Home » Archived » M2M (model-to-model transformation) » ATL ignores first Enumeration Entry
ATL ignores first Enumeration Entry [message #85114] |
Tue, 24 June 2008 14:45  |
Originally posted by: helko.glathe.freenet.de
I've made an Ecore with Enumerations.
For Example:
<eClassifiers xsi:type="ecore:EEnum" name="GroupVariabilityType">
<eLiterals name="OR" value="1" literal="or"/>
<eLiterals name="XOR" value="2" literal="xor"/>
</eClassifiers>
Inside a Rule, the enumeration will be used by
fg : FM!FeatureGroup (GroupVariability <- #OR)
The false result is:
<ISPJ2008:FeatureGroup/>
Using the second enumeration entry instead
fg : FM!FeatureGroup (GroupVariability <- #XOR)
the right result is
<ISPJ2008:FeatureGroup GroupVariability="xor"/>
This is only an example. I have many enumerations and this behavior accurs
accessing all of them.
Is this a bug or am I wrong?
Regards, Helko
Re: [ATL] ATL ignores first Enumeration Entry [message #85160 is a reply to message #85145] |
Wed, 25 June 2008 06:54   |
--------------050004070008000509070905
Marcos,
Specifically EMF doesn't serialize default values. I.e., if
eIsSet(<feature>) returns false, the value for that feature won't be
serialized because of this guard in XMLSaveImpl:
protected boolean shouldSaveFeature(EObject o, EStructuralFeature f)
return o.eIsSet(f) || keepDefaults && f.getDefaultValueLiteral()
!= null;
You can set keepDefault to true with the following option such that if
the feature itself has an explicit default, the feature's value will be
serialized even if the feature isn't set:
* Keep default content ( e.g. default attributes). This applies
to saving and converting contents to DOM.
* By default the default content is discarded.
* To save the default content, set this option to
<code>Boolean.TRUE</code>.
String OPTION_KEEP_DEFAULT_CONTENT = "KEEP_DEFAULT_CONTENT";
Marcos Didonet Del Fabro wrote:
> Hello,
> In fact, the results are correct, because this is one way how EMF
> handles enumerations: it does not serialize the first one.
> Marcos.
> Helko Glathe wrote:
>> Hi
>> For Example:
>> </eClassifiers>
>> the right result is
>> accurs
>> Regards, Helko
<html>
<head>
</head>
Marcos,<br>
<br>
be serialized because of this guard in XMLSaveImpl:<br>
<blockquote> protected boolean shouldSaveFeature(EObject o,
EStructuralFeature f)<br>
{<br>
f.getDefaultValueLiteral() != null;<br>
}<br>
</blockquote>
serialized even if the feature isn't set:<br>
<blockquote><small> /**</small><br>
<small> * Keep default content ( e.g. default attributes). This
applies to saving and converting contents to DOM.</small><br>
<small> * By default the default content is discarded.</small><br>
<small> * To save the default content, set this option to
<code>Boolean.TRUE</code>.</small ><br>
<small> */</small><br>
<small> String OPTION_KEEP_DEFAULT_CONTENT = "KEEP_DEFAULT_CONTENT";</small><br>
</blockquote>
<br>
<br>
<blockquote cite="mid:g3su84$6bp$1@build.eclipse.org" type="cite">Hello,
<br>
<br>
<br>
<br>
Marcos.
<br>
<br>
Helko Glathe wrote:
<br>
<blockquote type="cite">Hi
<br>
<br>
<br>
For Example:
<br>
<br>
<br>
<br>
</eClassifiers>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
the right result is
<br>
<br>
<br>
<br>
<br>
accurs
<br>
<br>
<br>
<br>
<br>
Regards, Helko
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------050004070008000509070905--
Re: [ATL] ATL ignores first Enumeration Entry [message #85190 is a reply to message #85160] |
Wed, 25 June 2008 11:22   |
How to set keepDefault to true inside an Eclipse ATL Rule?
Regards, Helko
Ed Merks wrote:
> Marcos,
> != null;
>> Hello,
>> Marcos.
>> Helko Glathe wrote:
>>> Hi
>>> For Example:
>>> </eClassifiers>
>>> the right result is
>>> accurs
>>> Regards, Helko
Re: [ATL] ATL ignores first Enumeration Entry [message #85265 is a reply to message #85190] |
Thu, 26 June 2008 08:51  |
Hi Helko,
The keepDefault option is not yet supported by ATL.
I recommend you to use Eclipse Bugzilla in order to add this feature
request.
Brahim.
> Regards, Helko
> Ed Merks wrote:
>> Marcos,
>> != null;
>>> Hello,
>>> Marcos.
>>> Helko Glathe wrote:
>>>> Hi
>>>> For Example:
>>>> </eClassifiers>
>>>> the right result is
>>>> accurs
>>>> Regards, Helko
Current Time: Fri Jul 25 22:04:28 EDT 2025
Powered by FUDForum. Page generated in 0.27051 seconds
