createConnection missing? [message #84878] |
Mon, 23 June 2003 17:05  |
Originally posted by: rahul.dhar.intel.com
There used to be a method createConnection in
com.ibm.etools.gef.editparts.AbstractEditPart (or so I'm told). I was
also told that it had moved to the class
org.eclipse.gef.editparts.AbstractEditPart when GEF became part of
Eclipse. However, I can't find it in the API. Has it been removed or
moved somewhere? Is there a method that does the same thing?
Any guidance is much appreciated.
-Rahul
Intel Corp. does not endorse any content in this post. All opinions
contained are solely the opinions of the poster.
Re: createConnection missing? [message #84981 is a reply to message #84894] |
Tue, 24 June 2003 09:46   |
Randy, thanks for your help.
However, I'm confused about how factories, editparts, models, etc work
together. Is there documentation on how each component plugs into the
overall application and how they're supposed to interact with each other?
Thanks.
-Rahul
Randy Hudson wrote:
> It's in AbstractGraphicalEditPart, since only graphical editparts can have
> connections.
> Also, all createMethods now call out to an EditPartFactory by default. So
> you can new everything in the same place now.
> "Rahul Dhar" <rahul.dhar@intel.com> wrote in message
> news:bd7q37$958$1@rogue.oti.com...
> > Thanks,
> > -Rahul
Re: createConnection missing? [message #84993 is a reply to message #84981] |
Tue, 24 June 2003 10:01  |
The EditPartFactory does not work with your model. It's job is to create
the EditPart associated with an already-existing model object.
In the version you were using, you had to override createEditPart(Object
model) in multiple places. The only difference is that you can now create a
single EditPartFactory, set it on the EditPartViewer, and remove all
overrides of that method. Everything else is the same.
news:bd9kmo$pjk$1@rogue.oti.com...
> Thanks.
> -Rahul
have
> > connections.
So
> > > Thanks,
> > > -Rahul
FUDForum. Page generated in 0.06496 seconds
