Home » Archived » Visual Editor (VE) » No New-Visual Class Menu Item
No New-Visual Class Menu Item [message #84877] Sat, 26 March 2005 20:01 Go to next message
Originally posted by: PeterNZ.gmx.net
I downloaded VE-SDK 1.0.2 and put it on top of a working Eclipse 3.0.1.
(incl. JDT 3.0.1). I checked the information under Help - About Eclipse
Platform - Plugin Details and it shows all the entries listed in teh FAQ. I
also read through all the artikles I could find here in the newsgroups and
checked all recommended settings I found there. I also did a
"D:\eclipse\eclipse.exe -clean"
I still don't get the Visual Class Menu Item under "New"
My OS is Win XP Professional and I am using JRE 1.5
Does anyone have a clue of what I do wrong? Some help would be greatly
appreciated. Please let me know if you need any additional information.
Cheers
PeterNZ
Re: No New-Visual Class Menu Item [message #84908 is a reply to message #84877] Sat, 26 March 2005 20:07 Go to previous messageGo to next message
Originally posted by: ian.amham.net
Peter NZ wrote:
> Cheers
> PeterNZ
Have a look under File - New - Other. It should then be under the Java
list. That's where I see it. Not sure how to get it on the menu directly.
Ian
Re: No New-Visual Class Menu Item [message #84923 is a reply to message #84908] Sat, 26 March 2005 20:11 Go to previous messageGo to next message
Thanks Ian for your quick reply. But no, sorry also under "Other" no Visual
Class, only Package, Class, Interface etc.
Cheers
Peter
"ian" <ian@amham.net> wrote in message news:d255r3$qg2$1@news.eclipse.org...
> Peter NZ wrote:
>> I
>> and
>> Cheers
>> PeterNZ
> Cheers,
> Ian
Re: No New-Visual Class Menu Item [message #84938 is a reply to message #84923] Sat, 26 March 2005 20:36 Go to previous messageGo to next message
Click on the Other... option of the menu.
> Cheers
> Peter
>>Peter NZ wrote:
>>>Hi,
>>>I
>>>and
>>>Cheers
>>>PeterNZ
>>Cheers,
>>Ian
Re: No New-Visual Class Menu Item [message #84952 is a reply to message #84923] Sat, 26 March 2005 20:38 Go to previous messageGo to next message
Also have a look under Help About - Feature Details and verify that the
VE is there.
> Cheers
> Peter
>>Peter NZ wrote:
>>>Hi,
>>>I
>>>and
>>>Cheers
>>>PeterNZ
>>Cheers,
>>Ian
Re: No New-Visual Class Menu Item [message #84992 is a reply to message #84952] Sun, 27 March 2005 02:09 Go to previous messageGo to next message
Yepp, all there, org.eclipse.ve, org.eclipsie.ve.sdk and
org.eclipse.ve.source
Cheers
Peter
"ian" <ian@amham.net> wrote in message news:d257mr$sav$1@news.eclipse.org...
> Also have a look under Help About - Feature Details and verify that the VE
> is there.
>> Visual Class, only Package, Class, Interface etc.
>> Cheers
>> Peter
>>>Peter NZ wrote:
>>>>Hi,
>>>>FAQ. I
>>>>and
>>>>Cheers
>>>>PeterNZ
>>>Cheers,
>>>Ian
Re: No New-Visual Class Menu Item [message #85007 is a reply to message #84938] Sun, 27 March 2005 14:42 Go to previous messageGo to next message
Yes, that's what I did. But no "Visual Class" under "Other" sorry!
Cheers
Peter
"ian" <ian@amham.net> wrote in message news:d257ie$s6c$1@news.eclipse.org...
>> Cheers
>> Peter
>>>Peter NZ wrote:
>>>>Hi,
>>>>FAQ. I
>>>>and
>>>>Cheers
>>>>PeterNZ
>>>Cheers,
>>>Ian
Re: No New-Visual Class Menu Item [message #85022 is a reply to message #84877] Sun, 27 March 2005 15:01 Go to previous messageGo to next message
Originally posted by: myersj.gmail.com
Hi PeterNZ,
Do you have the PDE plug-ins installed? I ask this because you said
you've installed JDT 3.0.1, which implies you installed the Eclipse
runtime + JDT, rather than the Eclipse SDK. The VE does have a
dependency on PDE as well, but it's not listed on the requirements list
because the requirements specify that it should be installed on top of
Eclipse SDK.
Hope this helps,
- Jeff
PeterNZ wrote:
> Cheers
> PeterNZ
Re: No New-Visual Class Menu Item [message #85036 is a reply to message #84938] Sun, 27 March 2005 14:42 Go to previous messageGo to next message
Cheers
Peter
>> Cheers
>> Peter
>>>Peter NZ wrote:
>>>>Hi,
>>>>FAQ. I
>>>>and
>>>>Cheers
>>>>PeterNZ
>>>Cheers,
>>>Ian
Re: No New-Visual Class Menu Item [message #85050 is a reply to message #85022] Mon, 28 March 2005 02:40 Go to previous messageGo to next message
Hello Jeff,
thank you fo ryour reply.
hoenstly I wasn't sure if I installed the SDKor teh runtime. Iinstallfrom a
Developers Magazine CD. So I re-installed everything. First I installed
Eclipse SDK 3.0.1 (eclipse-platform-SDK-3.0.1-win32.zip), then the PDE Files
(eclipse-PDE-3.0.1.zip) and then JDT (eclipse-JDT-3.0.1.zip). On top of this
the VE files (VE-SDK-1.0.2.1.zip). And still the same problem.
