Home » Eclipse Projects » Eclipse Platform » Question : No Java Virtual Machine ?
Question : No Java Virtual Machine ? [message #84876] Sun, 29 June 2003 16:44 Go to next message
Originally posted by: g_vangeel.hotmail.com
------=_NextPart_000_0072_01C33E8F.FC42AF60
Content-Type: text/plain;
charset="iso-8859-1"
Hello everybody,
I've installed Eclipse on a RedHat 9.0 system together with the =
j2sdk1.4.0_03 and the j2re1.4.0_03.
When I try to start Eclipse I get the following error message...
A Java Runtime Environment (JRE) or Java Development Kit (JDK)
must be available in order to run Eclipse. No Java virtual machine
was found after searching the following locations:
/usr/local/eclipse/./jre/bin/java
'java' in your current PATH
Even when I try using the -vm option to point eclipse to the j2sdk or =
j2re directory it won't work.
Can anyone help me to get eclipse to work please. (I'm fairly new to =
Linux and Java)
Thanks in advance
Kind Regards
Gert Vangeel
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.2800.1106" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2>Hello everybody,</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DArial size=3D2>I've installed Eclipse on a RedHat 9.0 =
system=20
together with the j2sdk1.4.0_03 and the j2re1.4.0_03.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>When I try to start Eclipse I get the =
following=20
error message...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><EM>A Java Runtime Environment (JRE) or =
Java=20
Development Kit (JDK)<BR>must be available in order to run Eclipse. No =
Java=20
virtual machine<BR>was found after searching the following=20
locations:<BR>/usr/local/eclipse/./jre/bin/java<BR>'java' in your =
current=20
PATH</EM></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Even when I try using the -vm option to =
point=20
eclipse to the j2sdk or j2re directory it won't work.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Can anyone help me to get eclipse to =
work please.=20
<FONT color=3D#800000>(I'm fairly new to Linux and =
Java)</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Thanks in advance</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Kind Regards</FONT></DIV>
<DIV><FONT face=3DArial color=3D#000080 size=3D2><STRONG>Gert=20
Vangeel</STRONG></FONT></DIV></BODY></HTML>
------=_NextPart_000_0072_01C33E8F.FC42AF60--
Re: Question : No Java Virtual Machine ? [message #84891 is a reply to message #84876] Sun, 29 June 2003 17:44 Go to previous messageGo to next message
use the -vm to point to j2sdk1.4.0_03/bin, not just j2sdk1.4.0_03
Gert Vangeel wrote:
> Hello everybody,
> /A Java Runtime Environment (JRE) or Java Development Kit (JDK)
> 'java' in your current PATH/
> Linux and Java)
> Thanks in advance
> Kind Regards
> *Gert Vangeel*
Re: Question : No Java Virtual Machine ? [message #85146 is a reply to message #84891] Mon, 30 June 2003 06:04 Go to previous messageGo to next message
Actually, you want to point it to the executable, not just the bin
directory, e.g. -vm j2sdk1.4.0_03/bin/java.exe
Jerome
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:bdnmjc$f15$1@rogue.oti.com...
> Gert Vangeel wrote:
> > Hello everybody,
> > Linux and Java)
> > Thanks in advance
> > Kind Regards
> > *Gert Vangeel*
Re: Question : No Java Virtual Machine ? [message #85252 is a reply to message #85146] Mon, 30 June 2003 07:49 Go to previous messageGo to next message
That's it !!!
Thank you very much to everybody who helped me here !
Kind regards,
Gert Vangeel
"Jerome Lanneluc" <jerome_lanneluc@fr.ibm.com> wrote in message
news:bdp207$ba8$1@rogue.oti.com...
> Jerome
> > Gert Vangeel wrote:
> > > Hello everybody,
> > > Linux and Java)
> > > Thanks in advance
> > > Kind Regards
> > > *Gert Vangeel*
Re: Question : No Java Virtual Machine ? [message #85847 is a reply to message #84876] Mon, 30 June 2003 16:20 Go to previous message
Originally posted by: msolo.third-bit.com
Hi Gert,
Also, set your JAVA_HOME variable to point to the j2sdk1.4.0_03 directory.
For example, under Red Hat add this line to your ~/.bash_profile file:
export JAVA_HOME=/usr/share/j2sdk1.4.0
This will allow you to run Eclipse without the -vm option and may solve
other future problems.
Matthew
Previous Topic:Multiuser Eclipse and Private Plugin Install
Next Topic:Newbie question re:/.classpath files
Current Time: Fri Jul 18 03:16:00 EDT 2025
Powered by FUDForum. Page generated in 0.28982 seconds
