Home » Modeling » EMF » CDO starting but not started - how to get more logging info
CDO starting but not started - how to get more logging info [message #759304] |
Mon, 28 November 2011 10:33 |
I am trying CDO with the 4.0 latest build. I have the problem that the CDO server is starting but I can't connect. Also
the string 'CDO Server Started' is not printed in the console, giving me the idea that something goes wrong when
starting the CDO server. I can connect using telnet though and do cdo sessions repo1
See the config.xml below, the cdo server starts correctly with a previous 4.0 build.
My main question, how can I enable more logging to be printed to the console?
(I tried OMPlatform.INSTANCE.setDebugging(true), but it did not help)
Listening on port 0.0.0.0/0.0.0.0:8811 ...
CURRENT Locale: country = United Stateslanguage = English
NEW Locale: country = United Kingdomlanguage = English
!SESSION 2011-11-27 22:33:36.114 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_26
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
Framework arguments: -product com.netxforge.netxstudio.server.product --launcher.XXMaxPermSize 128M
Command-line arguments: -product com.netxforge.netxstudio.server.product -data
/home/mtaal/mydata/dev/tmobile/workspaces/tm2/../runtime-netxserver_production.product -dev
file:/home/mtaal/mydata/dev/tmobile/workspaces/tm2/.metadata/.plugins/org.eclipse.pde.core/netxserver_production.product/dev.properties
-os linux -ws gtk -arch x86 -consoleLog -clean -console 8811 --launcher.XXMaxPermSize 128M
!ENTRY org.eclipse.osgi 2 0 2011-11-27 22:33:38.620
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-11-27 22:33:38.620
!MESSAGE Bundle initial@reference:file:../svn/trunk/Client/com.netxforge.netxscript.ui/ was not resolved.
!SUBENTRY 2 com.netxforge.netxscript.ui 2 0 2011-11-27 22:33:38.620
!MESSAGE Missing required bundle org.eclipse.xtext.ui.codetemplates.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.editors_3.5.0.
!SUBENTRY 2 com.netxforge.netxscript.ui 2 0 2011-11-27 22:33:38.621
!MESSAGE Missing required bundle org.eclipse.xtext.builder_0.0.0.
!MESSAGE Missing required bundle org.eclipse.compare_0.0.0.
!MESSAGE Missing required bundle org.eclipse.xtext.ui_0.0.0.
!MESSAGE Missing required bundle org.eclipse.ui.ide_3.5.0.
!ENTRY org.eclipse.osgi 2 0 2011-11-27 22:33:38.627
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause
if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-11-27 22:33:38.627
!MESSAGE Bundle com.netxforge.netxscript.ui_1.0.0.qualifier [41] was not resolved.
!SUBENTRY 2 com.netxforge.netxscript.ui 2 0 2011-11-27 22:33:38.627
!SUBENTRY 2 com.netxforge.netxscript.ui 2 0 2011-11-27 22:33:38.628
!MESSAGE Missing optionally required bundle org.eclipse.xtext.ui.shared_0.0.0.
!MESSAGE Missing optionally required bundle org.eclipse.xtext.common.types.ui_0.0.0.
!SUBENTRY 2 com.netxforge.netxscript.ui 2 0 2011-11-27 22:33:38.629
[INFO] CDO server starting
!ENTRY org.eclipse.emf.cdo.server 1 0 2011-11-27 22:33:38.634
!MESSAGE CDO server starting
SLF4J: Class path contains multiple SLF4J bindings.
SLF4J: Found binding in [bundleresource://54.fwk1913643:9/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [bundleresource://54.fwk1913643:10/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: Found binding in [bundleresource://26.fwk1913643:3/org/slf4j/impl/StaticLoggerBinder.class]
SLF4J: See http://www.slf4j.org/codes.html#multiple_bindings for an explanation.
SLF4J: This version of SLF4J requires log4j version 1.2.12 or later. See also http://www.slf4j.org/codes.html#log4j_version
log4j:WARN No appenders could be found for logger (org.hibernate.type.BasicTypeRegistry).
log4j:WARN Please initialize the log4j system properly.
27-Nov-2011 22:33:39 org.eclipse.emf.teneo.classloader.ClassLoaderResolver setClassLoaderStrategy
INFO: Class loader strategy set to: org.eclipse.emf.teneo.classloader.ContextClassLoaderStrategy
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: CDO starting but not started - how to get more logging info [message #759325 is a reply to message #759315] |
Mon, 28 November 2011 11:33 |
Thanks, I get the same messages in a previous version of cdo, and then it started fine. In any case, my original
question (how to get more logging info), stays the same...
gr. Martin
On 11/28/2011 12:04 PM, Erdal Karaca wrote:
> It seems you are using xtext and an editor created by it that itself depends on the IDE.
