Home » Language IDEs » C / C++ IDE (CDT) » Error : `abs' undeclared (first use this function)
Error : `abs' undeclared (first use this function) [message #85131] Wed, 05 November 2003 00:03 Go to next message
Originally posted by: deuff.nii.ac.jp
I get this error when I build my C++ project.
I think the builder doesn't know where math.h is. But I don't know how I can
indicate to it the location !...
Could someone help me ?
Thank you very much,
Dominique Deuff
Re: Error : `abs' undeclared (first use this function) [message #85193 is a reply to message #85131] Wed, 05 November 2003 14:29 Go to previous message
Make sure you include the header ( #include <math.h>), and assuming you are
using a Managed Make project, in the project properties click on C/C++
Build. Then in the Configuration settings select C++ Compiler / Directories
and enter the path to the directory containing math.h there.
The directories specified there are passed to the compiler as include paths
(-I). These paths are also used by the parser which will affect the outcome
of things like search and code complete.
-Andrew
"Dominique Deuff" <deuff@nii.ac.jp> wrote in message
news:boa08a$38c$1@eclipse.org...
> Hello,
can
> Dominique Deuff
Previous Topic:How to get IDs of Views
Next Topic:Decorating labels in "C/C++ Projects" View
Current Time: Mon Jul 14 11:53:42 EDT 2025
Powered by FUDForum. Page generated in 0.06628 seconds
