VE & omondo [message #85170] |
Tue, 29 March 2005 12:03  |
I have installed eclipse 3.0.1, emf 2.0.1, gef 3.0.1 and omondo 1.1.0...
I have also installed the visual editor. I have imported the plugins of
the visual editor.
If I am trying to open it with "Class Diagramm Editor" I get the message
below. There are not created any diagramms. If I make a diagramm from my
classes, I do not get this error.
Does somebody know why I get this message?
What can I do to solve the problem ?
Thank you very much in advance
Elena
java.lang.IllegalArgumentException: Attempted to beginRule:
com.omondo.uml.g.a.a@9cf542, does not match outer scope rule:
at org.eclipse.core.internal.runtime.Assert.isLegal(Assert.java :58)
org.eclipse.core.internal.jobs.ThreadJob.illegalPush(ThreadJ ob.java:106)
at org.eclipse.core.internal.jobs.ThreadJob.push(ThreadJob.java :200)
at org.eclipse.core.internal.jobs.ImplicitJobs.begin(ImplicitJo bs.java:80)
org.eclipse.core.internal.jobs.JobManager.beginRule(JobManag er.java:170)
org.eclipse.core.internal.resources.WorkManager.checkIn(Work Manager.java:95)
org.eclipse.core.internal.resources.Workspace.prepareOperati on(Workspace.java:1628)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1668)
org.eclipse.search2.internal.ui.text.MarkerHighlighter.addHi ghlights(MarkerHighlighter.java:41)
org.eclipse.search2.internal.ui.text.EditorAnnotationManager .addAnnotations(EditorAnnotationManager.java:164)
org.eclipse.search2.internal.ui.text.EditorAnnotationManager .addAnnotations(EditorAnnotationManager.java:159)
org.eclipse.search2.internal.ui.text.EditorAnnotationManager .setSearchResult(EditorAnnotationManager.java:75)
org.eclipse.search2.internal.ui.text.WindowAnnotationManager .startHighlighting(WindowAnnotationManager.java:76)
org.eclipse.search2.internal.ui.text.WindowAnnotationManager .access$1(WindowAnnotationManager.java:69)
org.eclipse.search2.internal.ui.text.WindowAnnotationManager $1.partVisible(WindowAnnotationManager.java:59)
org.eclipse.ui.internal.PartListenerList2$7.run(PartListener List2.java:139)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.ui.internal.PartListenerList2.firePartVisible(Pa rtListenerList2.java:137)
org.eclipse.ui.internal.WWinPartService$1.partVisible(WWinPa rtService.java:43)
org.eclipse.ui.internal.WorkbenchPage$1.propertyChange(Workb enchPage.java:139)
at org.eclipse.ui.internal.LayoutPart.setVisible(LayoutPart.jav a:268)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:31 7)
org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:122)
org.eclipse.ui.internal.presentations.DefaultPartPresentatio n.selectPart(DefaultPartPresentation.java:1116)
org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:946)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:921)
at org.eclipse.ui.internal.EditorStack.setSelection(EditorStack .java:196)
org.eclipse.ui.internal.EditorStack.setVisibleEditor(EditorS tack.java:200)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:338)
org.eclipse.ui.internal.EditorAreaHelper.openEditor(EditorAr eaHelper.java:268)
at org.eclipse.ui.internal.EditorManager$4.run(EditorManager.ja va:694)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:683)
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:779)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:582)
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:570)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2244)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2177)
at org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2169)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2156)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2151)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:299)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:137)
org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:110)
at com.omondo.uml.a.a.ab.a(SourceFile:60)
at com.omondo.uml.f.c.b.a.a9.int(SourceFile:113)
at com.omondo.uml.UMLDiagramUI.a(SourceFile:226)
at com.omondo.uml.OpenClassDiagramAction.run(SourceFile:72)
org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:276)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:915)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:866)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:785)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Re: VE & omondo [message #85246 is a reply to message #85216] |
Wed, 30 March 2005 10:19  |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
VE and omondo have nothing to do with each other. VE works on the Java
code, not UML diagrams. So if you are having problems with the omondo,
you will need to go to them for support.
Rich Kulp
Re: VE & omondo [message #606198 is a reply to message #85170] |
Wed, 30 March 2005 01:46  |
a little correction: I got this error yestreday if I did "UML | Reverse
Engineering" and the beginning of the error was:
!ENTRY org.eclipse.core.runtime 4 2 Mrz 29, 2005 19:19:09.593
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
After I imported "org.eclipse.core.runtime" I did not get any error but I
also did not get diagramms created.
1. Does somebody know what are the reasons for not creation of diagramms ?
2. Are there any other tools for creating a class diagramms of VE that are
compatibel with VE ???
I have also seen "argoUML" and "Understand for Java". "Understand for
Java" creates a class diagramm only for one class.
Thanks :o)
Elena
Re: VE & omondo [message #606201 is a reply to message #85216] |
Rich Kulp
FUDForum. Page generated in 0.03422 seconds
