Home » Archived » BIRT » How to render a chart (standalone)?
How to render a chart (standalone)? [message #85108] Thu, 27 October 2005 22:53 Go to next message
Originally posted by: none.none.none
I'm trying to use BIRT charting independent of a report. So, for example, I
have a web application that will generate a chart and render it to a PNG
image. Once I have the org.eclipse.birt.chart.model.Chart object, what do I
do?? I can't seem to even come close to figuring out how to turn this into
a viewable image.
Any ideas?
Thanks!
Re: How to render a chart (standalone)? [message #85141 is a reply to message #85108] Fri, 28 October 2005 04:11 Go to previous messageGo to next message
Please check the existing chart engine API:
http://www.eclipse.org/birt/wiki/index.php?n=BPS.BPS39
David
"chris" <none@none.none> wrote in message
news:djs3qr$mvl$1@news.eclipse.org...
> Hello,
> I have a web application that will generate a chart and render it to a PNG
> I do?? I can't seem to even come close to figuring out how to turn this
> into a viewable image.
> Any ideas?
> Thanks!
Re: How to render a chart (standalone)? [message #85327 is a reply to message #85141] Fri, 28 October 2005 12:05 Go to previous messageGo to next message
Thanks David. I had actually not located that document. However, it looks
very similar to the examples given in the FAQ. Both of which show how to
render an image to a Swing or SWT device. I'm not familiar with either one
of those other than I believe you would only do that if you wanted to render
the chart in a desktop app. I need to render it to web/HTML client. I
still haven't seen anything about how to render it to a common image format
such as PNG, JPG, etc.
What am I missing?
"David Michonneau" <dmichonneau@actuate.com> wrote in message
news:djsmgb$aaj$1@news.eclipse.org...
> David
Re: How to render a chart (standalone)? [message #85366 is a reply to message #85327] Fri, 28 October 2005 12:44 Go to previous messageGo to next message
Actually, after a bit more searching I came across another useful document.
I haven't tested it out yet, but it looks like it has what I need here (so
far the most comprehensive doc I've seen on the chart engine)... It's a
little confusing because it's a FAQ Word document which I just assumed was
the same as the FAQ web page... but it's not.
Anyway, for those interested, it is located here:
http://eclipse.org/birt/faq/Charts_FAQ.doc
The relevant code I was looking for below....
IDeviceRenderer idr = null;
try {
idr = ps.getDevice("dv.PNG");
} catch (PluginException pex)
DefaultLoggerImpl.instance().log(pex);
// DEFINE THE BOUNDS AND CONVERT INTO POINTS
Bounds bo = BoundsImpl.create(0, 0, 800, 600); // IN PIXELS
bo.scale(72d/idr.getDisplayServer().getDpiResolution()); // CONVERTED TO
POINTS
// BUILD THE RENDERED CHART STRUCTURE
Generator gr = Generator.instance();
GeneratedChartState gcs = null;
try {
gcs = gr.build(
idr.getDisplayServer(),
cm, null,
bo, null
} catch (GenerationException gex)
DefaultLoggerImpl.instance().log(gex);
System.exit(0);
// RENDER THE CHART TO A PNG FILE
Image img = new BufferedImage(
(int) bo.getWidth(), (int) bo.getHeight(), BufferedImage.TYPE_INT_ARGB
idr.setProperty(IDeviceRenderer.FILE_IDENTIFIER, "chart.png");
try {
gr.render(idr, gcs);
} catch (RenderingException rex)
DefaultLoggerImpl.instance().log(rex);
news:djti7j$hgg$1@news.eclipse.org...
> looks very similar to the examples given in the FAQ. Both of which show
> how to render an image to a Swing or SWT device. I'm not familiar with
> either one of those other than I believe you would only do that if you
> wanted to render the chart in a desktop app. I need to render it to
> web/HTML client. I still haven't seen anything about how to render it to
> a common image format such as PNG, JPG, etc.
> What am I missing?
Re: How to render a chart (standalone)? [message #85388 is a reply to message #85327] Fri, 28 October 2005 12:47 Go to previous messageGo to next message
Hi Chris,
Rendering in PNG or JPG is quite easy, simply use a PNG device renderer.
Then set the file path on the renderer:
File fChartImage = File.createTempFile( "chart.png");
IDeviceRenderer idr = PluginSettings.instance( ).getDevice( "dv.PNG" );
idr.setProperty( IDeviceRenderer.FILE_IDENTIFIER, fChartImage.getPath( ));
The file will be rendered at the specified path.
You can use all these device renderers, and even implement new ones if you
like:
dv.SWING
dv.SWT
dv.SVG
Hope this helps,
David
> What am I missing?
