Home » Eclipse Projects » Eclipse Platform » Printin from eclipse under Linux
Printin from eclipse under Linux [message #84760] Sun, 29 June 2003 06:25 Go to next message
Originally posted by: Riedel.Christian.gmx.net
I just wonder, how it is possible to print from eclipse under linux. I
remember to have read somewhere that xprint has to be installed to
acchieve this. But I _have_ xprint installed and the print button
remains disabled.
Can anyone help please?
Christian
Re: Printin from eclipse under Linux [message #85861 is a reply to message #84760] Mon, 30 June 2003 16:25 Go to previous messageGo to next message
Originally posted by: msolo.third-bit.com
Hi Christian,
It is possible to print from Eclipse under Linux. Can you print from other
applications? Xprint (or Xprt) is a module that you will need, along with
either CUPS or LPRing. Consult your Linux distribution's documentation to learn
how to setup your printer.
Matthew
Re: Printin from eclipse under Linux [message #86117 is a reply to message #85861] Tue, 01 July 2003 02:10 Go to previous messageGo to next message
Matthew Solo wrote:
> Hi Christian,
Hi Mathew,
printing from other applications works just fine (I have CUPS
installed). Eeven printing from mozilla is not a problem any longer
thank to the fact that I have the xprint-modules installed.
But still all the Print-Options in Eclipse remain disabled.
Are there any settings I have to edit?
Hope you can help again.
Christian
Re: Printin from eclipse under Linux [message #86584 is a reply to message #86117] Tue, 01 July 2003 13:04 Go to previous message
Originally posted by: jared-eclipse.mn.rr.com
https://bugs.eclipse.org/bugs/show_bug.cgi?id=24796
Printing on Linux-GTK is not supported. If you just want to print files, you
can do it by configuring an external tool that does command-line printing
with the selected resource as an argument.
I know this has been done, but I don't have a copy of the external tool nor
do I know how to print from the command line off hand. If I wanted to set
this up, I'd probably start with "man lpr". :-)
- Jared
Christian Riedel wrote:
> Matthew Solo wrote:
>> Hi Christian,
>> other applications? Xprint (or Xprt) is a module that you will need,
>> along with either CUPS or LPRing. Consult your Linux distribution's
>> documentation to learn how to setup your printer.
Previous Topic:Remove all menus from workbench window
Next Topic:Default JVM Arguments for debugging
Current Time: Wed Sep 24 14:43:20 EDT 2025
Powered by FUDForum. Page generated in 0.03945 seconds
