Home » Language IDEs » C / C++ IDE (CDT) » Debugger does not work
Debugger does not work [message #84980] Mon, 03 November 2003 08:49 Go to next message
Originally posted by: p1buehle.hsr.ch
Hello everyone
I installed the CDT Plugin, Version cdt-full-1.2-win32.zip
which I use on Eclipse 2.1.1, W2K installation.
Additionally I installed MinGW-3.1.0-1.exe which comes with a gdb Version
5.2.1, which should be ok.
Building und running C/C++ projects works fine,
(make, gcc and g++ are ok)
but I am not able to debug my application.
When starting debuggung I receive the error message:
Exception occoured during launch
Failed launching CDI Debugger: Error creating session: Target is not
responding (timed out)
When typing gdb -version in a console, the program is found on the
Harddisk. (Path should be ok)
Any idea where I could fix the problem?
Peter Bühler
Re: Debugger does not work [message #85059 is a reply to message #84980] Tue, 04 November 2003 08:02 Go to previous messageGo to next message
Peter Bühler wrote:
> Hello everyone
> Regards
> Peter Bühler
I solved the problem myself -> my installation of w2k is currupt. On a
different computer gdb worked without causing troubles.
Re: Debugger does not work [message #86709 is a reply to message #85059] Sat, 22 November 2003 14:49 Go to previous messageGo to next message
I'm getting the same error, on two different Windows XP machines, one of
which is a clean install as of a week ago. So I don't think the problem
is the operating system. However, I only get it on some projects. If I
make a simple hello world project as in the tutorial, the debugger works
fine.
I'm new to CDT, any suggestions of where to look in terms of logs or
traces or settings? I assume since it works on some projects, the basic
setup is okay.
Andrew McKinlay
http://www.suneido.com
Re: Debugger does not work [message #86722 is a reply to message #86709] Sat, 22 November 2003 15:10 Go to previous messageGo to next message
Andrew McKinlay wrote:
>>> Building und running C/C++ projects works fine, (make, gcc and g++
>>> are ok)
> fine.
> setup is okay.
> Andrew McKinlay
After that last message, I guess I'd better provide more info!
OS: Windows XP
Eclipse Version: 2.1.2 (updated from 2.1.1 via update site)
Eclipse Path: c:/eclipse
CDT Version: 1.2.0 (installed from update site)
MinGW Version: 3.1.0 (GDB 5.2.1)
MinGW Path: c:/mingw310
Project Path: c:/dev/interp
I've also tried creating the same project under c:/eclipse, but same
results. I can debug it from the command line with gdb.
andrew
Re: Debugger does not work [message #87002 is a reply to message #86722] Mon, 24 November 2003 05:17 Go to previous messageGo to next message
> >>> are ok)
> > fine.
> > setup is okay.
> > Andrew McKinlay
> OS: Windows XP
> andrew
I have same problem, but can't debug any programs, included HelloWorld.
My installation detalis are:
OS: SunOS 5.8
Eclipse Path: ~/eclipse
GNU Versions: gcc 3.3, gdb 5.0 y make 3.80
Thanks.
Raúl
Re: Debugger does not work [message #87062 is a reply to message #87002] Mon, 24 November 2003 07:38 Go to previous messageGo to next message
Wasn't there a requirement of gdb 5.2.1 and higher?
>>>>>are ok)
>>>fine.
>>>setup is okay.
>>>Andrew McKinlay
>>OS: Windows XP
>>andrew
> OS: SunOS 5.8
> Thanks.
> Raúl
Re: Debugger does not work [message #87161 is a reply to message #87062] Mon, 24 November 2003 08:43 Go to previous messageGo to next message
Thank you,
I have instaled gdb 5.3, and the problem is solved.
Raúl.
> >>>>>are ok)
> >>>fine.
> >>>setup is okay.
> >>>Andrew McKinlay
> >>OS: Windows XP
> >>andrew
> > OS: SunOS 5.8
> > Thanks.
> > Raúl
Re: Debugger does not work [message #87315 is a reply to message #87161] Mon, 24 November 2003 14:28 Go to previous messageGo to next message
Unfortunately, I have 5.2.1 as per requirements, and I still have the
problem.
andrew
Raúl Remedios wrote:
> Thank you,
> Raúl.
>>>>>>>are ok)
>>>>>fine.
>>>>>setup is okay.
>>>>>Andrew McKinlay
>>>>OS: Windows XP
>>>>andrew
>>>OS: SunOS 5.8
>>>Thanks.
>>>Raúl
Re: Debugger does not work [message #87346 is a reply to message #87315] Mon, 24 November 2003 16:11 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
How big are the projects that are timed out? For very large projects it
takes a long time for gdb to load the symbol information. In this case you
need to insrease the timeout value.
"Andrew McKinlay" <mckinlay@suneido.com> wrote in message
news:bptm06$8ng$1@eclipse.org...
> problem.
> andrew
> Ra
Re: Debugger does not work [message #87361 is a reply to message #87346] Mon, 24 November 2003 18:33 Go to previous messageGo to next message
I don't think that's it - this is a very small ~50 line test program. If
I start gdb on it manually it loads almost instantly.
>>problem.
>>andrew
>>>Thank you,
>>>Raúl.
>>>>>>>>>are ok)
> not
> a
> of
> problem
> I
> works
>>>>>>>fine.
> basic
>>>>>>>setup is okay.
>>>>>>>Andrew McKinlay
>>>>>>OS: Windows XP
>>>>>>andrew
>>>>>OS: SunOS 5.8
>>>>>Thanks.
>>>>>Raúl
Re: Debugger does not work [message #98102 is a reply to message #87361] Mon, 29 March 2004 15:39 Go to previous message
Originally posted by: juergen.berchtel.students.fh-vorarlberg.ac.at
I have also the same problem with C++ development.
But I can debug a C program without a problem.
WinXP
Eclipse Version: 2.1.3
CDT Version: 1.2.1
"Andrew McKinlay" <mckinlay@suneido.com> schrieb im Newsbeitrag
news:bpu4c4$pha$1@eclipse.org...
you
> >>problem.
> >>andrew
> >>Ra
Previous Topic:CDT 2.0M7 isn't working with M8
Next Topic:CDT2.0 M8
Current Time: Sun Aug 31 03:54:19 EDT 2025
Powered by FUDForum. Page generated in 0.04187 seconds
