Home » Archived » Visual Editor (VE) » Blank Shell
Blank Shell [message #84816] Sat, 26 March 2005 08:50 Go to next message
Originally posted by: ian.amham.net
I have been trolling through the threads but don't see quite what I am
looking for.
I have just started with VE 2.0.1 on Eclipse 3.0.1.
I create an SWT Shell application - it has the main call.
I added a couple of labels and a button.
I can see the code. I can run it and it looks okay, but the design
palette has only a blank shell, the labels and button are not shown.
Also the design palette is showing a error
size: java.lang.IllegalArgumentException(object is not an instance of
declaring class)
I also seem to have killed my .log file whilst trying to get its data.
How do I get it back?
Thanks in advance.
Ian
Re: Blank Shell [message #84831 is a reply to message #84816] Sat, 26 March 2005 11:50 Go to previous messageGo to next message
Hi ian,
> declaring class)
The .log file is always created when required and gets continually
written, so in fact deleting it is a graeat way to ensure you have a
clean file with no noise in it.
Open your class and then get the .log file in the .metadata directory of
whereever the workbench is. If when you launch eclipse.exe you use the
command line option -showlocation this should always let you see the
workspace location at in the Workbech window.
Once you have the .log file attach it to a note because this contains
the detail of what is going wrong and hopefuly we can work out why the
target VM image isn't showing up correctly in GEF.
Joe
Re: Blank Shell [message #84845 is a reply to message #84831] Sat, 26 March 2005 19:57 Go to previous messageGo to next message
Joe Winchester wrote:
> Hi ian,
>> declaring class)
> Best regards,
> Joe
Thanks for the reply.
I still don't seem to be able to make my .log file reappear, but I can
see, from the about information, the GEF is version 3.0.1.
I'm sure my problem is just some sort of configuration thing, I will
keep digging.
Ian
Re: Blank Shell [message #84893 is a reply to message #84831] Sat, 26 March 2005 20:03 Go to previous messageGo to next message
> Hi ian,
>> declaring class)
> Best regards,
> Joe
Ah, the configuration details via Help about are as follows, does that
help? Other than that it's a standard XP machine.
*** Features:
org.eclipse.cdt (2.1.0) "Eclipse C/C++ Development Tools"
org.eclipse.cdt.sdk (2.1.0) "Eclipse C/C++ Development Tools SDK"
org.eclipse.cdt.source (2.1.0) "Eclipse C/C++ Development Tools (Source)"
org.eclipse.emf (2.0.1) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.0.1) "Eclipse Modeling Framework (EMF)
Programmers Guide"
org.eclipse.emf.ecore.sdo (2.0.1) "EMF Service Data Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.0.0) "EMF Service Data Objects (SDO)
Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.0.1) "EMF Service Data Objects (SDO)
Source"
org.eclipse.emf.source (2.0.1) "Eclipse Modeling Framework (EMF) Source"
org.eclipse.gef (3.0.1) "Graphical Editing Framework"
