Home » Eclipse Projects » Eclipse Platform » Replacing selection in navigator causing exception
Replacing selection in navigator causing exception [message #84817] Sun, 29 June 2003 12:53
I have implemented Editor that uses viewer and extends EditorPart.
Whenever i change resource in navigator or exit platform I get error says:
FileEditorInputFactory.createElement() is null in error log.
I say it has to do with saveState of worbench and EditorHistory and object
from type IMemento, yet I can't figure out what is worng.
Another thing is that I expected that after open file from type I created
with the spacial editor extension i build for it, and then I open file from
java type or xml the appropriate editor will be opened and the editor from
the type I created will be hidden. It doesn't happen. Maby bug is the reason
or I don't get something.
Thanks in advance lads,
Asaf.
Previous Topic:How to create ViewPart that will react like EditorPart
Next Topic:Force patform to open viewer
Current Time: Thu Jul 17 05:46:15 EDT 2025
Powered by FUDForum. Page generated in 0.04292 seconds
