Home » Archived » Test and Performance Tools Platform (TPTP) » Unable to complete auto recording
Unable to complete auto recording [message #84937] Fri, 06 October 2006 02:51 Go to next message
Originally posted by: oklym.meta.ua
Hi guys,
I'm running Eclipse 3.2 under FedoraCore 5 with installed TPTP 4.2
As novice in TPTP I started with tutor "An Introduction to Using TPTP's
Automated GUI Recorder" from www.eclipse.org/tptp but couldn't finish it :(
as only new frame appear (after auto record was starting) - "New Project"
in that tutor - I can do nothing with it (compleetly disabled frame) until
stop recording, so XML have start lines only.
I try to record with my application but result thar I had even worse: I
can play with my apps during record, but result XML have only next two
lines
<macro version="1.0">
</macro>
Could you help me or point to next search?
Best regards.
Re: Unable to complete auto recording [message #84953 is a reply to message #84937] Fri, 06 October 2006 13:31 Go to previous messageGo to next message
I'm having a bit of difficulty understanding the exact problem you're
experiencing. I believe you're trying to record a test case but you only
get two lines in your macro.
I haven't done any testing on FedoraCore 5. If you have access to a Windows
machine, please try to see if you can reproduce the problem.
Do you get any error messages?
Can you check your workspace log file to see if any error messages are
recorded there?
You may want to also view the viewlet on the automated GUI recorder. You
can access it via:
http://www.eclipse.org/tptp/test/documents/userguides/auto-g ui-viewlet/auto-gui-viewlet_viewlet_swf.html
Ali Mehregani
"Oleg Klymenko" <oklym@meta.ua> wrote in message
news:6510c28fd3b7a854c3d24edfdbf16d07$1@www.eclipse.org...
> Hi guys,
> lines
> </macro>
> Best regards.
Re: Unable to complete auto recording [message #85042 is a reply to message #84953] Tue, 10 October 2006 03:43 Go to previous message
Ali,
many thanks for your attention with my problem.
I've repeat all my steps on Win2000 Pro. - all works well and I got
correct script. But I still have my problems under FC5...
Ok, I can make tests under Win, uncomfortably but let.
Best regards.
Oleg Klymenko
Previous Topic:TPTP Core (4.2.2.v200609010912--Cq0bcpd0qDlYrq) requires plug-in "org.eclipse.emf.ecore".
Next Topic:Execution statistics confusion
Current Time: Sat Jul 26 10:35:25 EDT 2025
Powered by FUDForum. Page generated in 0.07287 seconds
