Home » Archived » BIRT » Pojo's and a scripted subreport
Pojo's and a scripted subreport [message #84940] Thu, 27 October 2005 15:39 Go to next message
I am trying to create a sub-report using a scripted data source. I am having
trouble understanding how I should write the scripts of my sub-report so
that the data in my sub-report relates to the parent report.
I am getting my scripted POJO but when I generate the report, I'm getting
the same sub-report data with each parent entry.
I am currently creating a table for the parent report with two detail lines.
In the second detail line I create a second table for my sub-report. For
sake of example and to keep it simple, lets say my POJO looks like this:
public class Pojo {
private String company ;
private Set employees ;
public String getCompany() {
return company ;
public Set getEmployees() {
return employees;
I have two data sets, scriptSet1 and scriptSet2. The parent report Table is
tied to scriptSet1 and the sub-report is tied to scriptSet2. In scriptSet1 I
have defined scripts for open and fetch.
The open looks like this:
df = new Packages.my.package.com.DataFactory();
pojoSet = df.getPojoSet() ;
i = pojoSet.iterator();
The fetch looks like this:
if ( !i.hasNext() ){
return false ;
var pojo = i.next();
row["Company"] = pojo.getCompany() ;
j = pojo.getEmployees().iterator() ; // I have tried this in the open of
scriptSet2 but have the same result.
return true ;
My scriptSet2 has a fetch statement that looks as follows:
if ( !j.hasNext() ){
return false ;
employee = j.next();
row["Name"] = employee.getName() ;
return true ;
When executing this report, I will get the employees for my last Company
printed for all companies. I am assuming I've overlooked some basic concept.
Any suggestions would be appreciated.
Re: Pojo's and a scripted subreport [message #84988 is a reply to message #84940] Thu, 27 October 2005 16:47 Go to previous messageGo to next message
Tom,
When you put
in the data set 2 open, did you make pojo global?
pojo = i.next();
in dataset 1?
This looks like it should work.
Jason Weathersby
BIRT PMC
"Tom Stave" <tstave@bmtcarhaul.com> wrote in message
news:djraau$q97$1@news.eclipse.org...
>having
> lines.
> public class Pojo {
> return company ;
> return employees;
> is
> I
> return false ;
> return true ;
> return false ;
> return true ;
> concept.
> Thanks
Re: Pojo's and a scripted subreport [message #85003 is a reply to message #84988] Thu, 27 October 2005 17:09 Go to previous messageGo to next message
That did the trick -- Thanks
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:djreca$vqt$1@news.eclipse.org...
> Tom,
> When you put
> pojo = i.next();
> in dataset 1?
> Jason Weathersby
> BIRT PMC
> >having
getting
> > lines.
> > public class Pojo {
> > return company ;
> > return employees;
> > is
scriptSet1
> > I
> > return false ;
> > return true ;
> > return false ;
> > return true ;
> > concept.
> > Thanks
Re: Pojo's and a scripted subreport [message #85187 is a reply to message #85003] Fri, 28 October 2005 08:25 Go to previous messageGo to next message
In my haste to leave work yesterday, I should have looked at my data closer.
I still have the same problem.
I've ran several test on my POJO access and the data appears to returning
correctly, however, I am still getting the same sub-report data for each
main report item.
news:djrfjp$1na$1@news.eclipse.org...
> > Tom,
> > When you put
> > pojo = i.next();
> > in dataset 1?
> > Jason Weathersby
> > BIRT PMC
> > >having
so
> getting
> > > lines.
For
this:
> > > public class Pojo {
> > > return company ;
> > > return employees;
Table
> > > is
> scriptSet1
> > > I
> > > return false ;
of
> > > return true ;
> > > return false ;
> > > return true ;
Company
> > > concept.
> > > Thanks
Re: Pojo's and a scripted subreport [message #85230 is a reply to message #85187] Fri, 28 October 2005 09:23 Go to previous messageGo to next message
I also got the same behavior with the same implementation (2 scripted data
sets, nested tables...). What's the problem? Is this a bug or we are
missing something? This is very urgent and important to me because we want
to use BIRT in a production system. If we fail to address this, we cannot
built the prototype...
Re: Pojo's and a scripted subreport [message #85310 is a reply to message #84940] Fri, 28 October 2005 11:39 Go to previous messageGo to next message
Tom,
I did a little more digging on this one.
This isssue is that Data Set1 gets read completely before doing Data Set 2.
So this line j = pojo.getEmployees().iterator() will alway return the last
one.
What would be ideal to do is have a method in the pojo that accepts the
company name as a parameter and returns a Set. Then in the outer table in
one of the data controls set its value to something like this in the
expression builder for a data control.
tmptest = row["companyname"];
row["companyname"];
This will display the company name and set the tmptest variable to the
company name.
Then in the open method of Data Set 2 make your call like.
j = pojo.getEmplyforCompany(tmptest).iterator();
I am attaching an example that does something similar with two scripted ds.
Look at open and fetch on both DS. Also look at the Expression builder for
the data control under OuterCount.
Hope this helps
Jason Weathersby
BIRT PMC
>having
> lines.
> public class Pojo {
> return company ;
> return employees;
> is
> I
> return false ;
> return true ;
> return false ;
> return true ;
> concept.
> Thanks
Re: Pojo's and a scripted subreport [message #85415 is a reply to message #85310] Fri, 28 October 2005 13:30 Go to previous message
Thanks Jason!
Using a variation of your comments and my earlier example I came up with the
following which seems to work.
I created a new output variable in my scriptSet1 of type ANY and named
"StoreSet". I only use it for storage, I won't display it.
I kept my open for scriptSet1 the same, but I added the following to the
fetch statement:
row["StoreSet"] = pojo.getEmployees() ;
So the fetch looks like this:
return false ;
return true ;
When displaying my company name, using expression builder I added the
following:
empSet = row["StoreSet"];
row["companyname"];
My scriptSet2 fetch remains the same, but the open looks like this:
j=empSet.iterator() ;
This appears to work. But if I've thought that before. So if you see
anything I missed please let me know. If not, I hope this helps someone
else.
Thanks again.
news:djtgmh$fen$1@news.eclipse.org...
> Tom,
2.
last
> one.
> row["companyname"];
> company name.
ds.
for
> Hope this helps
> Jason Weathersby
> BIRT PMC
> >having
getting
> > lines.
> > public class Pojo {
> > return company ;
> > return employees;
> > is
scriptSet1
> > I
> > return false ;
> > return true ;
> > return false ;
> > return true ;
> > concept.
> > Thanks
Previous Topic:Chart: What are extended properties?
Next Topic:How to calculate a runningSum?
Current Time: Thu Jul 17 20:29:53 EDT 2025
Powered by FUDForum. Page generated in 0.08856 seconds
