing out that I need AM3 plugins, I had missed that.
Regarding the exception, it was actually a problem in my input model. The ATL EMF driver was throwing an exception when
it was not able to read the model, and then later the getSourceModels would fail.
It's not really a bug, but it would be nice if getSourceModels could test for the models and fail gracefully...
Thiago
William Piers wrote:
> Hello,
> issue.
>> is the exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> KM3 file),
> Best regards,
> William
Re: [ATL] New vs Old Launch Configurations and Ganymede Missing Features [message #85328 is a reply to message #85311] |
Thu, 26 June 2008 15:13  |
BTW,
in debug mode, I cannot see the variables, I don't know why...
Thiago
ps - using Ganymede Modeling Tools and JRE 1.6.0_10 on Linux
Thiago Tonelli Bartolomei wrote:
> Hi William,
> Cheers,
> Thiago
>> Hello,
>>> Hi,
>> issue.
>>> is the exception:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> KM3 file),
>> Best regards,
>> William
Current Time: Thu Jul 17 09:21:10 EDT 2025
Powered by FUDForum. Page generated in 0.31741 seconds