org.eclipse.jdt (3.0.1) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.0.1) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.0.2.1) "Java EMF Model"
org.eclipse.pde (3.0.1) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.0.1) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.0.1) "Eclipse Platform"
org.eclipse.platform.source (3.0.1) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.sdk (3.0.1) "Eclipse Project SDK"
org.eclipse.sdk.examples (3.1.0) "Eclipse SDK Examples"
org.eclipse.sdk.samples (3.0.0) ""
org.eclipse.uml2 (1.1.0) "UML2"
org.eclipse.uml2.doc (1.1.0) "UML2 Documentation"
org.eclipse.uml2.examples (1.1.0) "UML2 Examples"
org.eclipse.uml2.examples.source (1.1.0) "UML2 Examples Source"
org.eclipse.uml2.source (1.1.0) "UML2 Source"
org.eclipse.ve (1.0.2.1) "Visual Editor"
org.eclipse.xsd (2.0.1) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.0.0) "XML Schema Infoset Model (XSD) Programmers
Guide"
org.eclipse.xsd.source (2.0.1) "XML Schema Infoset Model (XSD) Source"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model"
com.ibm.wtp.common.util (1.0.1) "Logging Plug-in"
com.ibm.wtp.emf.workbench (1.0.1.2) "EMF Workbench"
org.apache.ant (1.6.2) "Apache Ant"
org.apache.lucene (1.3.1) "Apache Lucene"
org.eclipse.ant.core (3.0.0) "Ant Build Tool Core"
org.eclipse.ant.ui (3.0.1) "Ant UI"
org.eclipse.cdt.core (2.1.0) "C/C++ Development Tools Core"
org.eclipse.cdt.core.win32 (2.1.0) "C/C++ Development Tools Core for
Windows"
org.eclipse.cdt.debug.core (2.1.0) "C/C++ Development Tools Debug Model"
org.eclipse.cdt.debug.mi.core (2.1.0) "C/C++ Development Tools GDB/MI
CDI Debugger Core"
org.eclipse.cdt.debug.mi.ui (2.1.0) "C/C++ Development Tools GDB/MI CDI
Debugger UI"
org.eclipse.cdt.debug.ui (2.1.0) "C/C++ Development Tools Debugger UI"
org.eclipse.cdt.doc.user (2.1.0) "C/C++ Development User Guide"
org.eclipse.cdt.launch (2.1.0) "C/C++ Development Tools Launching Support"
org.eclipse.cdt.make.core (2.1.0) "C/C++ Standard make Build Core"
org.eclipse.cdt.make.ui (2.1.0) "C/C++ Standard make Build UI"
org.eclipse.cdt.managedbuilder.core (2.1.0) "C/C++ Managed Builder Core"
org.eclipse.cdt.managedbuilder.ui (2.1.0) "C/C++ Managed Builder UI"
org.eclipse.cdt.source.win32.win32.x86 (2.1.0) "Eclipse C/C++
org.eclipse.cdt.ui (2.1.0) "C/C++ Development Tools UI"
org.eclipse.compare (3.0.0) "Compare Support"
org.eclipse.compare.examples (3.1.0) "Compare Example"
org.eclipse.compare.examples.xml (3.1.0) "XML Compare Support"
org.eclipse.core.boot (3.0.0) "Core Boot"
org.eclipse.core.expressions (3.0.0) "Expression Language"
org.eclipse.core.filebuffers (3.0.1) "File Buffers"
org.eclipse.core.resources (3.0.1) "Core Resource Management"
org.eclipse.core.resources.win32 (3.0.0) "Core Resource Management Win32
Fragment"
org.eclipse.core.runtime (3.0.1) "Core Runtime"
org.eclipse.core.runtime.compatibility (3.0.0) "Core Runtime Plug-in
Compatibility"
org.eclipse.core.variables (3.0.0) "Core Variables"
org.eclipse.debug.core (3.0.1) "Debug Core"
