Tomcat 4.1 fails when deploying web service [message #84802] |
Fri, 18 March 2005 03:56  |
Originally posted by: kthuno.gmail.com
Whenever I try doing a web service as described in the tutorials I get a
Tomcat error:
<code>
IWAB0213E Error in starting server.
org.eclipse.core.runtime.CoreException: Server Tomcat v4.1 Server @
localhost failed to start.
org.eclipse.wst.server.core.internal.Server.synchronousStart (Server.java:1484)
org.eclipse.jst.ws.internal.consumption.command.common.Abstr actStartServer.startProject(AbstractStartServer.java:110)
org.eclipse.jst.ws.internal.consumption.command.common.Abstr actStartServer.StartServer(AbstractStartServer.java:81)
org.eclipse.jst.ws.internal.consumption.command.common.Start ProjectCommand.execute(StartProjectCommand.java:106)
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.runCommand(CommandFragmentEngine.java:322)
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.visitTop(CommandFragmentEngine.java:288)
org.eclipse.wst.command.env.core.fragment.CommandFragmentEng ine.moveForwardToNextStop(CommandFragmentEngine.java:208)
org.eclipse.wst.command.env.ui.widgets.SimpleCommandEngineMa nager$4.run(SimpleCommandEngineManager.java:206)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:344)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:289)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 824)
org.eclipse.wst.command.env.ui.widgets.SimpleCommandEngineMa nager.runForwardToNextStop(SimpleCommandEngineManager.java:1 75)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:69)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.getNextPage(WizardPageManager.java:91)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleWizard Page.getNextPage(SimpleWizardPage.java:123)
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:741)
</code>
Looking at the PDE runtime error log I have this:
<code>
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
STACKTRACE ->
org.eclipse.jst.server.tomcat.core.internal.TomcatRuntimeTar getHandler.getClasspathContainerLabel(TomcatRuntimeTargetHan dler.java:47)
org.eclipse.jst.server.core.internal.RuntimeClasspathContain er.getDescription(RuntimeClasspathContainer.java:56)
org.eclipse.jdt.internal.ui.packageview.ClassPathContainer.g etLabel(ClassPathContainer.java:163)
org.eclipse.jdt.ui.JavaElementLabels.getTextLabel(JavaElemen tLabels.java:333)
org.eclipse.jdt.internal.ui.viewsupport.JavaUILabelProvider. getText(JavaUILabelProvider.java:161)
org.eclipse.jdt.internal.ui.packageview.PackageExplorerLabel Provider.getText(PackageExplorerLabelProvider.java:46)
org.eclipse.jface.viewers.DecoratingLabelProvider.getText(De coratingLabelProvider.java:118)
org.eclipse.jface.viewers.DecoratingLabelProvider.updateLabe l(DecoratingLabelProvider.java:208)
org.eclipse.jface.viewers.StructuredViewer.buildLabel(Struct uredViewer.java:1712)
at org.eclipse.jface.viewers.TreeViewer.doUpdateItem(TreeViewer .java:206)
org.eclipse.jface.viewers.AbstractTreeViewer$UpdateItemSafeR unnable.run(AbstractTreeViewer.java:86)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:1015)
at org.eclipse.core.runtime.Platform.run(Platform.java:757)
org.eclipse.jface.viewers.AbstractTreeViewer.doUpdateItem(Ab stractTreeViewer.java:490)
org.eclipse.jface.viewers.StructuredViewer$UpdateItemSafeRun nable.run(StructuredViewer.java:352)
Internal error logged from JDI Debug:
STACKTRACE ->
org.eclipse.jdi.TimeoutException: Timeout occurred while waiting for
packet 682
org.eclipse.jdi.internal.connect.PacketReceiveManager.getRep ly(PacketReceiveManager.java:163)
org.eclipse.jdi.internal.connect.PacketReceiveManager.getRep ly(PacketReceiveManager.java:172)
at org.eclipse.jdi.internal.MirrorImpl.requestVM(MirrorImpl.jav a:174)
at org.eclipse.jdi.internal.MirrorImpl.requestVM(MirrorImpl.jav a:192)
at org.eclipse.jdi.internal.MirrorImpl.requestVM(MirrorImpl.jav a:207)
org.eclipse.jdi.internal.ThreadReferenceImpl.threadGroup(Thr eadReferenceImpl.java:454)
org.eclipse.jdt.internal.debug.core.model.JDIThread.getUnder lyingThreadGroup(JDIThread.java:1564)
org.eclipse.jdt.internal.debug.core.model.JDIThread.determin eIfSystemThread(JDIThread.java:365)
org.eclipse.jdt.internal.debug.core.model.JDIThread.initiali ze(JDIThread.java:221)
org.eclipse.jdt.internal.debug.core.model.JDIThread.<init>(JDIThread.java:204)
org.eclipse.jdt.internal.debug.core.model.JDIDebugTarget.cre ateThread(JDIDebugTarget.java:443)
org.eclipse.jdt.internal.debug.core.model.JDIDebugTarget$Thr eadStartHandler.handleEvent(JDIDebugTarget.java:1750)
org.eclipse.jdt.internal.debug.core.EventDispatcher.dispatch (EventDispatcher.java:137)
org.eclipse.jdt.internal.debug.core.EventDispatcher.run(Even tDispatcher.java:221)
at java.lang.Thread.run(Thread.java:595)
</code>
Can anyone make any sense of this because I'm lost.
Thanks in advance,
Kasper
FUDForum. Page generated in 0.05151 seconds