> Maybe, you should get rid of the IDE dependent bundles...
The Netherlands
Re: CDO starting but not started - how to get more logging info [message #759343 is a reply to message #759330] |
Mon, 28 November 2011 12:32 |
Thanks Eike for your response. There is more logging/tracing now, but I don't see anything special. If you have a few
mins, can you take a look (see attached log)?
When I try to run a client side test, it timesout on the connection.The cpu is not showing any action, so it seems to be
a connection problem.
gr. Martin
On 11/28/2011 01:03 PM, Eike Stepper wrote:
> Am 28.11.2011 12:33, schrieb Martin Taal:
> In an Eclipse Application launch you can use the Tracing tab. In standalone
> http://wiki.eclipse.org/FAQ_for_CDO_and_Net4j#How_can_I_enable_tracing.3F should help ;-)
> Cheers
> /Eike
> http://www.esc-net.de
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
The Netherlands
Re: CDO starting but not started - how to get more logging info [message #759357 is a reply to message #759343] |
Mon, 28 November 2011 13:31 |
Am 28.11.2011 13:32, schrieb Martin Taal:
That's ~1MB of traces!
> be a connection problem.
I'm about to leave for a demo camp and tomorrow I'm on a conference in Frankfurt. Please try to skype me on Wednesday
and make sure you've TeamViewer installed ;-)
Cheers
/Eike
> gr. Martin
>> Cheers
>> /Eike
Cheers
/Eike
Re: CDO starting but not started - how to get more logging info [message #759365 is a reply to message #759357] |
Mon, 28 November 2011 13:38 |
He he, it is large indeed :-), sorry, I thought your page down/scroll button would go fast!
Have a good travel, Eike!
gr. Martin
> Cheers
> /Eike
>> gr. Martin
>>> Cheers
>>> /Eike
The Netherlands
Re: CDO starting but not started - how to get more logging info [message #759367 is a reply to message #759357] |
Mon, 28 November 2011 13:43 |
Okay the log contained all kind of unimportant things, here is one that is 100kb.
gr. Martin
> Cheers
> /Eike
>> gr. Martin
>>> Cheers
>>> /Eike
The Netherlands
Re: CDO starting but not started - how to get more logging info [message #759395 is a reply to message #759367] |
Mon, 28 November 2011 14:41 |
Some more info, I have an IElementProcessor which opens a session a jvm connector. This is done when the activated
lifecycle event has been fired. But the jvmconnection is not possible, so the system/startup stops there (waiting for
connection) and the tcp stuff is not created/initialized in cdo. Is the ElementProcessor to early in trying to connect
to the CDO Server (even with a jvm connection)?
I added an elementprocessor to initialize some things in the database when starting the cdo server.
>>> session configuration:
final IManagedContainer container = IPluginContainer.INSTANCE;
acceptor = JVMUtil.getAcceptor(container, "default");
connector = JVMUtil.getConnector(container, "default");
// Create configuration
final CDOSessionConfiguration sessionConfiguration = CDONet4jUtil
.createSessionConfiguration();
sessionConfiguration.setConnector(connector);
sessionConfiguration.setRepositoryName(REPO_NAME);
>>> element processor:
public static class ServerElementProcessor implements IElementProcessor {
public Object process(IManagedContainer container, String productGroup,
String factoryType, String description, Object element) {
if (element instanceof IRepository) {
// create all the resources at startup
final IRepository repository = (IRepository) element;
repository.addListener(new LifecycleEventAdapter() {
public void notifyLifecycleEvent(ILifecycleEvent event) {
if (event.getKind() == Kind.ACTIVATED) {
getInstance().initializeServer(repository);
return element;
> gr. Martin
>> Cheers
>> /Eike
>>> gr. Martin
>>>> Cheers
>>>> /Eike
The Netherlands
Re: CDO starting but not started - how to get more logging info [message #759551 is a reply to message #759395] |
Tue, 29 November 2011 07:06 |
Am 28.11.2011 15:41, schrieb Martin Taal:
Tomorrow I'll try your code. More feedback then...
Cheers
/Eike
> >>> element processor:
> @Override
> return element;
>> gr. Martin
>>> Cheers
>>> /Eike
>>>> gr. Martin
>>>>> Cheers
>>>>> /Eike
Cheers
/Eike
Current Time: Tue May 28 04:41:24 GMT 2024
Powered by FUDForum. Page generated in 0.04588 seconds