org.eclipse.debug.ui (3.0.1) "Debug UI"
org.eclipse.draw2d (3.0.1) "Draw2d"
org.eclipse.emf.codegen (2.0.1) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.0.1) "EMF Ecore Code Generation"
org.eclipse.emf.codegen.ecore.ui (2.0.1) "EMF Ecore Code Generation UI"
org.eclipse.emf.codegen.ui (2.0.0) "EMF Template Code Generator UI"
org.eclipse.emf.common (2.0.1) "EMF Common"
org.eclipse.emf.common.ui (2.0.1) "EMF Common UI"
org.eclipse.emf.commonj.sdo (2.0.0) "CommonJ SDO"
Programmers Guide"
org.eclipse.emf.ecore (2.0.1) "EMF Ecore"
org.eclipse.emf.ecore.change (2.0.1) "EMF Ecore Change Model"
org.eclipse.emf.ecore.change.edit (2.0.0) "EMF Ecore Change Edit Support"
org.eclipse.emf.ecore.edit (2.0.0) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.0.1) "Sample Ecore Editor"
Programmers Guide"
org.eclipse.emf.ecore.sdo.edit (2.0.0) "EMF Service Data Objects (SDO)
Edit Support"
org.eclipse.emf.ecore.sdo.editor (2.0.0) "EMF Service Data Objects (SDO)
Editor"
Source"
org.eclipse.emf.ecore.xmi (2.0.1) "EMF XMI"
org.eclipse.emf.edit (2.0.1) "EMF Edit"
org.eclipse.emf.edit.ui (2.0.1) "EMF Edit UI"
org.eclipse.emf.mapping (2.0.1) "EMF Mapping"
org.eclipse.emf.mapping.ecore2ecore (2.0.1) "Ecore to Ecore Mapping"
org.eclipse.emf.mapping.ecore2ecore.editor (2.0.1) "Ecore to Ecore
Mapping Editor"
org.eclipse.emf.mapping.ui (2.0.0) "EMF Mapping UI"
org.eclipse.emf.mapping.xsd2ecore (2.0.1) "XSD to Ecore Mapping"
org.eclipse.emf.mapping.xsd2ecore.editor (2.0.1) "XSD to Ecore Mapping
Editor"
org.eclipse.help (3.0.0) "Help System Core"
org.eclipse.help.appserver (3.0.0) "Help Application Server"
org.eclipse.help.base (3.0.1) "Help System Base"
org.eclipse.help.examples.ex1 (3.0.0) "Online Help Sample"
org.eclipse.help.ide (3.0.0) "Help System IDE"
org.eclipse.help.ui (3.0.0) "Help System UI"
org.eclipse.help.webapp (3.0.1) "Help System Webapp"
org.eclipse.jdt.core (3.0.1) "Java Development Tools Core"
org.eclipse.jdt.debug (3.0.1) "JDI Debug Model"
org.eclipse.jdt.debug.ui (3.0.1) "JDI Debug UI"
org.eclipse.jdt.doc.isv (3.0.1) "Eclipse JDT Plug-in Developer Guide"
org.eclipse.jdt.doc.user (3.0.1) "Eclipse Java Development User Guide"
org.eclipse.jdt.junit (3.0.1) "Java Development Tools JUnit support"
org.eclipse.jdt.junit.runtime (3.0.0) "Java Development Tools JUnit
runtime support"
org.eclipse.jdt.launching (3.0.1) "Java Development Tools Launching Support"
org.eclipse.jdt.ui (3.0.1) "Java Development Tools UI"
org.eclipse.jdt.ui.examples.projects (3.1.0) "Java Development Tools
Example Projects"
org.eclipse.jem (1.0.2) "Java EMF Model"
org.eclipse.jem.beaninfo (1.0.2) "Java EMF Model BeanInfo
(Introspection) Support"
org.eclipse.jem.proxy (1.0.2) "Java EMF Model Proxy Support"
org.eclipse.jem.ui (1.0.1) "Java EMF Model UI"
org.eclipse.jem.workbench (1.0.2) "Java EMF Model Workbench Support"
org.eclipse.jface (3.0.0) "JFace"
org.eclipse.jface.text (3.0.1) "JFace Text"
org.eclipse.ltk.core.refactoring (3.0.1) "Refactoring Core"
org.eclipse.ltk.ui.refactoring (3.0.1) "Refactoring UI"
