Home » Language IDEs » PHP Development Tools (PDT) » How to prevent debug opening the browser?
How to prevent debug opening the browser? [message #85192] Mon, 01 December 2008 07:48 Go to next message
PDT behavior is currently extremely annoying with xdebug - i hope i am
missing something. Some setting or something.
Expected:
* (start listening for xdebug events - should happen automatically - ie.
always listening. can see some difficulties implementing that - so,
probably not possible currently)
* whenever / whatever i want to debug i tell that to my browser and the
debugger kicks in.
Actually what i get:
* launch debugger
* browser window opens with the mandatory (WHY!?) and meaningless source
file set in settings (i usually use a special file that does nothing to
prevent possibly harmful effects caused by debugger going amok)
* hit F8 to get out of it.
* close the useless browser window that got spawned
* :) here comes the expected part where i can actually use the debuger
sensibly and as needed. (when i want to debug - i tell that to browser and
the next server-event triggers the debugger)
* close debugger
* close another browser spawn.
I would VERY MUCH like to get rid of all the other bullet-points besides
the one with the smiley. Can that be done with 2.* version of PDT?
Managed to get rid of all the other (at least for me) useless spawns that
opened in eclipse itself - just can't get rid of the browser spawn and
first debug run.
Re: How to prevent debug opening the browser? [message #85222 is a reply to message #85192] Mon, 01 December 2008 16:11 Go to previous messageGo to next message
Dave Kelsey and I have recently had some discussions about this with PDT
2.0. If you look for the topic:
XDebug and Remote Session initiation (JIT) Support
That will give you an update on the state of that work. As well if you
read the second half of the thread on:
PDT / Xdebug / Multiple sub domains
you will see talk about JIT support. What you are wanting is that
functionality and not the default Eclipse debug session starting.
As to why PDT is working the way it is for the non-JIT debug setup...
Xdebug looks for a cookie within the current page request to see if it
should send debug information to the remote host. The only way for that
cookie to exist is for PDT to open up a browser with the cookie
information put into the URL so that Xdebug can set the cookie. Check
out: http://www.xdebug.org/docs/remote and look at the section on HTTP
Debug Sessions. PDT is doing its bests to handle what Xdebug requires to
get a debug session started.
One thing I could see as an improvement is that if you know you are
doing JIT debugging or if you have enabled the xdebug setting for
remote_autostart that you can setup your PDT debug to only listen and
not do the cookie initialization stuff.
Maybe Dave can provide some more insight into this.
Shawn Clark
> Expected:
> debugger kicks in.
> * launch debugger
> and the next server-event triggers the debugger)
> * close debugger
> that opened in eclipse itself - just can't get rid of the browser spawn
> and first debug run.
Re: How to prevent debug opening the browser? [message #86778 is a reply to message #85222] Sun, 14 December 2008 08:14 Go to previous messageGo to next message
That, as far as i can see, is incorrect. I use FF extension XDebug helper
for that. ie i tell trough FF when and where i want to debug - and it
works just fine. It's just the hassle with the bound-to-be-useless initial
debug session spawn (that i exit / ignore / close anyway) that i would
like to be without.
Do not know eclipse inner logic related to that, so can't really know how
or whether this can be done. Logically, there should be no problems (ie
current project + current debug config [just the config] + xdebug
connection spawned by whatever means [FF extension in this case] should be
enough).
One thing i am wondering: eclipse spawn has &KEY=<some number that looks
like time> attached. Does not show up in xdebug communication (visibly)
nor in xdebug documentation. What is it?
Re: How to prevent debug opening the browser? [message #86900 is a reply to message #86778] Tue, 16 December 2008 03:46 Go to previous messageGo to next message
Originally posted by: dkel50.hotnospmail.com
Shawn is correct what he states here. If you use PDT to launch a debug
session that launch is designed to do several things. One is to ensure
that xdebug will activate on the server and the other is to associate
the executed script on the server with that of the script you have
specified in the launch in order to do automated path mapping. In order
for all that to work, PDT invokes the URL you specify in that launch to
ensure the appopriate script is executed and to ensure xdebug activates
by specifying the cookie. This is working as designed (and this was all
designed before the FF extension was available).
It sounds to me like you want to enter the URL yourself in Firefox and
control whether the cookie is on or not via the firefox extension, and
in that case you want to use the remote session initiation/JIT support
in PDT 2.0.0. You can turn this in the PHP Debugger preferences. Now if
you use the FF extension and enable the cookie yourself, then enter the
URL, PDT should receive the xdebug initial handshake and allow you to
debug it.
Alternatively you can change PDT to use the internal browser (Under
preferences, general section) and then the launch will always put the
web page into a single eclipse view (so you won't get multiple FF tabs).
As for the reason KEY is appended to the URL. This was due to Internet
Explorer (which the internal web browser view uses on windows) caching
web pages if the URL was identical. Ie you could change your php code
but the web browser would show the cached page and not execute your
changed code. Putting a KEY value which changes on each launch forces IE
to execute the php code.
Dave Kelsey
>> that cookie to exist is for PDT to open up a browser with the cookie
>> to get a debug session started.
> helper for that. ie i tell trough FF when and where i want to debug -
> and it works just fine. It's just the hassle with the
> bound-to-be-useless initial debug session spawn (that i exit / ignore /
> close anyway) that i would like to be without.
> how or whether this can be done. Logically, there should be no problems
> (ie current project + current debug config [just the config] + xdebug
> be enough).
Re: How to prevent debug opening the browser? [message #87007 is a reply to message #86900] Wed, 17 December 2008 03:14 Go to previous messageGo to next message
> debug it.
Finally managed to find that setting (some-why didn't think that it might
be debugger specific option). Oddly enough i have used it before once, but
lost that eclipse installation and did not know i miss it. I knew there
must be a way - sort of lost hope finding it. Thanks to all involved.
Hee... should have seen that coming.
Re: How to prevent debug opening the browser? [message #665122 is a reply to message #86900] Wed, 13 April 2011 07:22 Go to previous message
Eclipse User wrote on Tue, 16 December 2008 03:46
How? where do I set that please?
under
Prefences -> General -> Web Browser
the "Use internal web browser" is greyed out
[Updated on: Wed, 13 April 2011 07:24] by Moderator
Previous Topic:configure debugger properly
Next Topic:Debugging not working correctly
Current Time: Fri Jul 18 22:48:51 EDT 2025
Powered by FUDForum. Page generated in 0.04603 seconds
