Home » Language IDEs » Java Development Tools (JDT) » Call Javadoc View from own editor
Call Javadoc View from own editor [message #756075] Thu, 10 November 2011 14:13 Go to next message
Hello everybody,
I wrote a new editor to document my APIs. It also supports Java and Javadoc. I would like to show the Javadoc of the current selected method by my editor in the Javadoc view (like the Project Explorer does with Java-Files). But I didn't get it working yet.
In my editor I implemented the interface ISelectionProvider:
private Set<ISelectionChangedListener> listeners = new HashSet<ISelectionChangedListener>();
public void setSelection(ISelection arg0)
        // Get the selected method from my editor...
	IJavaElement selection = (IJavaElement) ...;
        if (selection != null)
	  Object[] elements = new Object[1];
	  elements[0] = selection;
	StructuredSelection sel = new StructuredSelection(elements);
	SelectionChangedEvent event = new SelectionChangedEvent(this, sel);
	for (ISelectionChangedListener listener : listeners)
		listener.selectionChanged(event);
public void removeSelectionChangedListener(ISelectionChangedListener arg0)
 listeners.remove(arg0);
public ISelection getSelection()
  // Get the method from my editor ...
  IJavaElement selection = (IJavaElement)...;
	return sel;
  return null;
public void addSelectionChangedListener(ISelectionChangedListener arg0)
	listeners.add(arg0);
In the init-method I register my selection provider
		getSite().setSelectionProvider(this);
But when changing my selected method, the Javadoc View does not react. By using the debugger I could see that the changed selection is set to the listeners. But there is no Javadoc view in there. Is my approach correct? Could anybody give me a hint or an example?
Greetings
Jan Chistian
Re: Call Javadoc View from own editor [message #756535 is a reply to message #756075] Mon, 14 November 2011 04:01 Go to previous message
On 10.11.2011 20:13, Jan Christian Krause wrote:
> Hello everybody,
Make sure the Javadoc view is already open and that 'Link with
Selection' is enabled. If that's the case and it's still not working,
then start debugging in
org.eclipse.jdt.internal.ui.infoviews.AbstractInfoView.selectionChanged(IWorkbenchPart,
ISelection).
Dani
> @Override
> @Override
> arg0)
> @Override
> return sel;
> return null;
> @Override
> Greetings
> Jan Chistian
Previous Topic:"Comparison method violates its general contract!" Error
Next Topic:no grammar constraints dtd or xml schema detected for the document
Current Time: Sun Jul 13 15:40:05 EDT 2025
Powered by FUDForum. Page generated in 0.04936 seconds