Just to make sure if I do the right thing. I started Eclipse, switched to
Java Perspective and created a new Java Project with the default settings. I
then create a package under the project using the Context Menu of the
Project "New - Package" in the Package Explorer Window. Next step is the
context menu on the package and under "New ..." I only have "Project",
"Package", "Class", "Interface", "Source Folder", "Folder", "File", "JUnit
Test Case" and "Other". Also under "Other" I do not have a Visual Class
Entry.
Thank you for your help with this.
Peter
"Jeff Myers" <myersj@gmail.com> wrote in message
news:d27855$t70$1@news.eclipse.org...
> Hi PeterNZ,
> runtime + JDT, rather than the Eclipse SDK. The VE does have a dependency
> on PDE as well, but it's not listed on the requirements list because the
> requirements specify that it should be installed on top of Eclipse SDK.
> Hope this helps,
> - Jeff
> PeterNZ wrote:
>> I
>> and
>> Cheers
>> PeterNZ
Re: No New-Visual Class Menu Item [message #85079 is a reply to message #85050] Mon, 28 March 2005 15:31 Go to previous message
Originally posted by: sgtcasey.IH8SPAMcableone.net
On Mon, 28 Mar 2005 19:40:31 +1200, PeterNZ wrote:
> Hello Jeff,
> Entry.
Hey Peter I had the exact same problem as you are talking about when I
downloaded and installed VE manually. So, I decided to just start over and
delete the eclipse folder, unzip eclipse again and this time use Software
Updates (under Help) to install VE. Worked great after that and I was
never able to figure out why it didn't work the first time.
Now, if someone can just tell me how to change what Java code the VE
generates when you add swing items to the JFrame. :-)
Dave
You can talk about us, but you can't talk without us!
US Army Signal Corps!!
http://www.geocities.com/davidcasey98
Remove IH8SPAM to reply by email!
Re: No New-Visual Class Menu Item [message #606136 is a reply to message #84877] Sat, 26 March 2005 20:07 Go to previous message
Peter NZ wrote:
> Cheers
> PeterNZ
Ian
Re: No New-Visual Class Menu Item [message #606139 is a reply to message #84908] Sat, 26 March 2005 20:11 Go to previous message
Cheers
Peter
> Peter NZ wrote:
>> I
>> and
>> Cheers
>> PeterNZ
> Cheers,
> Ian
Re: No New-Visual Class Menu Item [message #606142 is a reply to message #84923] Sat, 26 March 2005 20:36 Go to previous message
> Cheers
> Peter
>>Peter NZ wrote:
>>>Hi,
>>>I
>>>and
>>>Cheers
>>>PeterNZ
>>Cheers,
>>Ian
Re: No New-Visual Class Menu Item [message #606144 is a reply to message #84923] Sat, 26 March 2005 20:38 Go to previous message
VE is there.
> Cheers
> Peter
>>Peter NZ wrote:
>>>Hi,
>>>I
>>>and
>>>Cheers
>>>PeterNZ
>>Cheers,
>>Ian
Re: No New-Visual Class Menu Item [message #606155 is a reply to message #84952] Sun, 27 March 2005 02:09 Go to previous message
Cheers
Peter
> is there.
>> Cheers
>> Peter
>>>Peter NZ wrote:
>>>>Hi,
>>>>FAQ. I
>>>>and
>>>>Cheers
>>>>PeterNZ
>>>Cheers,
>>>Ian
Re: No New-Visual Class Menu Item [message #606158 is a reply to message #84938] Sun, 27 March 2005 14:42 Go to previous message
Cheers
Peter
>> Cheers
>> Peter
>>>Peter NZ wrote:
>>>>Hi,
>>>>FAQ. I
>>>>and
>>>>Cheers
>>>>PeterNZ
>>>Cheers,
>>>Ian
Re: No New-Visual Class Menu Item [message #606160 is a reply to message #84877] Sun, 27 March 2005 15:01 Go to previous message
Hi PeterNZ,
Eclipse SDK.
Hope this helps,
- Jeff
PeterNZ wrote:
> Cheers
> PeterNZ
Re: No New-Visual Class Menu Item [message #606164 is a reply to message #84938] Sun, 27 March 2005 14:42 Go to previous message
Cheers
Peter
>> Cheers
>> Peter
>>>Peter NZ wrote:
>>>>Hi,
>>>>FAQ. I
>>>>and
>>>>Cheers
>>>>PeterNZ
>>>Cheers,
>>>Ian
Re: No New-Visual Class Menu Item [message #606167 is a reply to message #85022] Mon, 28 March 2005 02:40 Go to previous message
Hello Jeff,
Entry.
Peter
> Hi PeterNZ,
> Hope this helps,
> - Jeff
> PeterNZ wrote:
>> I
>> and
>> Cheers
>> PeterNZ
Re: No New-Visual Class Menu Item [message #606174 is a reply to message #85050] Mon, 28 March 2005 15:31 Go to previous message
> Hello Jeff,
> Entry.
Dave
Previous Topic:Visual Design without screen scrape
Next Topic:No EditParts in VE SWT
Current Time: Wed Jul 16 02:08:58 EDT 2025
Powered by FUDForum. Page generated in 0.06453 seconds
