Home » Archived » M2M (model-to-model transformation) » [ATL] Running ATL from the command line
[ATL] Running ATL from the command line [message #84970] Mon, 23 June 2008 11:23 Go to next message
Originally posted by: jmcq.cs.nuim.ie
Does anyone know of any documentation or examples for running ATL from
the command line? Thanks.
Jacqui
Re: [ATL] Running ATL from the command line [message #84985 is a reply to message #84970] Mon, 23 June 2008 12:22 Go to previous messageGo to next message
--------------010508090702090600050705
Hi Jacqui,
The following link may help you:
http://wiki.eclipse.org/ATL_Howtos#How_do_I_launch_transform ations_programmatically.3F
HTH
Freddy.
Jacqui a
Re: [ATL] Running ATL from the command line [message #84995 is a reply to message #84985] Mon, 23 June 2008 12:35 Go to previous message
Thanks! I've just found that myself and have downloaded Dennis
Wagelaar's ATL command line tool. Has anyone else used this? I'm
particularly interested to know what version of ATL, EMF etc it is
compatible with - I'm presuming Eclipse 3.2.2 and therefore equivalent
ATL and EMF versions. Does this imply it will work with later versions
of Eclipse/ATL? If not is there somewhere I can access a version of ATL
(including source code) for Eclipse 3.2.2 for Linux?
Thanks in advance,
Jacqui
Freddy Allilaire wrote:
> Hi Jacqui,
> HTH
> Freddy.
> Jacqui a écrit :
>> Jacqui
Previous Topic:[ATL] java.lang.ClassCastException while running transformation
Next Topic:[ATL] EFloat attribute assignment
Current Time: Mon Jul 14 12:23:14 EDT 2025
Powered by FUDForum. Page generated in 0.04620 seconds
