Home » Language IDEs » Java Development Tools (JDT) » Possible debugger bug..
Possible debugger bug.. [message #85186] Wed, 13 August 2003 01:14 Go to next message
Originally posted by: pawel7.astercity.net
Try this on Eclipse 2.1.1 :
(I tried on two computers with jdk 1.4.1 and 1.3.1 but it doesn't matter
anyway since this is very likely to be eclipse bug if it's one actually)
We got two .java files (compilation units) in one package.
First A contains usual public class A with main method with th name of the
file.
Second file B contains a non-public (package friendly) class Bx with the
name that is not the name of the file.
When you try to access the Bx class from A - the real-time debugger shows a
lightbulb on the left with "cannot resolve".
There's no task to fix on the tasklist and the project actually compiles and
runs well.
When you use a bit different source with the second file containing two
classes, one
with the name of the file B and another, Bx. The same lightbulb error shows,
but stuff compiles.
If you want to fix it (for the lightbulb to vanish) you gotta somehow (by a
class field or a constructor) access the class
that has the name of compilation unit (B) before the one with another (Bx).
Theoretically this is not breaking the package rules, should compile and
compiles. Why the prompt ?
here's an example:
// File A.java
package pack1.pack2;
public class A {
//B b;
Bx bx = new Bx();
// File B.java
class Bx {
Bx(){
System.out.println("that's me, bx");
//class B {}
What do you think? Is this a bug or am I wrong with some settings..
Greets
Pavel
Re: Possible debugger bug.. [message #89522 is a reply to message #85186] Wed, 27 August 2003 06:02 Go to previous message
You should avoid refering to non-public classes outside the compilation
unit.
See
http://java.sun.com/docs/books/jls/second_edition/html/packa ges.doc.html#267
83
Jerome
"Pavel" <pawel7@astercity.net> wrote in message
news:bhchd8$pq9$1@eclipse.org...
> file.
a
and
> runs well.
> classes, one
shows,
> but stuff compiles.
a
(Bx).
> here's an example:
> // File A.java
> public class A {
> //B b;
> public static void main(String[] args) {
> Bx bx = new Bx();
> // File B.java
> class Bx {
> Bx(){
> //class B {}
> Greets
> Pavel
Previous Topic:how extention mechanism works?
Next Topic:java gui/bean plugin
Current Time: Mon Jul 14 07:59:46 EDT 2025
Powered by FUDForum. Page generated in 0.07847 seconds