org.eclipse.osgi (3.0.1) "OSGi System Bundle"
org.eclipse.osgi.services (3.0.0) "OSGi Release 3 Services"
org.eclipse.osgi.util (3.0.0) "OSGi R3 Utility Classes"
org.eclipse.pde.build (3.0.1) "Plug-in Development Environment Build
Support"
org.eclipse.pde.core (3.0.1) "Plug-in Development Core"
org.eclipse.pde.doc.user (3.0.0) "Eclipse Plug-in Development User Guide"
org.eclipse.pde.junit.runtime (3.0.0) "PDE JUnit Plug-in Test"
org.eclipse.pde.runtime (3.0.1) "Plug-in Development Environment Runtime"
org.eclipse.pde.ui (3.0.1) "Plug-in Development UI"
org.eclipse.platform.doc.isv (3.0.1) "Eclipse Platform Plug-in Developer
Guide"
org.eclipse.platform.doc.user (3.0.1) "Eclipse Workbench User Guide"
Resources"
org.eclipse.platform.source.win32.win32.x86 (3.0.1) "Eclipse Platform
Plug-in Developer Resources"
org.eclipse.sdk.examples.source (3.1.0) "Eclipse Platform Plug-in
org.eclipse.sdk.examples.source.win32.win32.x86 (3.1.0) "Eclipse
Platform Plug-in Developer Resources"
org.eclipse.sdk.samples (3.0.0) "Experimental Eclipse SDK Samples"
org.eclipse.search (3.0.1) "Search Support"
org.eclipse.swt (3.0.1) "Standard Widget Toolkit"
org.eclipse.swt.examples (3.1.0) "SWT Standalone Examples Plugin"
org.eclipse.swt.examples.browser (3.1.0) "SWT Browser Example Plugin"
org.eclipse.swt.examples.browser.demos (3.1.0) "SWT Browser Demos Plugin"
org.eclipse.swt.examples.controls (3.1.0) "SWT Controls Example Plugin"
org.eclipse.swt.examples.launcher (3.1.0) "SWT Launcher Example Plugin"
org.eclipse.swt.examples.layouts (3.1.0) "SWT Layout Example Plugin"
org.eclipse.swt.examples.ole.win32 (3.1.0) "SWT OLE Example Plugin (Win32)"
org.eclipse.swt.examples.paint (3.1.0) "SWT Paint Example Plugin"
org.eclipse.swt.win32 (3.0.1) "Standard Widget Toolkit for Windows"
org.eclipse.team.core (3.0.0) "Team Support Core"
org.eclipse.team.cvs.core (3.0.1) "CVS Team Provider Core"
org.eclipse.team.cvs.ssh (3.0.0) "CVS SSH Core"
org.eclipse.team.cvs.ssh2 (3.0.0) "CVS SSH2"
org.eclipse.team.cvs.ui (3.0.1) "CVS Team Provider UI"
org.eclipse.team.examples.filesystem (3.1.0) "Eclipse Team File System
Example"
org.eclipse.team.ui (3.0.1) "Team Support UI"
org.eclipse.text (3.0.1) "Text"
org.eclipse.tomcat (4.1.30) "Tomcat Wrapper"
org.eclipse.ui (3.0.1) "Eclipse UI"
org.eclipse.ui.cheatsheets (3.0.1) "Cheat Sheets"
org.eclipse.ui.console (3.0.0) "Console"
org.eclipse.ui.editors (3.0.1) "Default Text Editor"
org.eclipse.ui.examples.javaeditor (3.1.0) "JFace Text Example"
org.eclipse.ui.examples.multipageeditor (3.1.0) "Multi-Page Editor Example"
org.eclipse.ui.examples.propertysheet (3.1.0) "User File Editor"
org.eclipse.ui.examples.readmetool (3.1.0) "Readme File Editing Tool"
org.eclipse.ui.externaltools (3.0.1) "External Tools"
org.eclipse.ui.forms (3.0.0) "Eclipse Forms"
org.eclipse.ui.ide (3.0.1) "Eclipse IDE UI"
org.eclipse.ui.intro (3.0.1) "Intro Plugin"
org.eclipse.ui.presentations.r21 (3.0.1) "R21 Presentation Plug-in"
org.eclipse.ui.views (3.0.0) "Views"