>> Thanks,
>> David
Re: How to render a chart (standalone)? [message #85400 is a reply to message #85388] Fri, 28 October 2005 12:54 Go to previous messageGo to next message
Looks like we were both responding at the same time, when I had found that
other doc. You're right, it does look easy now ;) Thanks a bunch for your
help.
news:djtkno$l0q$1@news.eclipse.org...
> Hi Chris,
> like:
> dv.SWING
> dv.SWT
> dv.SVG
> Hope this helps,
> David
Re: How to render a chart (standalone)? [message #85460 is a reply to message #85108] Fri, 28 October 2005 15:29 Go to previous messageGo to next message
Sorry to keep dragging this thing out, I'm closer, but still not quite
there. So I've gotten over the hurdle of understanding, in general, how to
render an image through code. However, I think I'm still having a problem
with the 'standalone' part.
So here's how I'm trying to run this.. My IDE is Eclipse 3.1 using the
Tomcat plugin. I'm trying to generate a simple chart (createLineChart()
taken from samples) into a PNG. I am currently on 2.0 M1, but I also
initially tried the 1.0.1 standalone charting download. The code to
generate the chart and render it is in a servlet.
I've taken the brute-force approach to try to get this thing working. So,
in my web-inf directory (where I point BIRT_HOME), I have a plugins
directory with ALL of the Birt 2.0 plugins in there. In my Eclipse
build-path to get the servlet to compile, I have the following libs...
birt.core
device.extension
chart.engine
When running the code (at the bottom of this message) as-is, I get the
following error which occurs on the gr.build() call:
Oct 28, 2005 1:05:49 PM org.eclipse.birt.chart.log.impl.JavaUtilLoggerImpl
log
SEVERE: Exception
org.eclipse.birt.chart.exception.ChartException: $NO-RB$
org.eclipse.birt.chart.render.Line
org.eclipse.birt.chart.util.PluginSettings.newInstance(Plugi nSettings.java:595)
org.eclipse.birt.chart.util.PluginSettings.getRenderer(Plugi nSettings.java:306)
org.eclipse.birt.chart.render.BaseRenderer.instances(BaseRen derer.java:1537)
at org.eclipse.birt.chart.factory.Generator.build(Generator.jav a:239)
If I remove the "STANDALONE" property, then I get this error:
java.lang.VerifyError: Cannot inherit from final class
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
org.eclipse.birt.core.framework.server.PluginClassLoader.fin dLocalClass(PluginClassLoader.java:116)
org.eclipse.birt.core.framework.server.PluginClassLoader.fin dClass(PluginClassLoader.java:36)
org.eclipse.birt.core.framework.server.PluginClassLoader.loa dExportedClass(PluginClassLoader.java:98)
org.eclipse.birt.core.framework.server.PluginClassLoader.doL oadImportClass(PluginClassLoader.java:84)
org.eclipse.birt.core.framework.server.PluginClassLoader.loa dImportedClass(PluginClassLoader.java:54)
org.eclipse.birt.core.framework.server.PluginClassLoader.fin dClass(PluginClassLoader.java:30)
Code:
System.setProperty("STANDALONE", "true");
System.setProperty("BIRT_HOME",
"C:\\EclipseWorkspace\\Test\\web\\WEB-INF");
Chart chart = createLineChart();
PluginSettings ps = PluginSettings.instance();
try
} catch (ChartException e)
logger.error(e.getMessage(), e);
bo.scale(72d / idr.getDisplayServer().getDpiResolution()); // CONVERTED
// TO
// POINTS
try
gcs = gr.build(idr.getDisplayServer(), chart, null, bo, null);
If I remove the STANDALONE and BIRT_HOME properties, then it says something
about not being able to find a plugins.xml and dv.PNG.
Any ideas?
Re: How to render a chart (standalone)? [message #85695 is a reply to message #85460] Mon, 31 October 2005 08:22 Go to previous messageGo to next message
If you remove STANDALONE, you need to specify BIRT_HOME for the path to your
plugins parent directory.
For the exception, can you try to enable tracing on the chart engine plugin,
and see what exactly is the exception about in the log?
David
news:djtu7b$248$1@news.eclipse.org...
> to render an image through code. However, I think I'm still having a
> problem with the 'standalone' part.
> birt.core
> device.extension
> chart.engine
> log
> SEVERE: Exception
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at
> at
> Code:
> try
> // TO
> // POINTS
> try
> something about not being able to find a plugins.xml and dv.PNG.
> Any ideas?
> Thanks
Re: How to render a chart (standalone)? [message #87234 is a reply to message #85695] Thu, 03 November 2005 15:15 Go to previous message
Magically started working after upgrading to M2.
news:dk55r1$8mp$1@news.eclipse.org...
> your plugins parent directory.
> plugin, and see what exactly is the exception about in the log?
> David
Previous Topic:t
Next Topic:trim in select statement
Current Time: Tue Jul 15 10:44:51 EDT 2025
Powered by FUDForum. Page generated in 0.11345 seconds