org.eclipse.ui.win32 (3.0.1) "Win32 fragment"
org.eclipse.ui.workbench (3.0.1) "Workbench"
org.eclipse.ui.workbench.compatibility (3.0.0) "Workbench Compatibility"
org.eclipse.ui.workbench.texteditor (3.0.1) "Text Editor Framework"
org.eclipse.uml2.edit (1.1.0) "UML2 Edit Support"
org.eclipse.uml2.editor (1.1.0) "UML2 Editor"
org.eclipse.uml2.examples.emof2ecore (1.1.0) "EMOF2Ecore Example"
org.eclipse.uml2.examples.ui (1.1.0) "UML2 Examples UI"
org.eclipse.uml2.mapping.ecore2xml (1.1.0) "Ecore2XML Model"
org.eclipse.uml2.mapping.ecore2xml.edit (1.1.0) "Ecore2XML Edit Support"
org.eclipse.uml2.mapping.ecore2xml.editor (1.1.0) "Ecore2XML Editor"
org.eclipse.uml2.resources (1.1.0) "UML2 Resources"
org.eclipse.update.configurator (3.0.0) "Install/Update Configurator"
org.eclipse.update.core (3.0.1) "Install/Update Core"
org.eclipse.update.core.win32 (3.0.0) "Install/Update Core for Windows"
org.eclipse.update.scheduler (3.0.0) "Automatic Updates Scheduler"
org.eclipse.update.ui (3.0.1) "Install/Update UI"
org.eclipse.ve (1.0.1) "Visual Editor"
org.eclipse.ve.cde (1.0.2) "Visual Editor Common Data Editor"
org.eclipse.ve.doc (1.0.1) "Visual Editor User Guide"
org.eclipse.ve.java.core (1.0.2.1) "Visual Editor Java Core"
org.eclipse.ve.jfc (1.0.2) "Visual Editor for Java Foundation Classes"
org.eclipse.ve.propertysheet (1.0.1) "Visual Editor PropertySheet"
org.eclipse.ve.swt (1.0.2) "Visual Editor for Standard Widget Toolkit"
Guide"
org.eclipse.xsd.edit (2.0.1) "XML Schema Edit Framework"
org.eclipse.xsd.editor (2.0.1) "XML Schema Editor"
org.eclipse.xsd.test (2.0.1) "XML Schema Infoset Model Test"
org.junit (3.8.1) "JUnit Testing Framework"
Re: Blank Shell [message #85154 is a reply to message #84893] Tue, 29 March 2005 08:54 Go to previous message
To get at the .log, Use the Preferences page -> Capabilities -> Development and check the Plug-in Development checkbox.
Then, Use Window->Show View -> Error log
Re: Blank Shell [message #606111 is a reply to message #84816] Sat, 26 March 2005 11:50 Go to previous message
Hi ian,
> declaring class)
Joe
Re: Blank Shell [message #606115 is a reply to message #84831] Sat, 26 March 2005 19:57 Go to previous message
> Hi ian,
>> declaring class)
> Best regards,
> Joe
keep digging.
Ian
Re: Blank Shell [message #606132 is a reply to message #84831] Sat, 26 March 2005 20:03 Go to previous message
> Hi ian,
>> declaring class)
> Best regards,
> Joe
*** Features:
Programmers Guide"
Programmers Guide"
Source"
Resources"
Guide"
Windows"
CDI Debugger Core"
Debugger UI"
Fragment"
Compatibility"
Programmers Guide"
Programmers Guide"
Edit Support"
Editor"
Source"
Mapping Editor"
Editor"
runtime support"
Example Projects"
Support"
Guide"
Resources"
Example"
Guide"
Re: Blank Shell [message #606191 is a reply to message #84893] Tue, 29 March 2005 08:54 Go to previous message
Previous Topic:Visual Design without screen scrape
Next Topic:VE & omondo
Current Time: Sun Aug 31 03:11:02 EDT 2025
Powered by FUDForum. Page generated in 0.06031 seconds
